Scott in Bellingham
Everything posted by Scott in Bellingham
  1. just diff studs with a locked rear diff
  2. all loaded headed out
  3. I made a sand buggy out of a suzuki swift a few years ago I just took the complete front wheel drive train out of the car and mounted in the back of a tube frame buggy , worked super with no custom stuff
  4. jeff got any stickers? if so bring some also 9:00 AM ??
  5. I like the subaru , I just dont like breaking and bending and no low gears so hope to fix that with this moshine , 4 link would be ideal in the rear I just dont have much room above the diff as I want the gas tank to stay there , water bottles catch the drips from the brake lines
  6. not noticable that bike engine was rigid mounted in the bike right?
  7. my white wheeler is solid steel mts no rubber , it has no issues I would go solid
  8. weight makes a big difference chop it off and add a roll bar
  9. huuummmmm what car should I bring
  10. Howd it go Jeff ??
  11. heres the rearend Toyota tacoma rearend with 4.10 gears Nissan 720 transfercase little over 2:1 ratio
  12. got the taco rear home, need to find a driveline next checked all the ones I have none fit
  13. could go zuki but the front and rear inputs are centered so is the nissan, well anyway its just sheetmetel the passengers in the rear wont need that footroom anyway, plan to pickup the rearend tonight
  14. Measured the Toyota tacoma rearend its 60-1/2" wide , looks like the subaru rear EA82 is 60" so Im going to get it, its a 4.10 ratio so that will work with the 4.11 up front and then I will be able to use same rims and tires front and rear and the datsun truck rearend was like only 55 " wide , so it keeps evolving, set the transfercase under the car , its a tall hummer, looks like I will be cuttting the tranny tunnel out and raise it up a few inches would like the t-case up another 6"
  15. early legacy 4.11 I got 2 of them weld up one ?
  16. Im designing a single 3" tube bumper, somethig we can start making for the masses, going to go look at a toyota tacoma rear axle see how wide it is may get it think its a 4.10
  17. this should be cool
  18. thanks Mick whats the story on the black jeep ?
  19. its just sittin in the shop, you should go wheelin with us when you come over and also bring Gurus linkage
  20. Jeff lets do it on the Tenth as I have somethinon the third I forgot about
  21. it was in a wagon with dual range , yes side mount , I didnt know till I saw the flywheel with a smaller clutch and decided to install a bigger one but the crank bolt pattern was smaller , $200 sound fair ?
