Everything posted by TheSubaruJunkie
Flutter under boost
TheSubaruJunkie replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok yeah, i'll do that tonight when i get home. I havent had much time to fine tune the motor since ive got it running. I'll spend some time on it tonight after work. -Brian -
Northern Nevada Meet 4/1/06
TheSubaruJunkie replied to Jibs's topic in Meet n' Greet. Your USMB Welcome Center
Awesome, i'll have to make sure to check it when its light outside -Brian -
Flutter under boost
Naw, i havent done that just yet. I was going to mess with the connectors tomorrow as my CEL has been on since i got the car running. But, after I adjusted the timing today the CEL has gone out. I'll probably pull codes tomorrow. -Brian -
Dinner sounds good. Hows the weather been up there lately? -Brian -
Flutter under boost
Well the wierdest thing. The other day after I dropped the motor in, i checked the timing and it was at 10 degree's. I took it on a few test runs and checked again when i got done, and it showed to be at 22 degree's. So I took it down to about 20 degree's and have left it since. Drove it to work for the 1st time yesterday and today. Noticed in the morning if I feather the throttle it runs fine, if i gass it at all (boost or no) i get flutter and the car just doesnt pull like it should. Tonight I got home and I checked it and the timing said it was at 10 degree's So i bumped it up to 20 and took it for a test run. No more hesitation. Also no flutter and the pull I Was looking for is back. I really need to get my intercooler on there. -Brian -
WHenever i hit boost, instead of accelerating i hear a bunch of flutter comming from my motor. The boost gauge stays solid at 5psi... engine hesitates but doesnt really accelerate like theres 5lbs of boost. I checked for leaks when i got home but found none. Could it be bad timing? -Brian
Should we change the topic so it reflects 4/2? I'll be working saturday, but I get Sunday and Monday off. I think im going to try to head up saturday after work that way I can wake up bright and early at Jibs and just drive to the meet, instead of spending 2hrs driving to the meet at the buttcrack of dawn -Brian -
I flushed my radiator by removing it and running water through it for a while. Wasnt nothing as extreme as NV's suggestion, but it helped my brat alittle. I tried the prestone stuff but it didnt work too well. I suggest doing it on a hot day -Brian
Its Aliiiiiiiiiive!!
Oh yes buddy! Thats already in the works. Probably wont be in stockton, trying to find an good meeting point for everybody since I will have some people from Chico comming and maybe even further north. -Brian -
I went and put all the PCV stuff back together. Its not stock, but it should work. Im getting some hesitation under Wide Open Throttle, i checked the timing and it was at 22 degree's. I adjusted it to 20 degree's, but the engine was still cold and i didnt mess with the test connectors for the ECU. The car idles GREAT. I dont think this car has ran this good since i owned it. Now it'll start right up, and hold idle at 950rpm. I can rev it and the throttle responce is quick with no lag and once i let off the throttle quickly drops to 950 and there it stays. My CEL is on, but right now I dont really care. Ive put the hood back on, and that signify's the end of its ressurection. Now im going to try not to kill it again -Brian -
Highly modifed 1982 Hatch up for grabs!
