5
Everything posted by Scott in Bellingham
looks like a fun rig , would do better in the sand dunes , I really think thats the key with these subarus , remove all the weight you can
Jeff I got the starts of the race car I was talking about its a 81 Dodge 2WD with a 2.6 4 banger this will be our first dirt track racer, pull the bed and cab off and add a roadster type body and move the engine to mid frame look like a old T track roadster so we need to start on that race track !!!!:banana::banana:
Ive herd of that area glad you had a good time , how did you get out?
correct to the EJ pattern
My latest aqusition, Free 1978 Corolla
Scott in Bellingham replied to Ken_B's topic in Non Soob Cars and Bikes Discussion
I had acouple of those 20+ years ago good little Hemi engine -
Walker Valley 20 June 2009 Report with pics
Scott in Bellingham replied to Scott in Bellingham's topic in Off Road
no bendy -
so a EA82, get the SPFI with a Dual range 87 or 88 , no Auto or no push button 4wd .for off road you want that dual range
what do you want tp know on what model?
3 of us went me Scott Jeff and Rick didnt get may pics had a good day overall many repairs
Installing SJR lift kit
Scott in Bellingham replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
correct I now send out the crossmember 1" block as on some installations the axles rub , you have my first 2" lift I sent out so it does not have the 1" engine crossmeber spacer , the picture at my store needs updated -
2" Lift kits for EA82?
Scott in Bellingham replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rollies correct on the long bolts they are for the engine crossmember, I have heard that the stock outback steering shaft will work on a 2" lift but not sure, the black bars are fpr the enginge crossmember and the for bolts with the silver couplers are for the mustache bar drops it down 1" -
drove the wheeler to work its all ready looks like rain
radius rod bending , how to fix
the control arm bends near the bolt mount , you can usually just unbend it , but they do start to crack at that point , Ive never hurt the crossmember its a Ea82 -
its from ramming the front tire into rocks, roots trees other imovable items -
seems like I cant keep these straight heres a few Ive bent so I shoved the bar threw a 1 x 1-1/2" rectangular tube and welded the ended we ll see how this works will test this saturday at walker what have you guys done and how do you prevent such bending ?? .
driving in low range all the time, is it bad for tranny
Scott in Bellingham replied to oooo's topic in Off Road
on a dual range transaxle you can run it in fwd low range just need to remove the short linkage from the front of the trans to the rear thats the hi/ low then just leave it in low or make 2 seperate linkages -
This guy is building a Subaru buggy
Scott in Bellingham replied to Andy FitzGibbon's topic in Off Road
looks good dave whats the wheelbase, lets see some action shots -
install struts off a outback gives 2" lift and room for bigger tires
got lookin at my car , the front right radius rod is bent so off it comes maybe I should make a stronger one for this weekend, that seems to be the weak spot for me, always the right side
correct, the stock bolts are welded in need broke out -
Fathers day run here we come should be a good one :banana:
OK looking at this picture the top row is the mustache bar blocks and longer bolts for that the next row is the rear shock extensions ,yes rotate the tops 180, the 4 long bolts and the 1" long pipes drop the diff , and then of course the front strut extensions , this is the first version , the new one comes with a front engine crossmember 1" block as Ive found on some not all installs the axles rub, Scott -
I plan on it , fired up the ole white wheeler and even gave it a bath , lookin forward to going its been awhile,
