8
You're kidding? That's BS! I would've asked to talk to a manager right then and there. Yes if the car has been sitting in the hot sun, it will take a little bit to cool down, however the air coming from the vents should be cold. As for where to look. If you open the hood, the ac compressor is the furthest right thing that has a belt going to it. With the ac off, you'll see the front part of the compressor (clutch) not moving. With the AC on, you should see that clutch moving. Watch that clutch and see how often it engages/disengages.
I'd recommend the basics, just to rule them out, filters, plugs, etc. Fuel filter would be one of the things I'd suspicious about. Can you be a little more detailed about what exactly the car is doing. Does it only happen on hills? Does the engine cut out completely, or does it feel like it's just losing power. Is it an AT or MT?
The haynes AC & heating book has the specified amounts of oil needed. I can get you the info when I get back in town this weekend if you don't want to buy it. I wouldn't worry about humidity getting in. As long as they draw a deep vacuum for 30-45 minutes, you'll be fine. Only benefit would be to keep dirt and junk out.
No Start
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Pull the fuses and fusable links out and check for continuity across them. If they're not perfectly zero, they're probably bad. You may have a short somewhere too.
