Everything posted by nipper
What the hell?
nipper replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI shopped optoimas. I chose a regular battery as they seemed to be longer rated. If you do any deep discharge stuff then an optima is best. Folks, he said he is in college, no reason to recomend a pricey battery when a regular battery which is easier on the wallet would perform equally well. nipper
What would make a transmission die like this?
nipper replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think 240,000 is a pretty good run for a manual tranny. If your not the original owner, poor maint, poor driving habits can cause this. nipper
car quit on me
nipper replied to s'ko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on this engine? Who rebuilt the engine? What was replaced at the front of the engine when it was rebuilt? nipper
Tranny work complete, noise in back end.
nipper replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNP. Sometimes noises need to get worse before they can accuratly be identified, and save you some money. nipper
nipper replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would wait it out. A rear diff can make noise for years and never really fail. I have seen diffs fail in less then 100k, you make enough of anything, eventually something will break early. Wait it out till it gets worse, so a better diagnoses can be made. nipper
low RMP shudder on Outback
nipper replied to bkvail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the rear tranny mount. This can be the source of low end rpm shudder. nipper
hood unlatches itself 97 Outback
nipper replied to bkvail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhite lithium grease (in a spray can) is your freind. Once a year you should hit all the hinge points with this, and the latches. nipper
nipper replied to cheetah8799's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX16,000 miles is a bit late to ask for any favors from subaru. Is this a LSD rear diff? Ever have an unmatched tire on that axle? How often did you have the rear diff serviced? When was the last time anyone checked the lube level? Get a used one, its much cheaper. nipper
97 legacy outback
nipper replied to beopots's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGive the car a tuneup, it will run better. nipper
Not a happy camper...new motor blues
nipper replied to SubiPilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had mine rebuilt by subaru. I paid more, but after watching all this, i feel i did the right thing. nipper
Head Gasket Blown: Advice w/ Options Please
nipper replied to nathanthepilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo just a legacy vs an outback. nipper
new clutch; pedal has a soft spring to it
nipper replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts not unusual for the Master and slave cylinder to go when or after the clutch is replaced. They do wear out, and sometimes traveling beyond thier normal stroke can tear the cups internally.
nipper replied to nathanthepilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only time i found a difference between the two is on hill climbing. The 2.5 takes less gas to go up a hill then a 2.2L. Otherwise i really didnt see a difference. MPG should be easier on the 2.2, but where i live with all the stop and go i never saw it. nipper
nipper replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEver notice how none of us are morning people? No one ever has an AM.
air/fuel sensor
nipper replied to NickRPS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny Check Engine lights on? Its a bit early for an O2 sensor to be bad, but not unheard of. How much did they quote you on it. How is your gas mileage? nipper
nipper replied to nathanthepilot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 20.00 question. Have you cooked the engine at any time during this discovery? If no you can rebuild the heads. If you have look at another engine. nipper
nipper replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you replace the throw out bearing clips with new ones? Does the car shift? nipper
air/fuel sensor
nipper replied to NickRPS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou dont know if you have an automatic or a stick?
P0106... It's back again
nipper replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy did you replace ALL those parts. You only change one thing at a time. If you have the original parts from the car, put them back on. Then change just the sensor and check for vac leaks, and make sure the electircal connector is good. Also computer codes are a tool, not the answer to all problems. you stil have to do diagnositics. nipper
Help! cruise or not to cruise!
nipper replied to chadwick35/04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX98% of the time it is a bad switch on the brake pedal and/or clutch pedal that needs adjusting. It may or may not be under warrenty, read your paperwork. nipper
air/fuel sensor
nipper replied to NickRPS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYear model transmission and mileage please. A?F sensor = O2 sensor. nipper
96 Impreza torque bind
nipper replied to marinemedic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust a general clarification for everyone. 13 flahses of the traany light on startup means that there was an electrical fault the last time the car was operated in the transmission. It does not automtaically mean that the Duty c is bad, but in your case, it is bad. There is a procedure for pulling tranny codes, so if you dont have TB and have the flashing tranny light it may be something else. nipper
09 Outback Question
nipper replied to XCR583's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this a pecv? (pcev?) nipper
Abs light is on
nipper replied to BRATDUDE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a search here on Antilock brakes and something should come up on how to read the codes. Why did you replace all those parts? Odds are a wheel sensor is eroded and giving a bad wheel speed reading or a broken tone ring. nipper
Ideas for the ultimate garage!
Heat would be nice. I had a freind that had a wood burning stove in his garage. nipper
