25
Everything posted by nipper
There have been two very common reasons for repeat HG failures of subarus. One is use of non-subaru HG's. the other is not refinishing the heads (or milling if you will). I would never do a customers car without sending it to a machine shop for cleaning up the surface at the very least. Thats water under the bridge now, what is done is done. Vacume gauges are really cheap, if you dont have a good compression gauge rent one. As long as it screws into the spark plug hole i'm happy with it. If the numbers are very high the timing is off. Do a dry/wet compression test. Do the vacume test first, as that may just answer our questions. good luck nipper
Hesitation
nipper replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Not trying to get rid of the codes, trying to restore performance (for now). Clearing out a clogged cat will do that. nipper -
Hesitation
Normally I would not agree, but since it is already broken, you cant make it worse (especially since they are getting replaced). nipper -
Go out to your car and turn the key normally. Do you hear things click if your not listening for them? It just becomes background noise, so you pay no attention to it. Now go out there and listen for everything that clicks (you may or may not hear them, but there is the main relay, a few others, maybe the fuel pump whiring, maybe not). If the failure is one in 100, or even one in 50, you wont hear the click all the time. I caught it only once out of many anoying failures, and even then it did not register as the starter, it just registered as one of the relays doing their things. nipper
And i now have a new desktop wallpaper. :banana:
I am not going to condem the HG without a compression test of some kind. I like felpro gaskets, I have used them to rebuild engines, but subaru HG should only come from subaru. Aftermarket may not have the lateste version of the HG, or may never even be close. I still say most likely your TB is off.
Hesitation
Any vacume line that you can trace back to the intake manifold is good. nipper -
Next to the lunar lander base nipper
Hesitation
Lets do this. Hit the cats with your hands when they are cold, do they rattle? Spend 19.00 on a engine vacume gauge. tell us exactly what it says and what it is doing. It is an under utilized tool that can tell you so much. http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm Where did the O2 snesors come from? How do you know the cats are good? -
What he said. It really is a lost art, but on a simple engine like this I say go for it. nipper
Hesitation
Are the cats clogged? Clogged cats can make any car a gutless wonder. What condition is the end of the spark plugs wires in? If the cats are failed your going to have a 420 untill the cats are replaced.
