25
Everything posted by nipper
87 Subaru Gl Wagon won't start...
nipper replied to hummer1331's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Back to basics. Fuel, air, spark. For now we assume air is supplied:-p Do you have spark? Do you have fuel flow? nipper -
that means it should be around the slow blow fuse #4 in the man fuse box under the hood Before the fuse is the alt/battery junction, after it is the ignition switch. Next time it happens, notice if your dome lights work. Also just removing and putting the fuses back in is sometimes enough to clean any corroded connectors. nipper
and check the frame grounds. I had a weird charging problem that was fixed with a new battery to engine ground. Also look at the main relay and the fuel pump relay coil. It can be one of those have a loose connector or a dying coil. DO you have a total loss of all things electrical, or just some systems. nipper
There is always one ..... and this time its me. i am not thrilled with them. For some reason i am not getting full contact at the very upper tip of the passenger side. The last snow storm we had the upper drivers side tip kept icing up, which required the constant slapping of the blade. If the last long, maybe ill replace my wiper arms and see if that fixes the problem. Or does someone know where i can get wiper arm springs ? nipper
i was giving the readers digest version (i have fully explained it many many many many times). Sometiems i get tired of repeating myself ... and getting for critisizing the switches. Actually it fully energizes the solenoid. This dumps all the pressure, so there is zero torque applied to the rear wheels. The switch to the C solenoid does the opposit, which puts the car in full unmodulated 50/50 lockup. so this time you can be the target :-p (that and im sick with an apendix that can't make up its mind what it wants to do) nipper
Converting my Loyale Wagon to Electric?
nipper replied to Davalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
now THAT i like, thats why i would like to do a justy oh hell just give me a justy nipper -
http://www.txdps.state.tx.us/vi/Misc/faq/ready_not.htm http://www.epa.state.oh.us/dapc/echeck/testing_info/obd_faq.html#notready Are a couple of explinations of not ready. Seems like Subaru does not have a "not ready" issue. Everytime i reset using scantool it seems to become ready rather quickly. I would like to know which one has a "few weeks" to be ready. First thing that came into my head was ford ... but i am probably wrong. nipper
I dont think the really lift the cars, its just the weight of the car hanging upside down that makes them look lifted.... mmmmmmmmmm good pain pills pretty colors :-p hehehehe nipper
Sounds like you have a clogged catalytic converter/exhaust system. There is a simple test for the cat, which you neighbors wont like you. Dissconnect the exhaust system. Start the car and try your rev test. If the negine will freely rev past 4K, then you know its an exhaust isuue. Next discconect the muffler and repeat. Usually a muffler just falls apart, but sometimes they clog. Sometiems an exhaust pipe can internally collpase. nipper
look at jc whitney as they use wagner pipes. ALso go to the corner autoparts store, you may be nicely surprised. SUbaru Genuine parts list a muffler at 51.00 (give jamie a call) nipper
Replace the o2 sensor if your getting a failed cat code. 99% of the time a poor cat performance code is the front o2 sensor. What it says is that if you come in for inspection and the CEL is on, you automatically are rejected for testing ( do not pass go do not enter the shop). Not ready means that there is a communication or other OBDII issue (like sensors missing) your automatically rejected. 1996 Subaru and chrysler products listed can be inspected if the CEL is on, due to the CEL coming on for other reasons not related to emissions. For instance, a bad VSS sensor will illuminate the CEL, but isnt a failed emission part. So replace the front o2 sensor. The fact that you have been passing emissions tells me your cat is fine, but the o2 sensor is whacked. nipper
me talk funny, or is that spell funny (pain pills and poor typing not a good mix). I have heard differnt opinions on flipping the differential. It really depends on the use of the vehical. As a toy it is probably fine, but it tends to change the thrust surfaces location. Now your giving me ideas on my awd corvair project, bad bad bad nipper
