Scott in Bellingham
Everything posted by Scott in Bellingham
  1. ive broke stubs and axles on the rear if the stubs are strong a axle will break, key is driving technique , know your limits and work within them,
  2. last week then its over, will start filling orders this week
  3. thats it I made one out of a long bolt and ground down the sides to a tapered square
  4. I have a set of those black plastic seats I would part with, for me they are too narrow , I put thick Garbage bag seat covers on the rigs I used to get muddy , also where some good waterproof pants and coat helps. take us some pictures next time you swamp that rig SJR
  5. this is what Ive found EA81 keep stock geometry , so if you want a 4" lift go 4" on everything EA82 2" over stock on front Axles OK and 1" over stock on rear axles OK
  6. lets get those orders in by the 20th , thank you to those who already paid
  7. i did 4" on this legacy 2" plus the outback struts those are 30 x950 tires
  8. if you use 7/16 you will not have to drill the strut top mount
  9. use 2 x 4 rectagular steel for the drop blocks, check out this thread http://www.ultimatesubaru.org/forum/showthread.php?t=97445 6" at the struts, 5" at the diff and engine crossmember
  10. +2 and take a video
  11. OK hows the EJ axles compare to the EA axles in strength anyone know that? I measured the rear (91 legacy wagon) and they are the same diameter as the EA82 axles I have , in my opinion if the axles are EA82 rear strength they are not strong enough unless you run a light vehicle with small tires , but Im asuming we are talkin a full Subaru not cut up to save weight and 28-29" tires , myself I would like to see some 32" tires
  12. whats your goal? travel for jumping ?or flex for offcamber slow moving? , if its flex you want you can do that without much travel , mount all the rear suspension on a frame and put a big pivot inline woith the driveshaft
  13. Thanks again Jeff for makin this happen one of the best runs ever , look forward to more in the future , my cars comin up on 4 years lifted old , may have been its last run Scott
  14. Eric we need to finish this ride think it should be my new wheeler as the old one needs a engine and a lot of other items , also I want to install the new Delta cams in it
  15. Just ordered a set , cant wait to feel the difference on the trail, might retire old white and start wheelin new white
  16. Ken Im ready for a set of cams ,the low end Torque grind for a EJ 2.2 , do I need to send you a set to have reground or ? thanks Scott
  17. good to finaly meet ya Bill sure we will see ya back again soon, thanks Jeff had a great time,
  18. CANT SLEEP looks like I may need a rain poncho today
  19. Eric I will leave home at 8 so Ill see you at Trader Joes at 8:15 ch 5 CB Scott
  20. Jeff I would like 2 , one black and 1 white
  21. OK those that want in go to my Store www.sjrlift.com and place a order and in the comments area write GROUP BUY 2009 and I will send you a corrected bill for payment , I will not fill orders till after Nov 20th then I will start ,thanks Scott
  22. cool I cut the parts for top o the struts just need a few holes
