8
Just a quick question about the description on your website "The VF34 is similar to the VF30 but has improved spool up due to roller bearing design. This is the standard turbo on the New Age Sti RA Spec C. This turbo yields good throttle response and mid and top range power. It also uses a ball-bearing center section, which reduces friction and positively locates the shaft-wheel assembly to improve spool up and avoid turbo failure. " How are the bearings configured to utilize both roller bearings & ball bearings?
Are you swapping stuff from an old gen car into another old gen car? It sounds like it, so I'm going to move this post to the old gen side.
As josh mentioned, you have to use the engine wiring harness from the 90-94 legacy so the engine connectors hook up.
The final drive is probably different. The SS has a 3.90 final drive, while the 95 I think has a 4.111 final drive. What trim level is the impreza? What engine does it have in it? The electronics are going to be different between the two cars, but you "should" be able to run the 95 Impreza 4EAT with the turbo legacy TCU. The turbo legacy 4EAT actually has a few things that make it beefier then the standard 4EAT, extra clutch packs and what not.
Torque curve for EJ22T
Legacy777 replied to 2.2T Syncro Westy's topic in Vanagon Conversion Discussion
http://www.ultimatesubaru.org/forum/showthread.php?t=49024&highlight=dyno
