Everything posted by calebz
will be driving from east coast to midwest at end of week
Definitely bring papers.. or at least fresh screens :cool:
pug wheels
Yes. 505 is the only one
EA-82T timeing
The reason they don't go to 25, is because the timing is supposed to be set at 20 btdc
loyal lugs baddddd
timing could be off. could be bad gas.. any other symptoms? how long has it been doing it? did you change anything before the problem started?
ea-81 gauge Q
I have the same question for the temp guage on an EA82.. sorry to hijack your post, but I will bet they are the same size
clutch stutter
calebz replied to bannergraphics's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy mother in law has made similar complaints about her OBW.. was bought used with a new clutch in it(OEM).. after 3k miles.. clutch stutter..
Ej20tt
calebz replied to csm101's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, we didn't get it here. unfortuntely
I need CV's
thats where I got mine.. 6000 miles and still going strong.. no troubles at all, except that it took 5 axles to find 2 that weren't visibly damaged or weren't obviously constructed by a myopic retard with an obvious dislike for soob axles
RX Tranny
Brad .. I saw that one on Ebay.. I am absolutely AMAZED it didn't get any bids.. (sarcasm)
Sept. NorCal Rally Cross
Hey now... Some of us have over 100 hp.. barely
EA82 gas tanks
yup, the 88 is the wrecked one. mail comin your way, Thanks
87 turbo running very rich (solved)
Running stoichiometric raises combustion temps in comparison to running rich. thus giving you a much greater chance of melting your turbo and manifold. at the stoic ratio, one false move and you are in detonation mode. Skip, If you can't figure it out, it must be one hell of a problem.
EA82 gas tanks
Yeah Rob, they're the same. I would recommend the one from the 88 turbo.. I drove it longer and trust it more. There is paperwork coming your way And is there any way I could talk you out of the fuel pump off the 88 turbo?.. I think its still there.
I need CV's
I don't know of anywhere that sells just the joints.. in my experience, its best to replace the whole axle. $60 plus a core isn't bad, just make sure you inspect them closely before you take them home.. and get a good warranty.. I believe mine came with a lifetime warranty
3spd auto 4wd to 5sp 4wd D/R ?? help?
As I said in my first post, my advice only applies if the car in question was an EA82 (had to guess since you didn't say) Since your car is an EA81, all my advice is null and void. I don't know anything about those
91 Loyale Trouble Codes
Nope, Oob, thats not it.. By not giving the answer directly, I was encouraging a little bit of research with the resources given. All the answers are in that link
How do I turn off the light?
calebz replied to falling's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 87 turbowagon does that too(used to have the ride height suspension.. been converted). still haven't figured out how to get rid of it. that flashy light is irritating.
check the link you were given in the last post.. all the codes are there
stubid question #2 posting pics
I can resize pics for ya too. send em to me and I'll send an 80x80 back to you czaharris@comcast.net
Which one looks better?
The second one looks better.. thats the one thats photoshopped isn't it?
92 Legacy LS "wiggle"
calebz replied to falling's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUneven wear/mismatched tires? that might cause binding as well
1996 Outback
calebz replied to VWillis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it a dealer or private party? That makes a big difference on price. 5700 doesn't sound too bad, but I would check cars.com, autotrader.com and kelley blue book(kbb.com)
:burnout: Yeah, johns right about the thepedal box. I recently did the swap from auto 4wd to manual 4wd(S/R) I'll help with whatever info I can give
parking lights on steering column
calebz replied to dormat925's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have gotten 2 soobs very cheaply due to "wiring problems".. IE: parking lights that won't turn off.. the first was one was my first soob, so I didn't know any better.. after fiddling around with it for a couple of hours, I sat down, took a break and looked through the owners manual for amusment.. thats when I found the switch.. have never used it since
doors lock when shutting door
calebz replied to mahlmann's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAhhh thought that might be the case.. Never heard of that on our older soobs. you might try posting on the new generation forum.. thats where the legacy and impreza owners hang out. Sorry I can't be more helpful
