New Subaru mini-van!
Legacy777 replied to Dusza Beben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis info is incorrect. Check out NASIOC's news & rumors forum. The minivan is meant for japanese markets only.
bodykits for 90 subaru legacy
Legacy777 replied to subaru girl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe simple answer is you probably won't find anything. If you do, it's going to be crazy expensive. You can try modifying a kit for an impreza or later model legacy....
2006 synchros in 2003 WRX
Legacy777 replied to Blue Hornet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably not, I wanted the updated design put in the turbo legacy tranny I had rebuilt, but it wasn't possible. The 03 WRX may be different, but I can't say for sure.
SatNav / Forester '06
Legacy777 replied to McChazza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo they have a main headquarters/office in Poland? If so, try calling/emailing them. They may know more then the dealer. If they don't, I'm not sure what to tell ya.
Need part # for 97 Outback rear strut mount
Legacy777 replied to LostWater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGive Jamie a call at www.subarugenuineparts.com She should be able to help.
93 Subaru Impreza Power Steering/Alignment
Legacy777 replied to Dazed Dreamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about an alignment or to have them check the power steering? A 4 wheel alignment can range from $50-$100. As for checking the power steering...really don't know...depends on how many hours they spend, and if they find anything.
Legacy777 replied to Dazed Dreamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably two different things, but you should have it checked out.
Legacy777 replied to McChazza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to try contacting subaru of Poland directly.
90-91 Legacy AT vs 5 spd engine mgmt system
I went to 92 engine management for a different reason. I had swapped in 92 fuel injectors. They were different then the 90-91 models. Since I swapped in the injectors, the car seemed a little sluggish and my mileage was crap. I attributed it to the differences in EM programming and the different injectors. I ran on my AT ECU for a while before I got my 92 ECU, and it worked fine. As I said, the ECU is outfitted to be able to run in either AT or MT mode as long as the identifier pin and other associated wiring is corrected.
Bad cat code P0420 low efficiency
Legacy777 replied to jlawlor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're continuing to get the code, and have replaced the sensor. The problem more then likely is either in the wiring or that the cat is truly not working as well as it's supposed to. You don't want to clean it with solvents. They make cleaners you can buy and dump in your tank that's supposed to help, but I don't know how well they'll work. If you can find seafoam, give that a shot www.seafoamsales.com
1990 legacy 2.2 dies intermitantly
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood deal. I'd also suggest resetting the ECU. That was allow the ECU to start off from a "fresh" point in case the MAF had been giving bad signals to the ECU.
Trade in the old horse....
Legacy777 replied to Steve B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSteve, I don't think there's much difference between those models. I'm not sure how many forester owners there are on here, but in terms of the newer generation cars. They are definitely more civilized and what not. If you don't get any further replies, you may want to check out the forester forum on http://forums.nasioc.com/forums I think edmonds may have a forester specific forum too.
donor cars for 5mt into 4EAT tranplant question
Legacy777 replied to Adam Lee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere are the scans I was talking about. This describes the AT http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg MT http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWDMT_description.jpg Center diff http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff3.jpg
98 Forester aftermarket Shocks
Legacy777 replied to redmethods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know if KYB makes specific forester applications. If they do, I'd recommend them. If not, I know people have taken WRX or STi struts and springs andd used them on their forester.
The engine management goes with the particular sensors that were used. If the AT sensors & ECU were retained, that's fine. Everything will work fine. If they mixed and matched sensors with ECU's, then that's not good. There is a MT/AT identifier pin on the ECU. That will tell the ECU what transmission it has, and will adjust things accordingly. Read my swap write-up. I go into detail the modifications that need to be done to get the wiring correct. www.surrealmirage.com/subaru/swap
Legacy777 replied to Adam Lee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe AWD systems on the auto and manual trans are completely different. The automatic uses clutch plates, and a hydraulic solenoid which actuates the plates like a typicaly automatic transmission. The manual uses a viscous coupling attached to the center differential. There are inner and outer plates in the coupling along with a silicone type material that becomes more viscous as the plate "shear" it. I've got technical scans, but one of the drives on my server is crapping out. So once I take care of it tonight, I can post those scans. The rear housing is different on the FWD 5spds, however you really don't see many of the rear housings and transfer sections of the AWD trans floating around. I would just try and find a complete AWD 5spd.
fuel tank
Legacy777 replied to orviszj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the rear end must come out, and pretty sure you're going to have to remove the rear crossmember as well. I don't think there's enough room to snake the gas tank out with it in.
Legacy777 replied to Adam Lee's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you read my write-up? www.surrealmirage.com/subaru/swap All of the 90-94 legacy tranny's will work. Your 94 4EAT has a 3.90 final drive ratio. The 91-94 turbo legacies were the only ones with that final drive ratio. So unless you get one of those transmissions, you will need to swap the rear diff too. Dual range transmissions were not available on the 90-94 legacies. Your best bet is to find a donor car, that way you have everything, and don't have to piece-meal the parts needed.
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt can....but it sometimes won't. Mine didn't throw a CEL until it was REALLY bad.
my liberty is cooking!!
Legacy777 replied to libby94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds like the system wasn't probably bled of all the air. Is your model normally aspirated or turbo'd? The normally aspirated radiators have a bleed screw on your driver's side of the radiator to allow air to escape. I would start there.
94 Legacy 2.2L Low Compression Drivers Side
Legacy777 replied to skeeter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I've found out with my recent compression test on my n/a ej22. The actual final values may be off from what they're supposed to be due to gauge inaccuracy. However cylinder pressure variance is important. When you did the compression test, was the engine warmed up all the way, injector connectors pulled off, and throttle plate open all the way?
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the JECS MAF was what I have too.....I haven't heard of too many of the Hitachi ones failing.
Repair '91 Legacy head gasket in-car: an at-home job?
Legacy777 replied to Hondaman900's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe head gasket can be changed with the engine in the car. Space will probably be a little snug, but yes it can be done. Are you aware there is a bleed screw on the passenger side of the radiator? Open that, refill the coolant and see where you temps are. I'm not saying your head gasket is ok, but it sounds like you have an air pocket in there.
1991 Legacy, no dash lights
Legacy777 replied to rruoho98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup, check the fuse
Legacy777 replied to kevinC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have the Hitachi (silver) or JECS (black) MAF sensor?
