93 legacy wagon no reverse
Legacy777 replied to cw2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour tranny is probably going south. I've heard of others loosing just one gear/reverse. Eventually the problems will spread. Your probablem is more then likely in the valve body. You could try having it flushed....maybe something got lodged in there.
Did I fry the ECU?
Probably wouldn't start because the engine is super flooded. As for the lights on the dash....I don't really see how that's related. I'd try the battery disconnect first.
what ej heads can be swapped
Before anyone says anything will swap with anything.....what year/model engine do you have, and what are you looking to swap. Whether the engine is n/a or turbo brings in complexities, as well as what phase it is, exhaust port (single or dual port), intake manifold fitment, etc.
94 - 00 Legacy Blueprints
Legacy777 replied to Stew2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you just looking for pictures, or actual engineering drawings?
Alarm hookup - uh... ..... im stuck!
Legacy777 replied to n16ht5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmight help to specify what type of car/model/year
Relation gear of TZ102ZR2aa-MM and TZ102ZSAAAA-C3 automatic transmission
Legacy777 replied to piloto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check on www.bbs.legacycentral.org I think someone was asking for a transmission decoder from that number.....and I don't recall it was answered or not.
using the fwd option
Legacy777 replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBasically it controls the amount of lockup on the rear clutch plates....so essentually controlling AWD. Check out these scans, they may explain it better. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg
Legacy777 replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMis match tires can cause torque bind due to wheel speed differences. Torque bind when left alone I think is more likely to cause issues to the clutch plates, rather then the duty c solenoid, but I can't say for sure that the duty c solenoid wouldn't be affected by driving extended periods with mismatched tires.
Rear rotor removal
Legacy777 replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is NOT TRUE!! The rear rotors are most definitely slip on like the front. All the newer subarus are like this. That large nut holds the axle to the hub. You do NOT need to remove that to replace the rotor. Make sure you have removed the caliper & caliper bracket. There are two bolt holes on the rotor that you can screw a bolt in to help free it from the hub. I don't recall the thread pitch/size. If you don't plan to keep the rotors, bang on the front with a hammer to help loosen the rust.
Legacy777 replied to piloto's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's very possible the front and rear diff ratios are different. If you continue to drive it, you're going to kill the transmission again. You should be able to put a fuse in the FWD fuse holder next to the passenger side strut tower (on a left hand drive car). This will temporarily disable the AWD. Do you know what year car the new transmission came out of?
Legacy777 replied to Stew2000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe chances of you finding anything is going to be pretty slim. Typically engineering drawings like that are proprietary, and not floating around the general public.
Repacing Legacy engine
Legacy777 replied to Grahams101's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's possible something was restricting oil passages, or that subaru might be disassembling it to verify there's not a problem with manufacturing. I'd say, just be happy you got a new engine
Cost of CV Joint & wheel bearing replacement
Legacy777 replied to adwolf1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can buy a reman'd cv axle for around 55-60 bucks at autozone. They have a lifetime warranty. Labor, should run you about an hour or so... Wheel bearing....I've heard around 200-250.
Possible new owner Asking questions?
Legacy777 replied to kyriian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I'd say they're pretty reliable. You're going to find a lot more sti owners on http://forums.nasioc.com/forums I'd suggest asking over there as well.
Legacy 92" Dies when cold
Legacy777 replied to abanic1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the car sputter at all, or does it just instantly die? It might be the coolant temp sensor. Have you done any other troubleshooting/diagnostic to make sure you have fuel, spark, etc?
Normal behavior for fan?
Legacy777 replied to Bjornis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fan kicking in shouldn't cause that, however the AC compressor kicking in could.Other then that, not sure I can be of much help without knowing more. I'm assuming you've checked your coolant level in the radiator right?
Technical Illustrations of Engines
Legacy777 replied to Bradsit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmay find something on www.endwrench.com
Vent air ducts Stuck
Legacy777 replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you hear something moving when you push the buttons, it's possible the linkage is disconnected. Stick your head under the dash on the driver's side and have someone push the buttons on the hvac unit, and see if you see any levers move on the air box behind the stereo.
Legacy777 replied to bdecriscio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the older models the fuse holder is next to the passenger strut tower in the engine bay. On the newer models I believe it's in the fuse box in the engine bay.
No spark on #3 and #4 Cylinders?
Legacy777 replied to subaruVWnut's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the engine run, or is it just that you're getting CEL's for misfires.
hks super afr instal 2002 wrx?
Legacy777 replied to wes200x's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be able to find the info you need in one of these scans http://www.main.experiencetherave.com:8080/subaru_manual_scans/2002_WRX_FSM/
No steering lock?
Legacy777 replied to GoldDiggerRoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's supposed to lock. Have you tried turning the wheel all the way from left to right with the key out?
Legacy777 replied to Bjornis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your defrost or AC on? If so, the fans will be on.
B9 Tribeca Review
Legacy777 replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's a new gen vehicle....so we can talk about it right here.
Auot trans acting up?
Legacy777 replied to FSTOUR's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't sound like anything is really wrong. Some of the control logic in the newer automatics is a little weird, and that may be what you're experiencing.
