Everything posted by nipper
7 year sit
Tires wil be shot. There is a chance you may have wheel bearing issues, but soobie wheel bearings for those cars are so over designed. Rubber hoses may be an issue. Critter damage may be an issue. Try turning the engine by hand first to make sure it will spin. Squirt oil in all the cylinders and hand rotate. GAs will probably be icky, but strange things may happen (like ti fires right off). Frozen parking brake. At the very least change the oil first and a new fuel filter. nipper
Identify this car
Hint Smokey the bear would not be happy.
Surco safari roof rack post help for a Loyale wagon.
Let us know what it is like I like the looks of it. nipper
Identify this car
Been there done that with a 78 civic. Was interesting to hear the death wales of things popping. nipper
What is a good brand Timing Belt Tensioner for the EA82?
Rule of thumb, well two thumbs. First one is the more critical the part, the nmore important it is to be OE. Second thumb, if it lasted X number of miles, the OE replacement will last just as long if not longer. nipper
AWD to FWD fuse--top speed???
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat he said. I did the same thing and MAN what a differnce, and not for the better. People underestimate how that 10/90 through to /50/50 split makes a huge differnce. nipper
Stuck in Neutral..... any input is good
Depends upon how much they are asking. I'm going to assume since its a california car it doesnt have a rust issue. Are you prepared to buy a non running the car that may need an engine overhaul? nipper
Shifter issues are easy, they are just bushings. It is also possible the car is stuck in two gears at the same time, again a shifter issue. You cant tell anything till you get under the car and shift the tranny from there. nipper
Different Tires and AWD
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI rotate mine twice a year. Tire rotation has been around as long as there have been tires. nipper
brake pads sticking
nipper replied to popeye2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsually it just takes some drtiving around to break off all the rust. This is not an uncommon thing with disc brakes. This is also why you dont set the parking brake if your going to be away fopr a long peroid of time. It should go away. What airport? Was there an excessive amount of rain? nipper
Thats where i was heading. nipper
97 legacy outback overheating
nipper replied to scotte6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBAD! BAD! back away from the tools. Your timing is way off. Never Ever use marks on any belt. You always use the marks on the gears as per the mfg. Go to www.endwrench.com and look at the procedure. nipper
A question
nipper replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeave them alone. Just follow the procedures that subaru specifies when you first install the headgaskets. nipper
No crank sometimes '00obw AT - neutral safety switch?
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk so we confirmed your ignition switch is good. That leaves the (replaceable) starter contacts. They are cheap enough to just throw in the car and see if the problem goes away. nipper
Its going to neutral, 1st or reverse. Does the shifter feel like its moving anything, or does it just feel stuck (you cant move it into any gear). Forget about the transmission for now. nipper
Burnt valve reporting back
nipper replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the head resurfaced? nipper
not true. You can actually roll a car more then you would think with it stuck in gear. A few inches is possible, if you stop and think about gear ratios, all the play in the drivetrain, and how healthy the engine is. You still need to compress air in the engine in order to stop the car from rolling. nipper
Clear timing belt covers for Subaru?
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour close. It keeps anything with mass from getting caught in the belts and driving the belts off the pullies. Packed snow can do this, along with sticks and stones ... they arent just for bones anymore. nipper
any negatives with running 14" rims/tires on an outback?
nipper replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey may not fit. The outback has larger disc brakes. If they do fit, swap the spare tire also for her car. nipper
Get under the car and try the linkage dirtectly. Can be a problem with the shifter. Can you push the car? nipper
nipper replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey may be too brittle for real world driving. They may look cool, but the extra expense aint really worth it. nipper
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore like the only solution (aside from all 4 new). Professionally I really dont like it, but if your in a crunch for money and have no choice, you have no choice. nipper
How do I restore a foggy headlight?
nipper replied to dariusbd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere are kits. Also do a search here. lots of info nipper
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor the record, its not just subaru. Jag and volvo have the same warining, just to name a few. nipper
nipper replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXActually the new VDC systems dont have this problem. And they would need to use a steering angle sensor to let the car know its going straight as well. nipper
