Everything posted by mudduck
Overheating and no heat issues... please help!
mudduck replied to emarsh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't think that leaking radiator is helping. -
What should I expect if when these things let loose? Fan in the radiator?
Put transmission in by your loansome...
mudduck replied to Uberoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A whole lot of wrestling that thing around and a whole bunch of swearing, and about a pack of smokes. Thats what it took to get a NP435 and 205 transfer case into a 77 f-150 whaen I had to do the clutch in that thing years ago. -
I have the same problem. A piece of black tape over the light fixed it right up.
Yes, the wheels fit because of the worn pads.
A red x
ej cars=new generation. ea cars=old gen
Rust-Free PNW cars- The End is Nigh!
mudduck replied to The Beast I Drive's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA82 cars are self oiling. Atleast around the front. For the rest, used moter oil sprayed into every place underneath works. -
Mag cloride is some nasty stuff! I had put new chrome wheels on my old Toyota 4x4 out there, and within 2 weeks they started to rust. Ate the bed of that old yota all up also. Same with my Loyale. Front fenders are all ate up from mag choride. The under side of that car is in good condition though, from spraying oil on everything on the underside. Did the same on that old yoda to keep the frame from rusting. -
newbie from Greensboro n.c.
mudduck replied to Animal_Gso's topic in Meet n' Greet. Your USMB Welcome Center
Hello from down here in Asheboro. Nice to see another local on the board. -
Oil filters-would bigger be better?
mudduck replied to Kwhistle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just don't run FRAM filters and you'll be alright. -
Thats how I fixed mine! Matches so well, you can hardly tell that theres any black tape at all. Works great!
Grease up your linkages, and replace the throttle cable.
Wow, another from NC! Welcome.
How many miles on your subaru?
mudduck replied to dughrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
289,xxx on my 91 loyale. -
Hooray for open timing covers, but...
mudduck replied to mudduck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, checked everything out, everything seems good. I guess the belt stretched just enough to come off. I had a tire go down on my earlier in the week also, for some unknown reason, nothing in it, no leaks at all. I had also just topped off the tank then also. Maybe I should just fill the tank to 3/4's from now on. -
Disconnecting Front Handbrake
mudduck replied to rxleone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Having the handbeake on the front is great. If the regular system fails, you can always stop the car with the handbrake fairly easily. -
Stopped in at a friends house tonight, and when I went to leave the driver side timing belt came off. Didn't break, just was so loose that it was doing nothing. So I put it back on, and all seems good. But, what has me scratching my head is what could have even caused this? The tentioner seems fine, and everything looked ok yesterday when I was poking around. I had just filled her up with gas, so maybe it was just messin with me.
Put a piece of black tape over the light. Thats how I fixed mine.
