Everything posted by nipper
Daughter wants a Legacy sedan
nipper replied to toni1595's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEmpty fuse holder is good. Thats the FWD fuse. You use a spare fuse in that slot when you have to run on the spare tire. The fact that its not there means the AWD is working. The bill states that the AWD unit was at the least serviced, if not rebuilt (If the bill is around 800.00 it was rebuilt). Make sure the tires all match Next do figure 8's with the car. The car should make this manuver with no throttle or very little htrottle applied. If it does this in a smooth motion then its fine. Only other thing is to see when the timing belt was changed, otherwise it sounds fine. nipper
Knocks & Pings....
nipper replied to calazo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust out of curisosity, when exactly this start happening. When was the timing belt last changed. Check the knock sensor. Change the fuel filter, and invest in a tank of preimum name brand fuel and tell us what happens. nipper
Changed ATF, still no AWD now what?
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell he didnt do something right, as i have never heard of anyone getting it fixed and it not working. He did something wrong, and you need to have him fix it (since he admited he goofed up) or get another opinion. nipper
Should head lights stay on ???
nipper replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtsktsktsk and you call yourself a subaru fanatic.... for shame *giggle* yes and yes nipper
Subaru Parts Online
nipper replied to usaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttps://www.subarugenuineparts.com/oe_parts_cat.html Jamie Rocks nipper Just because the part isnt listed on the site, doesnt mean Jamie doesnt have it. I have gotten many parts that arent listed on the site from Jamie.
WRX STI Factory Gauges
Does anyone have the instruction sheet from H5010FE056 OE Gauge kit http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=013&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=230096944996&rd=1,1 I need a copy of the instruction sheet. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot everything can be fixed by a magical can, especially if you like the rest of your transmission. There has been some succes with a conditioner when people have torquebind, which you dont have. You have AWD clutches that are shot and need to be replaced. nipper
Forester Diesel?
nipper replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell they arent popular here for two reasons. GM did a really good job on ruinung the reputation of diesels. Secondly our emission standards wont let them in, but thats about to change. nipper
nipper replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is no tranny fix stuff for this. nipper
"Tick of Death" or Rod Knock?
Actually a vaccum gauge is one of the best tools to find engine problems that a compression test wont pick up, and its really easy to read. I dont see how its easy to misread. http://www.fordf150.net/howto/diagnoseengine.php nipper
What does it take to get a Subie with Blizzaks stuck?
An avalanch? nipper
Too much oil?
nipper replied to mtbe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo much oil ins a subaru can be catastrophic. I do agree its tough to read the dipstick on a subaru, so triple check. Unlike a V engine or a std engine, the pistons are on their sides. Over filling (could) get the oil up into the cylinders behind pistons. You wont have hydraulic lock (that would be too easy, as the starter motor cant bend anything). What can happen is the oil foams and gets airated. The oil pump cant pump air. Oil with bubbles in the oil can't lubricate. The carankshaft jounrals can throw the oil around and airate it. nipper
Chirp / squeal then DEAD - 97 OBW
nipper replied to JohnVT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell if your talking about what i think your talking about.. The tabs that are at irregular spaces apart form each other? Very important. The car wont run without them. They make the signal for the crankshaft position sensor. Otherwise i am not sure what you mean. nipper
nipper replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes there is a proper switch for draining the batteries nipper
nipper replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have an owners manual? if not try to get a hold of one, to explaine all the other goodies on the car. nipper
Where can I find some snow around here....
Your just a very greedy person and refuse to share with us east coast people :-p nipper
Autoblog reports Subaru more focused on USA
nipper replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are loosing their quirckyness, which is what drew people to them. They need another small car, a little more zip, and stop falling into the "camry" cookie cutter cold. nipper
Catalytic Converter Rear Flange - 99 OWB
nipper replied to 99obw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen the cat pipes have been welded in the past, they dont seem to hold up. But maybe you can go to a junkyard and cut off the flange, then match it up to yours and weld it on. nipper
Our Legaback and a Jeep Grand Cherokee ... head-to-head. Both lose.
nipper replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm very happy the other half is doing well. Been there done that with the broken sternum. It's amazing how tough cars really are. Remind me to tell you my 1979 civic crash story some time (hence the broken sternum). It involves a car witha nun as a drivers ed instructer ..... nipper
EJ22 N/A Compression Check...
nipper replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know thats why i pointed it out. Hayens is a good book, dont know why you dislike it so much, but each thier own. I am still trying to find a FSM for blu with no luck, and i hate those cd versions. nipper
2.2 motor "stumbles" under load 2-2500 RPM
nipper replied to rallynutdon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhrmmm are the intakes differnt on the two engines? Can the car be starving for air in a specific rpm band? Why did you swap intakes? nipper
Cost of Timing Belt replacement
nipper replied to nveilleux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can reuse the tensioner, but why take the risk (see other p[osts on tensioners going bad). When i had it done on my legacy it was 600 - 650.00 ( i also needed a harmonic balancer) . That was basically replacing everything under the front covers, money well spent for another 106,000 miles of peace and quiet. You may want to by the tensioner yourself on https://www.subarugenuineparts.com/oe_parts_cat.html To save some bucks. nipper
2000 OBW Stealth Sub Enclosure?
nipper replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to ask a stupid question. Is there clearance with the sub for a full size spare tire? nipper
need a new cat...recomendations?
nipper replied to skizix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy front sensor is 6-8 months old, so i wont change that. My front threw the ocassional code, then got worse with time, so i included it as part of a major tune-up. nipper
95 legacy L... need help/advice
nipper replied to lilears4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found this on ABS http://www.endwrench.com/pdf/brakes/FtSubaruABSS99.pdf nipper
