nipper
    25
Everything posted by nipper
  1. That used to be my response to, let em get a job like i did, but not these days. My nephew had been looking for months and can't find anything. His friend got one shift a week at mcdonalds (hardly makes it worth it). Locally here in downstate NY there really is nothing. Even whne stores do have signs in the windows, they are just collecting applications. I can't even find part time work myself.
  2. If i had photoshop skills i would make a 360 with a lit fuse, but since i don't look at this http://www.xs4all.nl/~mjs/subaruk.html
  3. An SVX is a typical trophy wife. It is beutiful. Your frineds will be envious. If you are lucky at times she will let you run your hand up and down her (gear) knob, but when she needs something, and she will, it will cost you. And yes i would want one
  4. Ya know ...... Then we can maybe give a Jeep a run for the money, and i would stop lusting after a wrangler limited. nipper
  5. Pulls to the right. That can mean so many things. How many feet forward on a properly flat road does it take to drift 3 feet to the right. There is a right drift aligned in cars, but it should not be noticable nor fatiguing. A good alignment shop (and there are less and less of them) can take into account the normal weightload of the passengers in the car (using weights) to adjust the alignment to your liking. Good alignment shops will use the mfg specs as a guide and tweak it to make the customer happy. I am going to assume that they checked tire pressures before they aligned the car or checked it. i have seen quite a few forget this detail. nipper
  6. That doesnt look like a crack to me, it looks more like an erosion path. As long as you keep in mind that the repair may not work and dont blame subaru, the planets, or karma, i would say go ahead and try to repair it. nipper
  7. Yay you have a great skillset. The only other caution I have is when you get the HG's from subaru, follow the torquing sequence someplace on www.endwrench.com in the archives under engine. They can be touchy. I too have worked on chevy. fords, AMC and mopars. Back when they were all so very forgiving. BTW check the seperator plate in back of the engine. If it is plastic replace it with a metal one. Also put in a new PCV valve. nipper
  8. I want to say yes, but i wouldnt rest my rep on it just yet. It seems that every premature HG failure seems to be the 2.5 in the outback. My theory (blind educated guess) is that the outback is a heavier car. the engine is taxed more due to the weight, higher drag, gearing (and the pull of mars). I know the 2.5 DOHC was designed at the very limit (at the time) for that engine. Maybe the smaller car took off just enough stress where it wasnt an issue anymore. I want to say it is a US vs Japanese thing, but i know Outbacks blew HG's in Germany and Austrailia, but odly in all my research I did not see any Imps doing it. I dont even know how many Imps were sold with 2.5's. If my theory is correct, then once you add the heavier car into the mix, they may also go bad. nipper
  9. Imps arent made in the USA so they don't seem to have HG issues. Subarus tend to get the epa rated mileage for most drivers (those that dont live where there is a stoop sign on every corner). www.cars101.com And yes the HG issues seemed to have gone away to some extenet. Some HG's i feel in 2005 were over zealous mechanics seeing oil leaks from other sources. nipper
  10. I googled "subaru 4eat gear ratios" and that was on the second page of search results. But now i must kill you since I gave away one of my secrets nipper
  11. GOOGLE actually i screwed up i was going to respond to the imprezza tranny swap thread, and i had too many windows open, and posted to the wrong window. my bad.
  12. http://www.ultimatesubaru.org/forum/showthread.php?p=595297 try that. nipper
  13. The SVX forum can be a little, er, um, bullheaded? But there are also SVX owners here too. nipper
  14. Yes that happens. Cars have to be moved and people just grabs keys to move them without checking. SO what you are saying is that it happened to them?
  15. Two general rules of themb for any heavy engine work. 1- Cleanliness is next to godleness, and begin clean working on an engine is akin to sitting on God's moms lap. 2- Unless the part is being replaced, everything goes back to where it came from, the only exception are the fasteners, though I know people who even tag the Major bolts and pu them back where they came from (nothing wrong with that). You can never be to anal retnetive when doing major work. At this point I would just dig into it, as I am satsified with the vac gauge test. Also if you did put the wrong lifter in the wrong spot, you may now need a valve job (which I would have done to begin with). nipper
  16. I'm sorry but everytime i hear nabisco and i think, what are subarus doing on a oreo board? And they are right. Go aftermarket for the filters or stick with the stated change intervals and keep those reciepts. nipper
  17. Poor valve seating if it does that all RPMS. If it does it just at idle leaking HG. nipper
  18. I should have said coolant temp sensor too. When its something that is dependent on climate, you really can't put pressure on him untill the weather cooperates. He cant find something that requires cool weather to fail when its warm out, as the fault will never show up. He doesnt have a drive in enviormental chamber to test in. In this case work with him, Make sure the complaint is noted someplace in documentation, and just wait till the cooler weather comes for it to act up. nipper
  19. These things can be annoying to diagnose, and in a way the dealer is correct. This has all the symptons of a had sensor or module. Which one, iw ould guess the crank sensor or cam sensor. Do you notice any black smoke when it happens out the tail pipe?
  20. I wonder this too. There are some things that MAY make the waterpump last 200K or more. Since it is a chain, there is less side force on the waterpump shaft then with a timing belt. The shaft end is in a happy place (getting sprayed with oil). Subaru uses a new high mileage coolant made for this pump. The new pump is very hardy in contruction, but only time will tell. It also depends upon what the life of the car is. 200,000 miles is a respectable mileage for ANY car part, period. I think anything past 160,000 is gravy (for non soobys). I did the math and the cost of replacing a sooby timing chain is the same as two timing belts, so thats a wash. The placement of the sooby waterpump is not in a horrible place, but it could have been much better. If you already have the cover off it is right there looking at you. http://endwrench.com/images/pdfs/Tribeca.pdf On page 11 its the little gear next to the crank. What joy three timing chains can be
  21. Replace the cap. What subarus can sometimes do is devlop a hairline crack in one of the tanks. They only leak under heat and pressure (like the car moving at 60mph with the AC on) so you will never really see a leak. What you need to do is clean the car up under the hood and under it, then get a dye test. Then you dirve the car for a while, and they expose the car to balck light to see where the leak is. nipper
