25
Everything posted by nipper
You do realize that hot water goes into the bottom of the radiator and cooler water comes out the top? And that cooler can seem downright cold depending upon the air temp going through that radiator. I'm with GD on this one, what is the problem? If it is cold enough outside, Blu's T-stat wont open up (but engine temp gauge is normal), but i will have plenty of heat. The heatercore is just a small radiator. nipper
no heat
nipper replied to derby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Clogged radiator? -
Tire Size dicontinued? What to use instead?
nipper replied to Deener's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can you drive down to the states and buy a set? nipper -
You asked about an interchange, not a rebuild. I have rebuilt them. I have stopped since sometimes costs more to rebuild them then what one can or is willing to buy one for. Why not call a subaru parts supplier and ask them? But since the voltage regulator is differnt I would say they may not be good matches. This is for a 2000 Legacy: Voltage regulator, legacy, 2.5l 00-04 $179.35 $129.13 Bearings, front, legacy 95-00 $20.68 $14.89 Rectifier, legacy 00-03 $115.51 $83.17 Bearings, rear, legacy 95-04 $38.92 $28.02 Brushes, legacy 00-04 $13.22 $9.5
Lets attack the stalling issue first. My 97 will do this starting issue on ocassion. I am 98% sure with Blu its a dying crank position sensor. There arent many things that will make a no start condition on a subaru (crank sensor engine coolant sensor). The stalling I would think may be a coolant temp sensor. These will not always throw codes. Since these are intermittent issues, throwing parts at these would not be a bad thing (as they arent terribily expensive used). nipper
bad svx trans
nipper replied to TN svx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WOW that must be a record, it sure as heck aint the original transmission. Cracked flex plate or not, the fact that it will move only at higher rpm means the tranny is fried. A common conversion is to change the tranny and rear diff with one from a legacy. nipper
