Everything posted by mudduck
Newbie fixing unknown problems...
Have you checked all the fuses under the dash? I can't remember which one it isc number 5 i think it is, that will cause the symptoms your describing.
Finally got a couple more 6 lug wheels drilled out so I now have a spare tire again.
How To Keep Engine Cooler? Any Ideas?
Get your radiator cleaned out by a reputable radiator shop or replace it. Flush out your heater core. I like to fill it up with CLR and let sit for 15minutes or so and back flush, and repeat a few more times.A clogged heater core will give you overheating issues. Replace the t stat with one from the dealer only. Make sure water pump is flowing properly. And make sure you have a shroud around the clutch fan. Go through all this, and your car should run cool. The cooling systems on these cars are the weak link, and any issues turn bigger real quick if let go for too long. I have single row radiators in both my cars, My 91 runs cool on the hottest days with the ac, and my 89 runs cool runnin all day on the trail in the heat here.
Sway bar extensions and disconnects
just remove it. You won't miss it
Fram High Milage oil filter
Stay away from the fram filters. Cut one open and youl see why. I run purolator filters, they are cheap, and are of much better quality than the frams.
Electrical Glitch
Yep, had one do this to me before, alt getting way hotter that it should be, Replace it with a known good one.
Power Steering Bracket
About like anything else on the motor. Snug, but not super crazy godzilla tight. Never had any issues.
- 2" lift = shredded CV's -Whats the solution?
Difficult to change gears - can't "find" the gear
The bushings in the linkage are probably shot. Had the same issue in my 89, only things would hit the driveshaft. Replaced all the bushings but one, on that one I used a piece of hose as a bushing. Its still sloppy, but at least it isn't hitting the driveshaft, which is good enough for that car
'98 Outback Radio compatible with 92 Loyale?
Yeah, most any thing is gonna stick out. The outback stereo doesn't look the best in there, but I couldn't beat the great price of free. Well, actually I did buy some super cheap speakers to toss in the doors.
You can make it work. I have an outback stereo in my 89. you need to use the outback wireing and the EA82 wiring and make one harness out of them. Yes it does stick out of the dash about an inch and a half, and makes use of the ashtray a little tougher, but it works.
Yeah, I like the black on that car. Was wanting to do this on my wheeler, And it's about the same color. My hatch needs to be painted anyway, as its white and the rest of the car is red.
- 4wd and engine bay smoke
Best Way to Scrap After Removing the Drivetrain
I did one backi in the fall. We flipped it over on the roof to get what was left under it off, than slid it up on a small trailer on its roof, and hauled it upside down.
EA82 Removing Cam Tower
I have the inexpensive harbor freight stand. You have to get a little creative to make it wirk. I can take a pic of how mine is set up, I actually have a ea82 on it as I type this.
The engine stand works great, as you can turn the motor sideways. I havealways used anarobic saeler on the cam cases
Front struts 86 GL
I don't belive that a "quick strut" is available for the subarus. Your best bet is to rent a spring compressor, and compress the spring to remove it from the old strut and install on new strut.
TOW ? 4x4 xt-4 driveshaft back half removed ?
Yes! This will work, and is only 8 bolts. My 89 didn't have the rear part of the driveshaft and drove just fine.
Pull out the rear axles instead of the drive shaft. You can move it all you want that way, not lose any oil from the trans, and just the rear wheels will spin when towing it.
ea82 cooling system confusion
Sounds like what mines was doing. Pushing coolant out of the system. And coolant smells of exhaust bad. If your gonna fix it, do it right and replace the head gaskets, don't dump head gasket in a bottle crap in there.
Free wrx or $400 sti suspension for my 90?
mudduck replied to Hinano's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can't beat free.
GL won't start after girlfriend added too much oil...
No.
Lifters will not come out of ea82 head!
And they are out!! Thank you all for the ideas! I heated the head up with a heat gun, used duster with the can turned upside down to freeze the lifter, and griped it with vicegrips, and gave them a few good whacks with the hammer and the finally came out! No damage to lifters, and no damage to the head! Woohoo
