				Posts3827
				Days Won5
Everything posted by Scott in Bellingham
	  SJR Ultimate offroader projectScott in Bellingham replied to Scott in Bellingham's topic in Off Road anyone in my area that wants to work on this project maybe weekly or whatever, Im not makin much progress, :-p :cool: :-\
	  Apparently 6-ply offroad tires don't always have 6-ply sidewallsScott in Bellingham replied to eggroller's topic in Off Road Zap , I noticed the Kuhmos why not swampers? the reason I ask is Im looking to get a set of more streetable tires and am looking at the Kuhmos
	Im looking for a set if anyone got some
	heres one
	looking good,
	I had a '86 with the automatic it was a x cab p-up I really liked the truck but when our girl came along I sold it as there was no room for a baby seat sounds like a nice project good luck
	Heres a idea heres a 31" x 10.5 tire on a stock 15 soobie rim, you could move the strut up to the second hole take some metal with 3 holes in itand bolt it up , I did this on a offroad Metro I put together, it also gives you part of your lift, I would stay away from deep dish offset wheel as Its harder to turn and hard on the bearings , and offroad it tends to jerk the wheel out of your hands
	went out northfork, we should plan another trip up there http://www.ultimatesubaru.org/forum/showpost.php?p=543133&postcount=3
	Here we are went up the hill out Northfork, should go up again with others. Mounted uup the studded snow tires and even got a flat on the main road headin in , not sure why it seemed like I was loosing power so we pulled over and the rear Passenger side was totally flat, it might have been low from home as I have never ran these befor, they ride much nicer then the swampers,
	if its the same as a 91 legacey i have the struts to make the pattern off,
	front strut towers what maybe 2" I could make a set
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road think we need to install dads moter in it ,carb it, keep the 6" lift on it , raise the engine back to stock and prep it for a transfercase and front diff , it could be my DD and sell the White car, then eventually maybe drop in the EJ . or save the EJ for the Tracker project:eek:
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road Rollie you comin over tonight?, drive over #1
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road Rollie we need to make plans for the #1 Red beast ,
	thinkin duals front and rear with a 2" lift maybe cool , use stock subaru rims and 25-26" snowish tires , maybe run the outer tires smaller so they wouldnt contact the ground untill you needed them ,this would also help with the stock gearing, run a locked rear of course
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road look forward to it
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road do you have the stock plate? if so bring it and we will used that as a base and weld some more bracing on that
	  Shop/Club night Bellingham OffroadersScott in Bellingham replied to Scott in Bellingham's topic in Off Road shop night has dwindled down , maybe its winter maybe its every here has there cars where they wanted to be , not sure ................................................. Im thinkin about starting a new thread, more on the lines of whats going on at Scotts place this week , I could post what Im developing, my own personal projects Im in the process of building, what SJRLIFT is up to and developing , any other thoughts that are going though my head, what do you guys think? any suggestions?, maybe even throw in some of the other personal going on in my life , any interest in a thread like that? would anyone read it or even care?
	powers been off a couple days here , if a couple guys could help me out we could make them but its not a project Im willing to take on by myself, , I have a bunch of my own projects that are not getting done .I will be making a hood for my offroader it will be one peice hood/fenders/grill , leave the rear half the hood and fenders cut at centerline of wheel , be custom with small round headlights and front corners bobbed kind of like the hoods they put on Baja bugs:banana:
	add plastic fenders to fit in:banana: :eek: :cool:
	go EJ, do you want low gears? , or going to stick with stock gears and smallish tires, myself I would want lower gears, if you go with a second diff up front you could bring the engine back and drop the diff up inbetween the engine and transaxle this will bring the nose back 4-6" also brings the diff up so your engine can stay lower,would also need a transfercase , nissans 1:2 ratio ,or a sammy is 1:2.26 , with the sammy you can get some even lower gear sets, if its a sand type looking buggy you could even run a 3.7 diff up front and a 4.11 out back,that way you could have a 27" tire on front and run 31s on the back, heres a chart that shows what tire combos would work: .........Front...Rear1...Rear2...Rear3 Ratio...3.7.....3.9.......4.11.....4.44 Tire1...25......26.4......27.8.....30.0 Tire2...26......27.4......28.9.....31.2 Tire3...27......28.5......30.0.....32.4 Tire4...28......29.5......31.1.....33.6 Tire5...29......30.6......32.2.....34.8 I would pick up a good running lagacy and use that as the doner , has a 4.11 rear diff, has a EJ2.2 has stronger axles and easy to find 5 bolt wheel pattern, the rear axle set up is more difficult as it runs struts and arms , all matters what you want and your ability SJR
	  Went to the Snow, had a blast (56k? me too :) )Scott in Bellingham replied to ezapar's topic in Off Road who needs that when we have the real thing,.............. looks like you had fun Zap
	a VW Thingee has mosty straight flat surfaces, if it was me I would take a rust free soobie chop off all the sheet metal that doesnt look like a thing, weld up some straight square tubing in the shape of a thing and put a skin on it pretty simple lines on that thing keep us posted SJR
