Everything posted by Scott in Bellingham
EJ with dual single Weber Carbs and Disty
heres them carbs on a Bug Moter
5 speed swap tomarrow
Lighten up on this guy
I wonder what year...
Cool Custom rear hatch
Buildin up a new moter this ones a 91 EJ 2.2 going with dual single barrel 34 Webers , a VW Bug setup I got a couple years back, got the intake manifolds builtup , cut the bottoms off a stock EJ intake manifold added some tubing and the flanges off the VW Weber intakes , got a set of Delta Cams they are the torque grind , lookin to get more lowend torgue out of this bad boy, will be going into my new wheeler a EA82 3 Door Coupe white , also looking to get the stock Subaru Disty turnin on this one , I used the Escort Disty on the last engine , works good, just wanted to stick with the sooby so I wont be modifiing any wiring and also the suby disty is sealed better and self contained , goal is lowend dont care to much on the high end for a Walker wheeler , what ya think
XT6 transmission project.
thanks guys
NW Washington Offroad Walker run Dec 19????
I know its a long trip from your place, hope you figure it out:eek:
Ahaaahhahaha it lives(now what to do about mouse nest)
get Decon and set it in the car , they will find it, no easy way to get the nest , if there is no A/C you can remove the hose between the fan aand heater box if not then the dash has to come out
BOSS Gen 1 BRAT/4wd lift kit Christmas Deal
looks great Bill good job !!!
so chux will a EA82 D/R fit into a EJ trans case?
wheelin in bham and surrounding areas
we head out to walker valley near mt vernon each month
Ill be in Robs sedan
good stuff ' legos '
14 inch on 98 outback
I tried 14" soobie wheels on a 96 Legacy would not fit, hit calipers
sjr lift ????
under the rear mustache bar wear it mounts to the body, drops the diff down 1"
How many inches lift do you think to fit 31"s on early 90's Legacy?
Gloyale you are correct , I would not have had room for the 31s if it was a top block
4.11's
and I know the 90 , 91 Legacy 5 speed have the 4.11 as I have one at my shop
Im plannin on it maybe build a snow man:eek:
4.11's
early gen 1 legacy 90 same housing and stub shafts
SJR EA82 new white wagon 6" build thread 2009
Heres the start of the front bumper
Ill be busy in the morning of the 12th how bout the 19th
anyone make a lift kit for a 97 OBW???
www.sjrlift.com sorry nothing for a 97 OBW
wondering about an ej22 engine swap...
no but will need a engine adapter plate EA to EJ and need a redrilled EA82 flywheel SJR
lookin to do EA81 to an EJ22
I make and sell the adapter that allows you to install a newer EJ moter onto your Brat tranny , I also redrill the flywheel to bolt up
SJR Lift Site Problem
will be redoing whole site soon , will end up with more info on lifts, engine swaps , wheels/tires and other mods ,
softwear problem hope to resolve soon
