25
Everything posted by nipper
1- you can fit Hella's to that space where the fog lights are, do a search here as i think there are other posts on it. 2-Powerlocks usually just work. The first suspect to check is the switch itself. They are easy to rebuild and clean. next suspect would be where the wires pass through the door. 3-can be as simple as a corroded terminal in the fuse block 3a- one fan is the primary and one is on with the AC.
Thats actually alot of useful information. Check the main fuse block. Physically remove it and inspect for corrosion or a tired fuseable link. There are not many places on the car where you can loose the primary power feed and have a backfeed to the entire car. nipper PS check the main relay harness too.
Codes are a TOOL, not a diagnoses. Lets go back to car repair 101. The first step for weird starter motor issues is to rig a light from the starter solenoid (switch lead) and put that bulb where you can see it. Then you have to wait for it to fai to start. If the ligt comes on when you turn the key to start and there is no crank, the ignition switch is fine. Get yourself a haynes manual. Look up how to test the crank position sensor. There is zero reasons to replace the starter in a subaru, as a- you can inherit someone elses starter contatc issues (if it is used), b- subarus starters are rarely the problem. Have you checked the Neutral saftey switch (inhibitor) and the clutch pedal saftey switch?
I was wondering if the battery operated electric impacts are any good. nipper
About your friend, well, i'll be nice. All autopmatic transmissions when you drop the pan will have some metal shavings in them, so calm down and stop and think. The metal shavings are most likely from the clutch drum in the AWD unit, a common thing when the clutch pack fails. It gets replaced as part of the repair. Take the car to a dealership, as it costs about 900.00 to fix the AWD unit in one of these transmissions, which is about what it will cost you to replace the transmission with labor. Also the 2000's have an issue with an inner seal, causing a long delay in engagment from a stop, and from rev to drive. If yours does not have these problems, KEEP IT! Odds are the replacement will have this issue (could be the reason it ended up in scrap yard to begin with). Take it to subaru, get it fixed, get a warrenty, and save yourself money in the long run. nipper
20 mpg per gallon is a little low, but not tragic. Its sounds like you are only 2-3 mpg too low in local driving. Always do MPG mathmatically, not by the fuel gauge. 2.2 is due for a timing belt every 60,000 miles. When in doubt replace it. Yes it can cause a misfire code on all four cylinders. The carnk position sensor is used to determine spark timing, the cam is used to determine fule injection timing. If the engine thinks that these two sensors are out of synch it will throw multiple misfire codes, as well as cause you to have poor gas mileage. Replace your fuel filter. Replace your PCV valve. What brand wires, o2 Senosr and plugs did you use? nipper.
Not really, as there are seven solenoids in the transmission and acter the Duty C (most popular) is the Pressure solenoid and the TC solenoid that are the others to throw codes that one may not notice. I have seen a bad tranny temp sensor once in a while too. But as is asked here, we need the parking lot test. nipper
Its not a cross flow radiator? It doesnt matter when your removing your external cooler, but it does when you add it. You want to cool the fluid before it goes in the radiator, as it also helps to heat up the tranny fluid. Putting it in after the radiator can cause the tranny to take longer to warm up. nipper
yes its time for a full tuneup first. The flashing tranny light may or may not be related. Does the cra stall when it comes to a stop, or when you take your foot off the gas? The light is telling you on the previous car operation, there was an electrical fault in the transmission (a OBDII reader will not read this code). How does the car behave when you make a tight U-turn? nipper
So a little subaru 101. After your old girlfreind slashes all your tires, or maybe just one, ( if this is an AWD subaru) make sure all 4 tires always match, are equally qorn, properly inflated, and never drive on a flat tire. This will keep your AWD unit very happy. If this is 2wd, let her slash away hehehehe
Seek help for your drinking problems maybe ? Welcome to the site, is this your first subaru? nipper
Wooooooooooooooooooooooooooooooooo slow down. Why replace an entire transmission when the AWD problem can be fixed on its own. If you have a trouble free 2000 transmission, stick with it and just fix the AWD section. Using your logic, may as well replace the car because it has an oil leak Now what problems are you having with the AWD. nipper
