Scott in Bellingham
Everything posted by Scott in Bellingham
  1. I hear ya you can do it yourself get some Omni single coat and a cheep harbor freight gun and borrow a air compressor ,Ive done one out under the trees and it came out good, also people have had good luck with these small foam throw away rollers , go with a light color it will hide most the flaws
  2. Nissan / datsun rear diff, same as Nissan 720 4x4 pickup front diff, bolts right up no mods, would need to make own bearing carriors
  3. remember hes got a tranny in that bike engine so 2 trannys i with low range AWesome!!!
  4. Jeff if I come can I drop off BIlls engine just befor at your place?
  5. 87 soooobie my origanal 6" lift with 27" swampers An Idea as how to mae it lighter with better aproach and departure angles
  6. Brian this is what I plan to build licensed and legal to drive on the road, Subaru body, Subaru Engine, also whats all this about? """Itsignifiesourdeterminationtonotstrikethefirst blow,butalsotonotstandmuteandallowour lovedones,andallthatwebelieveinandstand for, tobetrampledbymenwhowoulddepriveusofour God-given–ornatural,ifyouwill–rightstosuit theirownends. """"
  7. I got one its deeper then the toyota, and positions the starter back farther, maybe would work with a automatic starter not sure
  8. have a nissan case I may sell
  9. is the XT the same underneath as far as the body goes? whats the differences, car you interchang any body parts like the front fenders and hood? what interchanges between the XT and ther EA82s? thanks Scott AE82 car
  10. my birthday comin up
  11. Heres the EJ Flywheel heres the EJ trannywill need to cut the front off the tranny machine it down , cut the Toyota Bell housing in half Machine it down and weld the 2 halves together
  12. OK decided which direction to go, I didnt really like the Nissan case its so tall and would need a framework to mount up , so I went out and picked up a Toyota 86 4runner 4x4 tranny with transfercase , checked it out tonight Heres the Subaru clutch disc next to the Toyota one, the Toyota one has a bigger hole with more splines , subarus on the right, also the subby preasure plate has a larger throwout bearing and "hole" subbie center bearing slipped onto the Toyota pilot same size...
  13. like the loose nut holding the wheel
  14. Brian this gives me more motivation to get er done quick and not be distracted by other new and old projects, I must have A. D.D. or somthin
  15. on the roof or the back beats having it hit you in the head, Ive done that , even broke both moter mounts on that fall
  16. Im up to it .................... rules I would say minimum must have Subaru Engine and body any year or model , what else Brian ??
  17. mount rear diff up front , normal not upside down the nissan case is a 720 from early 80s trucks , sammy case works too
  18. EASY you dont remember that silver car that saved your ( Dodge) 2-1/2 years ago??, that thing wasnt "easy" has a 2nd tranny and transfercase , 9" lift and modified body, come on Brian Ill challenge you to a build off and we will meet up this summer and compete our 2 soobies side by side and see what happens , I realy like my ole white car just want somthin a little better that will not break
  19. OK Ixve seen all these "snorkles" now lets see them in action with your car in deep water or are they just for looks?
  20. got the car moved today, its now back it the corner all so started some major cleanup found the back wall of the shop, its been 10 years since I saw that area, moved the new to me bandsaw in place , moved the wood stove out next for a steel rack on the back wall
  21. Mick now that you have had it both ways is there anything you miss about hte old Brat before the axle swap? anything??