TheSubaruJunkie replied to Sweet82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That would be badass hanging up in the garage. Would make your 2 car feel like a 3car -Brian -
I noticed that on the test drive yesterday miles. I was able to pass some lady without needing to downshift I think im going to put the wastegate back in stock form, and see if that doesnt smooth out the boost alittle. Also, I checked the timing and it showed to be at 10 degree's I dont think that can be bad, but im going to set it closer to 20 and see if that helps. Im sure it will. Oh... and the only thing I run is premium. RIght now my intercooler isn't plumbed, so its running with a stock plentum and no bypass valve. -Brian -
Yeah, it cant be too hard to pull... its only an intercooler. And for the record, ive never broken anything at the junkyard that i didnt HAVE to break. Again, my original post was a joke, but i guess humor doesnt portray itself well over the internet. The junkyards I goto dont "haggle" its either, buy it or put it in a bin over there and we'll dispose of it. Its also not a mom & pop operation, Pick-n-pull is a nationwide franchise... i pay $2 to enter the place wether I buy anything or not. So most the time, I pay $2 for a pocket of lug nuts or 10mm bolts (can never run out of those). -Brian
Wow guys... cry me a river. ITS A FREAKING JUNKYARD!! NOT WALMART! I dont know if the junkyard here are the same as yours, but the cars we have in our junkyard are... well... JUNK! This isnt a carlot full of new model showcars, the cars I pull parts off of have been rolled, burned, hit from the front, hit from the rear, t-boned. My initial post was actually a joke, but since you guys like to hug and kiss your parts cars i guess i should have thought twice. I guess i wont mention all the parts I pocket. -Brian
I didnt, but ive seen where they're located in the saabs. If you are going to the junkyard, bring a prybar and a couple screwdrivers. A utility knife may help too. Break everything surrounding the intercooler, but leave the intercooler in tact. Cut anything that maybe holding the intercooler to the car and then use a prybar to bend anything that maybe in the way. Then carefully extract the intercooler It shouldnt be too hard, an adjustable wrench or a socket set may help. The turbo hoses are most likely connected to the intercooler with hoseclamps so bring both screwdrivers with you. Oh and by the way, you'll find the Intercooler located on the passenger side of the engine, near the fender. -Brian
GL Boost, no I installed a N/A Block in my EA82T after i blew up the original motor. Motor blew up the weekend before thanksgiving, and ive been in the process of putting everything from my stock block onto a stock MPFI Block from a XT. Just got back from its 1st, 2nd and 3rd official test runs. All i can say is WOW!!! Im in love all over again Car runs great, plugged some of the left over hose fittings and PCV ports that i didnt use and now it holds a steady idle at 950rpm. I can race it all day long, and if i drop the throttle it goes to 950 and stays there, no bouncing around or eloping. Boost is kinda wierd. Maybe its cause i messed with my wastegate, but it likes to spike at 5psi and hold somewhere around 3psi. Could be my gauge out of calibration so maybe its higher, but if I gun it i can get it to stay at 5psi and the motor doesnt seem to care. Only while WOT in 5th gear do I get some hesitation. I think once i re-install my intercooler that problem should be solved. Yes Jeremy, at this rate i have no excuse not to make it to reno next weekend Cant wait either. -Brian -
!WOOT! Finally got a chance to crank the engine over today. I spent all day yesterday mounting the intake manifold and connecting/replacing all the hoses involved with PCV and fuel. I also went and bought a new battery along with a couple other odds and ends. Today I woke up and installed the radiator, oil filter and alternator. Filled it with oil and water. I performed a compression test before I put the plugs in and everything checked out okay. So in went the plugs, and then it was only a matter of figuring out which plug wires went where. I just got that figured out, installed the wires and decided it was now or never. Tried to fire it up without a MAF or any intake plumbing but it would only crank. I couldnt get it to run so I decided i would install the maf and all that... then try. After I put the stock intake plentum on, i looked over and there I saw the coil wire laying on the hood. So I installed the coil wire to the disty and went to try again. The motor didnt even make 2 full revolutions before it fired up. And i mean, it fired right up! Better than before.... but the idle likes to climb up to 3000 or so. I guess all i have left to do is button up the PCV system and take her for a test drive -Brian
I gotta put the plug wires back on the RX and see if it will fire up. But the Service Manual i have doesnt have the firing order in it. And the HTKYSA lists EA81's, but doesnt specify if EA82 is the same. I have this graphic I made up a while back for the EA81: Would it be the same for the EA82... just the disty in the back instead of the front? -Brian
Installing an N/A XT MPFI engine into an RX
TheSubaruJunkie replied to TROGDOR!'s topic in Subaru Retrofitting
i havent done this conversion, but i did remove that boost solenoid. Just leave it unplumbed, it wont effect the engine in any way... it just delays pressure to the wastegate under certain conditions. No harm in leaving it unplugged. -Brian -
So close I can taste it!
Today I got the intake manifold bolted on. Was able to get all the hoses connected and wiring done. Also put together the bracket for the alterantor. Tomorrow i'll fill the motor with oil, do the intake plumbing and install the Alternator & Radiator. Newest Pix Here are some other pix. http://gallery.usmb.net/album46 Hopefully tomorrow I'll have her running again -Brian -
Save all the hassle and just get a mechanical water temp gauge. Thats the next thing on my list after the RX is running again, all mechanical gauges. I cant risk depending on 20yr old subaru gauges, ive had to many fail or read faulty on me. Those wagon wheels would be sweet with a set of: Mounted to them. Perfect for dirty rally or trips to the snow. -Brian
