Air Flow Sensor Problem
Legacy777 replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo all you did was install the CC? What wiring did you have to modify to get the cruise installed?
1990 legacy wagon electric fans cfm rating?
Legacy777 replied to Frank B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe factory manuals don't list a cfm. I doubt you'll find that info. It does list the motor wattage at 120 W
Name That Gasket...
Legacy777 replied to nebmaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's no reason for them to buy any sort of gasket kit to do those three things. The rear main seal is 10 bucks, tops. The rear cover they're talking about is more then likely the yellow looking thing on the right of the engine bell housing http://www.main.experiencetherave.com:8080/subaru/images/ej22t/DCP_3992.JPG It just takes rtv silicone to seal it. 4 bucks....tops. Oil pan is the same thing, uses rtv silicone to seal it. So to do those three things, the materials should not have exceeded $30-$40 at the VERY most. Get your car back, see exactly what it says they did on the invoice and let us know once you get it back and I can tell you if it's bogus or not
Name That Gasket...
Legacy777 replied to nebmaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat work were you having done? Unless they were rebuilding the motor, there was no reason to buy the engine rebuild gasket kit. Where in Houston are you? What shop did you take it to?
No Start
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe needs to clarify which lights he's talking about, and whether they dim, or if they turn off completely. As I said, the lights and other accessories turn off when the key is in the start position.
No Start
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlen's correct. The headlights, radio, acc, etc turn off when the ignition is in the start position. I'm telling you...it's the contacts.
Is a 94 Legacy Sunsport a good car?
Legacy777 replied to RallyJusty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe sunsport was just a special edition of the normal 94 wagon. It got a few tidbits here and there. As for all the swapping stuff, I'd ask over on the old gen side, they'd probably know.
AC cycling rapidly
Legacy777 replied to Simon Bennett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore then likely it's overcharged. If they're low on refrigerent, the compressor typically just runs all the time. I'd tell the dealer it's not normal, and that they need to fix it. If they won't, tell them, they'll be getting the bill when you take it to another shop. May also be worth complaining to SOA about the dealer and your problems.
AC compressor "stuck" on?
Legacy777 replied to BeefaRu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't really worry about it. It'd probably be a good idea to check pressures, but if everything's good, I wouldn't worry.
No Start
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you sure you are not hearing a click? When my starter solenoid contacts were giving me issues, I thought I didn't hear a click at first, but there was one. Open your window and listen carefully. If you hear a click, more then likely it's the solenoid contacts.
bypassing the clutch/starter interlock
Legacy777 replied to jib's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, you're probably one of the few/only ones I know of. I understand your reasons for wanting to do it, but it is a safety device that really should be there. What if someone else drives your car? I think the thrust bearing issue really isn't too big an issue. Oil does still remain in there. I hosed out the ej22t engine I am rebuilding with water and degreaser. This was with the heads off and oil pan off. When I split the block, there was still oil around the bearings. So for that short period of time at start up, I don't think it's a big deal. If you want to use your starter without pressing the clutch, you should tie a toggle/push button switch in parallel to the clutch start switch. That way, under normal circumstances, and when other people drive your car, everything works as supposed to. Yet when an "emergency" occurs or when you want to, you can start the car without depressing the clutch.
Loose Harmonic Balancer
Legacy777 replied to subaru424's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes, on the pass side of the engine bell housing http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2486.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2487.JPG http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2488.JPG
ADVICE Please ... 94 Legacy for $2700
Legacy777 replied to bivywack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost people typically rip out the air suspension and put regular struts & springs. If it comes to needing to replace the suspension, I'd highly recommend that route, compared to repairing the air suspension. $1000 is a little on the light side for the air suspension in my opinion. I'd say you could probably replace the air suspension with springs & struts for 500 or so for parts. There are other subaru model springs that will work, so you can usually find used stuff for cheap that will work. Clutch....I guess it's your standard job...about 4-5 hours or so. So probably around 400-500 bucks. to have a shop do it. Just a guess.
crank sensor R&R TB?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the link work? You need to RIGHT CLICK AND SAVE AS the pdf document. Do NOT try and open it from the web.
93 Legacy Station Wagon CEL, Long Question
Legacy777 replied to Chapster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake off one of the plastic end caps of the timing belt cover and check the timing belt to see if it's still tight. Only other thing I can think of is the wiring from the cam sensor is bad. However that typically doesn't go bad instantaneously
Hello sub board !!
Legacy777 replied to fubar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out my site http://www.surrealmirage.com/subaru/subaru.html Go to notes & tips, engine related. It tells how to pull the codes via check connectors.
CV joint leaking
Legacy777 replied to cmac's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe red fluid is more then likely automatic trans fluid. It's probably not leaking out of the front diff....or it shouldn't. The front diff should have differential fluid which is typically brownish. I would check the front diff level and atf fluid. Either way, it should be ok in driving it to the mechanic.
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitch the crappy manuals and d/l the factory one from me. http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ It's for the 92, however most of the stuff is the same.
2002 Impreza RS Cupholder sticks
Legacy777 replied to kleaving1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmay want to also try http://forums.nasioc.com/forums
91 Legacy Tranny
Legacy777 replied to 98impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, no I don't know what the 98's final drive ratio is.
91 Legacy Tranny
Legacy777 replied to 98impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4.111 is the final drive ratio.
AC charge
Legacy777 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe expansion valve is basically an orifice. When you're low on refrigerent, it has to cut pressure quite a bit to maintain a cool temperature. The larger the pressure cut, the more noise you're going to get. Add some refrigerent and it should go away. I'm going to try and add some to my truck tonight.
AC charge
Legacy777 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's sort of loaded question, because in order to properly explain it I have to explain the entire ac system Anyway, here's a quick and dirty of the parts in your ac system, and how they work. The following is the order in which the refrigerent & oil go in. Compressor Condensor Receiver/drier Expansion Valve Evaporator The refrigerent is in gas form, and goes through the compressor, its pressure increases as well as its temperature. The refrigerent then goes through the condensor where it loses heat, and condenses into a liquid. The reciever is more or less a filter, and contains dessicant to help remove moisture. Next you have the expansion valve. The valve cuts the pressure & temperature of the refrigerent. The refrigerent also goes from liquid to gas through the valve. The cold refrigerent then goes through the evaporator where the air blows across it to get cold and go into the cabin. Then the process repeats. there's more theory behind it, but that's the jist of it. Here's a link with a pic http://home.howstuffworks.com/ac2.htm
rear strut q's
Legacy777 replied to slipspeedy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo they will not work.
AC charge
Legacy777 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy expansion valve is hissing at me after my recharge. It probably needs a little more refrigerent.
