25
Everything posted by nipper
Well.... The justy is a hedge against high gas prices (Blu gets 19 around town). Also since autoparts stores closed, its hard to get parts easily. So Blu doesnt get jelouse a 2nd car will make it easier to fix his EGR system and the heated seats that don't work. But i will send him your reguards. He is getting a roof basket in the spring that can hold an axe, shovel and spare tire. The Justy doesnt have AC (tempting to correct that) so Blu will still be used in the heat of summer locally. Blu didnt get jelouse of the bicycle so we should be good. :-p
Yes they control your AWD. Loose one and loose your awd, you should get a CEL. Loose two and you'll loose the spedo and AWD and have a CEL. You will also not be able to go faster then 50mph. The either work or dont so if you dont have any CEL or codes dont worry about them. they tend to be robust. Which leads to the next question, are you having AWD issues? nipper
You just answered your own question. You may have a failing tensioner or idler. You are playing with fire. There is a huge diffenrce between a timing belt job with all the parts and rebuilding your cylinder heads. It shows up under light load causing a miss or rough running. Skip the coil test for now, as either way you need a timing belt like yesterday. nipper
(Possibly Stupid) Questions about Adapter Plate
nipper replied to rxleone's topic in Subaru Retrofitting
Just one thing I wanted to point out, there are no stupid questions just stupid people -
Lest start out with two things. What is your alt output under this condition. Next does your brake booster have a vac leak. Thats the simple things. Next spray some water on the coil pack and check for sparklies. How old is the timing belt, and more importantly how old are the tensioners and idlers? nipper
Hell I can get parts from the worst dealer on Long Island (who is only 4 miles from my house) doesnt mean i trust him. Chainging the belt was premature, but thats water under the bridge. Find another shop before they really screw up your wallet. The rough running can be as simple as a vacume leak. How long has the car been doing this?
What are you adapting too? -
Lets take it one step at a time, since if you do have Torque bind, we can't do much about it now. The engine. When was the last time it had a full tuneup? How many miles on this car? Have you had the air filter replaced recently? When was the last time the timing belt was changed? You cant diagnose transmissions issues properly untill you get the engine running properly. nipper
