25
Everything posted by nipper
Yes we need come clarification on what was replaced. The "center differential" is usually replaced for torque bind. I can't even think of the last time someone replaced those bearings if ever. It also is a silent death. There may be a clunk, but no whine. Now, a normal diff (front or rear) will whine as it slowly dies. The volume of the whine will increase with speed. Now If the bearings are bad, it will cause the drive pinon gear to go out of alignment. In a Diff the clearances and contact patches of the gear are critical. Now this could have been a problem long before you heard it to become aware of it. Without seeing the parts in question myself, I will side with the mechanic on this one, as the last thing he wants is an angry customer to have a double labor charge to replace a diff. Here is a pic of the inside of the diff As you can see alighnment of the pinion gear is very important.
It could, but we first need to get everything else at a normal baseline before we start pointing fingers. A bad MAP will not cause a tranny to slip.
- 22 replies
- 2
- check engine
- vacuum leak
(and 1 more)
Tagged with:
Actually over filling is bad. It can cause the fluid to get aireated. Hydraulic systems do not pump air well, It can cause slipping and other oddities.
- 22 replies
- 1
- check engine
- vacuum leak
(and 1 more)
Tagged with:
When driving in steep hilly areas, do not use D, use D3 to atke some stress off the transmission and maybe reduce shifting if the car cant seem to make up its mind what gear to be in (not unusual for a sooby). Change the fluid. Everything else everyone has said is sound advice so I wont repeat any of it as my typing sucks.
- 22 replies
- 1
- check engine
- vacuum leak
(and 1 more)
Tagged with:
That over-revving is the transmission slipping which is not a good thing, as that rarely gets better. Do you mean the tach or engine revs climb but the car doesnt pick up speed? When you buy a used car from someone just do everything like it has never been touched. Plugs are not too hard on this car. Filters are easy, and the pcv vale isnt too hard, thats a tuneup.
- 22 replies
- 2
- check engine
- vacuum leak
(and 1 more)
Tagged with:
May just be times for a new cable. If you decide to lubricate it, graphite lube but VERY VERY VERY LIRRLE, otherwise you will end up wearing it and fouling the spedo head.
What he said. Check your transmission fluid condition and level too and let su know how that is.
- 22 replies
- check engine
- vacuum leak
(and 1 more)
Tagged with:
Tires
nipper replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Now now now we don't want to start a discussion about religon, I will if this turns into the best tire thread -
Tires
Actually 79.00 a tire isnt really bad. Next set of tires for the Justy I am going to have to get escort rims so I can move up to 14's. I have to put off tires for a bit as the house and flood insurance went up -
I have a freind with an H6 and several H4's he says it is quite noticeable in the handling and he goes through a set of rotors a year. It isnt horrible, it just depends upon what your using it for. Also keep in mind that the weight of the engine is ahead of the wheels, so it doesnt take much to be noticable.
How the hell did this happen?
nipper replied to shoebee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am limited by the length of my driveway, otherwise i would have another Justy -
They followed you home, just dont tell her you towed them home -
2005 A/F Snsor
It is a fairly easy place to see it i will check after the next polar vortex breaks. -
2005 Outback 2.5L Limited. I am in a tight spot. Changing the steering rack somehow I managed to piss off the drivers side A/F sensor (Pre-cat O2 sensor to us normal people). I really do not have the money for the Subaru part at this time. Are the 2005's as pickey as my 97 was, or are there more options out there. I may even have to (gasp) get a used one. Luckily my inspection isnt untill next Dec, but that blinking criuise light is driving me insane.
I cant find my original post, so I will just put this here: Well it has been solved. Took the car (2005 Outback) to Firestone #1 they said the rear bolts were frozen and they would have use a torch, ruining the bushing etc, but "we do this all the time". I took the car home. Months later went to a friends heated garage to replace the rack and front end links. Took the car to Firestone #2, they gave it back to me aligned (!). I didnt ask what they did or how. Left rear camber -1.1 degrees, Toe 0.39 degrees Right r camber -0.3 Toe 0.35 Spec Camber 0.6--0.9 Toe -0.13-0.00 After Left rear Camber -0.9 Toe -0.06 Right r -0.2 Toe -0.11 The car is no longer terrifying. Yay.
