TheSubaruJunkie
Everything posted by TheSubaruJunkie
  1. I dunno... are we? Jeremy... i didnt know you were working on a legacy. This upcomming weekend Im gonna be traveling to Reno so maybe when we're done with Jibs I can lend a hand. Russ... do you have an address for Mt.Hamilton? The Park that we met at the Impreza meet was a nice little place, and the observatory at the top was neat as well. I think that would be a cool place to have a mini-meet. 1st weekend of May would put us at May 5th & 6th. Shall we agree on that then? Which is better, saturday or sunday? Im thinking Sunday shouldnt be as packed as Saturday... but maybe the observatory closes early? -Brian
  2. Set your parking brake and you can remove the CV w/out messing with your rotors or caliper. Kinda tricky, but it can be done... and once mastered can cut your CV swap time in half. You will need to remove the lower ball joint from the lower control arm... you should also remove the ball joint from the steering rack, but sometimes you can just rotate the steering wheel all the way toward the CV you are replacing and that will give you enough room to slide the CV off the tranny stub. Once the CV is off the tranny, just slide the shaft out of the bearing and hub assembly. That is, of course, if the CV wants to slide out. Ive done some CV's where i had to beat the snot out of the shaft to get it out of the hub. Usually in that case, the bearing comes out with it and you will then need to replace whichever (or i suggest both) bearings. Ive also done some CV joints where they just slide right out of the hub with barely a tap. Those are the ones I preffer to do :-p -Brian
  3. Yeah, we have a site up right now with brochures. http://usmb.net/gallery/Brochures We can work on putting those new brochures up if you want. I wonder if there's any aftermarket rims for Isuzu Geminett's -Brian
  4. your idle problem sounds like a vacuum leak. Should be a pretty big one since it fails to idle when its warm. Use a can of carb cleaner and spray it around the motor to help find the leak. -Brian
  5. More space for PM's. More space for photo's. And a nifty little badge under your name. -Brian
  6. I really liked the little mexican joint that setup at last years WCSS. -Brian
  7. JB. The moonrocks are there 365 days of the year, and how many events do they throw there? The WCSS is only once a year. I put in for my vacation time today. Got August 22nd till the 29th off. -Brian
  8. Rear E-Brake has been performed by using 240SX parts i believe. I think Tex did it, or maybe it was corky. Not sure if the USRM has anything in it about rear ebrake. There seems to be alot more impreza's showing up in the junkyard here. Maybe I'll have to pull some parts and see what fits what. -Brian
  9. I call bull***************. -Brian
  10. Lost the passenger side mirror to a tree once. I dont think i left it on the trail, just threw it in the back of the car and continued on my way. -Brian
  11. If your a member of the USMB you are more than welcome to come. Probably wont be any offroading as I'll be in the RX. It doesnt agree with the dirt right now. Would like to find a nice scenic drive somewhere. I know of some great places up here and around the sierra's, but not many in the bay. -Brian
  12. Yes your using the right word. Backfiring it is. The WRX's could probably do it with ease if they messed with their fuel mixter and timing. Again, Im not sure you understand your engine. Did you say your car was carburated? -Brian
  13. The headlight trick is definatly my favorite. Right now, the #1 feature i love most about my Subaru is the Dual Range AWD with locking Center Diff -Brian
  14. I paid $32 for both of my front KYB's from a local junkyard. And here's a secret about Kragen. They will beat anyones price by 5%. You shoulda called Napa 1st and then called Kragen and told them Napa had them for $90. Napa might have to call to confirm, but they will then adjust the price to 5% lower than Napa's. Saves me a buttload on CV's -Brian
  15. Thats BRILLIANT!! +1 for the USRM -Brian
  16. I say its the spider intake. Put the stocker back on -Brian
  17. Miles... right now my timing is set at 20-21 degrees. I used to have it set at 18 degrees, and it seems setting my timing up to 21 only helps alittle. BGD73... i doubt it's my cams. My intake temps should be through the roof, but yeah... its turbo'd, so thats to be expected. I havent installed the intercooler just yet. I want to change my BPV setup before I put the IC back on there. -Brian
  18. Yeah my RX has em too i believe. -Brian
  19. not on my brand new exhaust!!! However, i do have a custom catless 2.5" downpipe ive been meaning to put on. It has enough pipe at the end to cover the 2nd cat (the one with a gash). Only problem is finding a shop that'll do it. I know of one, but i dont like the guys welds. Maybe he's improved in the past couple years. Oh, and it builds boost just fine. -Brian
  20. Fuel filter was replaced in September... car died in November and took a 6month break. So the filter should still be good. I didnt think about the cat comming apart and clogging things up. I cant really disconnect it, my entire exhaust is 1 piece. I'd have to unbolt it from the turbo, but then it would hang and drag on the ground. -Brian
  21. Lemme break out the old vids of when my wagon was alive. You will need DiVX installed to view these: http://usmb.net/albums/albuo73/JunkieDirt.avi http://usmb.net/albums/albuo73/JunkieDirtStuck.avi <--- warning, 40mb file http://usmb.net/albums/albuo73/HatchPatrol_Junkie_Run1.wmv <-- My only run with the famous Hatch Patrol http://usmb.net/albums/albuo73/JunkieSoobme2.avi http://usmb.net/albums/albuo73/Subaru_Tool.wmv <-- Some video editing work i did... short intro I never completed. I'll have to get another wheelin rig before I can get more footage -Brian
  22. Feels like a fuel problem too. Exhaust is brand new. As a matter of fact, there shouldnt be any restriction at all since I tore a 8" gash in my catalytic converter. Maybe time for a new fuel pump? -Brian
  23. Whatsup? Car kinda just loses its guts. In 1st gear I can get it to skate to 4500. 5000 is worthless. Once i shift out of 1st gear, no point in trying to go past 4000rpm. Seems like ALL my power is between 1700-3500. Full boost doesnt help, doesnt even seem like its trying to pull when i have it at WOT. The other day I came off a red light. Tried to hot rod it, and it screamed past 1st gear, as soon as i shifted into 2nd and held it at WOT the engine just kinda went BAHHHHHHHHHHHHHHHHHH... no real power at all. Major hesitation, until i let off the throttle. Seems I have to be easy on the peddle and gradually increase the throttle as the motor speeds up. But again, once Im at 4k i am forced to shift. What Gives? -Brian
  24. Wish the best for you Tex. My motor has some wierd hesitation too under boost. I dont have all the cool gadgets you do, so i dunno where my fuel ratio is at. Alls I know, is i finally have low end torque. Makes power till about 4k and thats about it. Oh, N/A block... stock RHB5 and so far, un-intercooled. -Brian
  25. No idea when it will be. Trying to get some input here. So yeah... what weekends are best? I can do it almost any weekend. -Brian
