montana tom
12
Everything posted by montana tom
It's walmart... with minimum wage workers... I'm sorry but you get what you pay for. Very likely the tech did the damage... oh well.... They won't admit it... Its just a wheel stud ... knock it out yourself and change it. If you let the walmart boys pull that hub to change a stud your in for way bigger issues than a buggered stud.
Smack it out with a hammer, Place new stud in hole .... tap in as best you can ... place larger nut over stud from wheel side anti sieze stud,spin on lug nut snug to larger nut ... big ratchet and draw stud into place. The final draw down happens after you install the tire and rim . Use large tool to make sure stud is seated ... don't forget to back it off and re-torgue studs when done.
I'm thinking a torch is definitely last resort. Imagine the fire you would create... industrial heat gun is much safer... Large hammer & lg screw driver would take it out. Make a heck of a mess as well. Call a private shop not a dealer ship . If no shop around then visit the dealer in person and go around to the shop doors and ask a real person....who might have a clue. The nice lady up front wants you to get rid of that old spoob and BUY NEW !!! The american way ! You know 30,000 in debt for 5-7 years... or continue to fix your old car .... your choice...
John; I know you said it was tight area ... but can you get a hammer / chisel on it ? Up at the top??? (I doubt it) Your heat gun idea may work. Old plastic does break or melt , make sure that a replacement part is quickly available before you get violent with it. When you do get it off make sure you use anti seize on the threads and seat. Have you talked to a VW shop ? I'm sure they have had this issue (why are they using cartridge rather than a spin on in 2018 !!!) They may tell you to break it and just replace it ????
The 642 is the one for everything . The 770 is overkill unless its a turbo.
- 12 replies
- head gaskets
- 2003 outback
(and 2 more)
Tagged with:
When I get out of the woods to the BIG city's of Missoula & Spokane I can see dozens of baja's any day. They definitely are less numerous than outbacks but there is no shortage in the N.W. I'm sure you can find a rust free body out here, of course it most likely will have deer damage on a fender... cracked windshield , paint shot , but it will have great tires and run all day at 80 mph , dodging deer of course...
Throw away that chilton's manual, they cause more grief than help . Move the crank as Tex instructed. The keyway should be down when lines on top are even . Drivers side cam is under tension when properly lined up ... it will stay at just where it needs to be, with notch in plastic housing lining up with mark on cam gear. Pass. side cam is free floating when lined up with the crack in the case. When all three hash marks are lined up, leave the top pass side idler loose to help install belt. Now attempt to feed the belt on . Books say go counterclockwise I always go clockwise! start at the crank pay absolutely no attention to the silly lines printed on the belt, proceed under the tensioner and around the drivers side cam gear follow around water pump idlers pass side cam gear and finally slip it under the loosened idler (don't forget to tighten it up) If all timing marks line up then books say to pull the pin ... I say hand roll the motor over 2 revolutions until marks come back in line ... IF all three still are perfectly in line THEN pull the tensioner pin and hand rotate 2 more revolutions , Marks should all three still be perfect if so finish your installation if they are off AT ALL START OVER ! (EDIT) Didn't realize this is a ej25 D motor
Don't bother testing a used one ... install it . Get several , chances are if this is your problem one of the wrecking yard ones will change it. I wouldn't buy a new one until I was sure this is really the issue. After you confirm, then worry about a new one. I see prices on them from 60- 80 bucks as long as its not calf. emission.... those are 180-280 bucks go figure ... EDIT) By the way , 165,000 is barely broken in..... mine has 298,000 would drive it to key west today ! Well maybe wait till January....
That's a tough one. How long has it been going on ? Did you all the current work hoping to clear the stutter up ? Yes, a bad map sensor can cause a hesitation, Low manifold pressure makes the ecu think the engine is not under load so it cuts the amount of fuel, causing a stutter or hesitation, this also makes for great fuel economy . New map sensor runs 60-80 bucks or more , grab one from a wrecking yard or borrow one from a good running car and try.
Get all the air filter piping out of your way. There is only 8 bolts holding down the intake manifold. A handfull of electrical connectors (they only snap in to one place you can't mess it up. If you have one, the EGR pipe should come off. two 3/8" water lines going to the throttle body. Not like an old chevy ... no water transfers from the intake manifold to the head, uses a separate water manifold underneath the intake manifold. So no water needs to be drained from the engine. (two 3/8 lines may need a clamp IF they leak much) The air conditioning compressor will give you a few finger pinches but the manifold will clear and lift rite off. Oh the power steering pump may need to be unbolted from the block and laid off the side of the fender. May not on your year.... on the earlier ones they had lines bolted to the top of the manifold. Some things like the fuel lines may be able to stay connected and just roll the manifold upside down to look inside. This job looks daunting when you open the hood, its not . Take photos , count how many electrical connectors you disconnect and make sure to reconnect the same amount. Your other option like GD said if..... it makes it down in the cylinder its gone... poof . danger is if it hangs up before the valves and disrupts the fuel flow to one or more cylinders. Your car will run like crap and you will be pulling an intake. Good luck it won't be that bad (EDIT) Just looked at the "instructions" you posted.... those things would confuse me. Don't over think it worrying about it just dig in and do it
