25
Everything posted by nipper
It was a dark and stormy night... Actually a chilly and sunny day off roading. Going doena path which wasnt too bad at 20-mph left front wheel went over a washboard bunp-bump-bump-bump and lo the CEL did light. My inspection isnt due till next Dec so i wasnt excited. i checked with the scangauge and it was our freind 420. Front O2 OE sensor (i didnt put it in) has 40,000 on it, rear has 10,000 on it. Scangauge wont reset it. i was fiddling with it today, and noticed when i stepped on the gas it was in closed loop, when i let up, it would go to open loop. This is instant. SO this tells me its not the cat (230,000 on the cat, 40,000 on the engine). My thought. The front O2 sensor is physically damaged. It may be cracked and have an exhaust leak issue. The car is not loud, noisey etc etc. Gas mileage has dropped more then it should for this time of year. nipper
Its a little blowby, nothing to get too excited about. First thing to do is clean as much of it as you can, replace the PCV valve, and then keep track of your oil level. nipper
Get a name brand 5 year battery. Just go in to the store tell them what you got and what you need. Now what bothers me, is a bad battery can kill an altenaotr. If its an altenator i wouls recomend getting it from a dealer (look at 1st subaru for prices and see if they will match it) as it can be cheaper then the store. A car doesnt usually die while running because of a bad battery, but because of a bad alt. Not that it doesnt happen. nipper
Thats where i would go next, if it was my car, He can have a leaking fuel pressure regulator that takes extra long to build pressure back up. Lets do another Regulator test. Detach the vacumum hose from the regulator and watch the gauge. The fuel pressure should go up considerablly. If it doesnt go up check the vacuum to the regulator with a gauge. Leak down is normal, but your not complaining of a cold start issue which sounds like to me his regulator is lazy and taking a while to allow pressure to build back up. Another test would be to pinch off the return line and look for a quick rise in fuel pressure, as this would rule out the fuel pump. One other thing to look at, and i know its awfully cold to do this, is a compression test. I forget have plugs been changed on this car? nipper
From waht i understand there was a rules change, would require a dramatically re-engineered car, so i think they cut thier nose off in spite of thier face. Car companies just dont have the dollars to blow on this right now. nipper
How much disassembly is required
nipper replied to Uberoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And so it starts "here, hold my beer..............." hehehe nipper -
i'm curious, what condition is your fluid in? This is a relativly simple system, there is a VSS sensor in the tranny, one in the spedo head, the duty C solenoid, an internal spool vavlve, some clutches, and some input from the ECU. Maybe a vss sesnor flaked out on you. Putting the car in L will force a more aggresive AWD pattern. nipper
