8
Yeah, the 98 impreza gearbox should fit.
99 Subaru 2.5RS Transmission Upgrade?
Legacy777 replied to ShadyNluvNit@charter.net's topic in Subaru Retrofitting
The final drive ratio will be different, but other then that....it should be relatively swappable. -
Other thing to consider, you may have made the engine an interference engine now....
To remove the trans, you need need to disconnect the torque converter from the flex plate on the transmission. To do this, you need to access the bolts through the plug hole on the engine bell housing. It can be a pain, but it's not too bad if you take your time. http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2486.JPG here's some more pics http://www.main.experiencetherave.com:8080/subaru/images/injectors Other then that, you just remove the upper bolts and lower nuts holding the trans to the engine, and lower the rear transmission crossmember. It can be a real pain to get the trans out, and slide back far enough off the engine studs. Other option you have is to pull the engine & trans out as one unit, which probably is going to be easier. I've got scans from the factory manual on my server. They may not be exactly the same, but should help http://www.main.experiencetherave.com:8080/subaru_manual_scans/
manual or automatic? -
You just want to make sure you don't adjust the clevis pin too far, so that the master cylinder doesn't return to it's full stop/resting position. If it doesn't, it keeps pressure on the slave cylinder which could wear things out, and/or possibly leave the clutch a smidge engaged. Take a look under the dash, and it should be a little more clear. Even if you don't have a full stroke on the pedal, you should still be engaging the piston in the master cylinder, and could bleed the system.
The chances are, the heat control incident was a coincidence. I am pretty sure the 96 still uses a cable actuated flapper door. What does the hvac controls look like? If it is cable actuated you should be able to get access or get near where the door is down below the glove box, to at least get the heat off until you can put in a new cable.
Here's one http://www.renickmotorsports.com/oscommerce/catalog/product_info.php?products_id=429 You might try searching NASIOC....there's bound to be someone else as well. Energy Suspension I think might have a kit as well. Some additional whiteline stuff http://www.pdm-racing.com/products/subaru_corner.html http://www.boxer4racing.com
The rotors on the 05 LGT are HUGE compared most other subarus. Also, the braking system was redesigned for that car, and is pretty good. My recommendation to you would be to replace the stock pads with something more "performance" oriented, put stainless steel braided brake lines on, and use some good brake fluid.
The final drive ratio on the turbo legacy AT's is 3.900. So it'll match yours. Bolt pattern should be the same There is a dropping resistor over by the passenger strut tower. DO NOT unplug it. It will firm shifts up, but will cause you problems down the road. I had mine unplugged for a little while, and had issues with the car not downshifting, and some other weirdness. So, I'd recommend you leave it alone.
From a quick glance....the wiring at the TCU is different. Look at this (pg 35) http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/1995%20Legacy%20Wiring%20Diagrams.zip and these http://www.surrealmirage.com/subaru/files/swap/6-3_at_control1.jpg http://www.surrealmirage.com/subaru/files/swap/6-3_at_control2.jpg Find out everything that is different.
Check out www.bbs.legacycentral.org for more info about the first gen legacy. As for what's interchangable.....actually quite a bit of stuff is. For example....I'm running wrx front brakes, 05 LGT rear brakes, single diaphragm impreza brake booster, SVX master cylinder, impreza sti bushing for the front control arm, impreza whiteline rear subframe bushings, impreza sti front/rear trailing link bushings, whiteline sub-frame locks, etc....etc. There's a lot of info on the BBS, you'll find out what fits and what doesn't fit by seeing what other guys have already done.
