nipper
Everything posted by nipper
  1. i have an AC license. Trust me ive thought of buying a machine and JUST doing recharges .. very exp machine, but they are amazing in what they do. nipper
  2. is this one viscous fan clutch and one electric clutch? i wonder if the viscous/thermostatic clutch is bad.... nipper
  3. Same thing your feeling now. It doesnt really matter weather its forward or reverse, this isnt a Auto where sometimes it helps. The Steering boot can be replaced. nipper
  4. It's a long shot. If your car is pinging (you cant always hear it) thats an uncontorlled explosion in the cylinder. This will make unwanted heat at the worng time and can result in a hotter running engine. Going to a higher grade of fuel slows down the flamefront (reduces ping) so the heat is managed as per design. Like i siad its a long shot. When was the last time the tranny was serviced? Does the temperiture rise change with the setting of the coldness of the ac? nipper
  5. Yes... Of course first make sure all the tires match and are properly inflated. nipper
  6. Are the condensor fins straight? HAve you tried a differnt grade of fuel? i'll admit im runing out of ideas... nipper
  7. When there are steering wheel controls, you can set it in motion. Thats pretty much the standard. nipper
  8. Easiest way is to pull a vaccum on the system. If you cant pull a vacum you have a leak. You can use N2 and a snifer, or Refridgernat and a sniffer. There is a mix of N2 and Refridgerant made for the purpose of leak testing. 90% of the time the vac alone will be good enough. You only need the others to trace a leak. A venturi vacume pump wont work. You need a real vac pump to pull down the vac and hold it. Some things you just have to pay a shop to do sometimes. nipper
  9. OK NOW your being difficult ..... Didi you say you had a differnt front bumper skin? I would pull that off and see what happens.
  10. Did you forget a vacum hose someplace? nipper
  11. Step one, remove wheel and inspect brake. Bet you need front brakes, and from the sounds of it possibly a stuck caliper or shot wheel bearing. nipper
  12. There is another post like this, hence my confusion... You need a radiator. nipper
  13. Also stick your head under the hood (with the car off) and make sure all the fan blades are accounted for. A broken blade can make a loud fan too. nipper
  14. Rotate the tires and see if the problem goes away. If it doesnt it can be: Wheel Bearing CV Joint Sticking Brake Caliper Bent Control Arm Wheel Alignment Bad Bushing nipper
  15. Like everything, there is an inside and an outside. The outside looked fine, but i bet the inside is clogged. The car is old enough for that to happen. nipper
  16. Sheesh, i thought my dashboard was getting busy nipper
  17. CHeck your voltages. If the voltage drops the temp gauge will read higher. i am a little confused here, exactly what are we calling "hot" on the temp gauge? nipper
  18. That didnt answer my question. Just because they spin doesnt mean they are working. Is there any play in the can shaft bushings? Do they spin freely by hand? Can you check how much amperage they are drawing? nipper
  19. its looking more and more like a bad radiator, but i know that rads for these things are expensive, so would rather have you inspect/replace everything else first. What voltage is your charging system putting out? What condition are your rad fan motors in? nipper
  20. Have you thrown gauges on the ACsystem to make sure its properly charged? nipper
  21. If the impeller is stamped and not cast, yes it is possible. The impeller wears away with time. nipper
  22. Auto Transmissions are usually held together with snap rings nipper
  23. Clutch assemblies are usually held together by a big snap ring. In your case i would replace the clutches. Since you damaged them with the switch. nipper
  24. Which leads to the question, when was the last time the cooling system was serviced anyway? nipper
