8
Yeah if it is the metal hard line, then yah you'll probably have to drop the gas tank. To get the gas tank out you pretty much have to remove the rear diff, axles, and subframe. I "think" you could leave the crossmember in there, but it may give you more room to remove it as well. It's not overly difficult, but there's a bit of work involved.
Just wire up a resistor in the EGR electronics circuit. Then you can use the EJ22 manifold. If you use the EJ22 ECU, you shouldn't need the EGR valve. Main issue I can see with this though is the EGR piping. You'll either have to put a blank plate on the piping going up to the EGR valve, or swap the exhaust piping from the Legacy.
Oil Filter ?
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
purolator made the white subaru filters. I'm not sure who makes the black ones. -
Comparison
Legacy777 replied to Oldacura's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
A lot depends on your driving style. If you are a lead foot, the turbo will probably get slightly worse mileage. Obviously the n/a 4 cylinder is going to get the best gas mileage. Personally, I'd get the turbo 4 cyl. I don't think the extra cost of the 6-cyl warrants the cost. Best advice I can give you is go to your local subaru dealer and drive all three. Check out http://www.legacygt.com/ There's probably some turbo Outback owners on there that can give a ball park of their mileage. If not, the GT owners should be able to give you some feedback on their mileage. -
Man....for that price....just get the tranny. I still believe the 96 had the phase 1 4EAT trans. Check the connectors on the 96 transmission. Just make sure they match the ones on the 91. There are some additional inputs/outputs on the later model phase 1 4EAT transmissions, but I think you could probably still use your 91 TCU. As for trying to fix yours. Pull the torque converter out. You should see the input shaft seal right there.
Have the rotors turned or replace them. I'd just replace them. You really can't see variations in the rotor...enough to cause you problems. As a general rule of thumb. If you feel shaking in the steering wheel the problem is the front brakes. If the pulsation feels more like it's coming through the brake pedal, it's probably the rear brakes.
ECU Info
Legacy777 replied to rotorque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You may want to ask this question on the rs liberty forums. They may be better suited to help you since most the guys are based either in Aus or NZ. http://www.rslibertyclub.org/forums/index.php?
