Loose Harmonic Balancer
Legacy777 replied to Legacy Ree's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt probably won't stay tightened because the torque spec in the manuals are incorrect. It should be torqued to about 120 ft/lbs
need 1990 legacy starter info
Legacy777 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4 posts down will have a link to where you purchase the contacts from http://www.ultimatesubaru.org/forum/showthread.php?t=2447&page=9&pp=10&highlight=start+secret
Brake problem
Legacy777 replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have to buy subaru pads in order to get new shims.....
Washing Transmission?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's still sealed up, the only entry point is the vent lines. If you change both the diff & at trans fluid when you get it, I don't think you'll have any issues. For more precaution, after you have it in the car and driven around for a couple hundred miles, change the fluid again.
wrx powered porsche 914, Pics!!
That's pretty damn cool!!
gear ratios??
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's really not that hard to change out the diff if you have the right tools and know how. If you have limited mechanical knowledge, I don't know if I'd recommend doing it yourself since some parts can be a little tricky. I believe there are newer AT's with a 4.111 final drive ratio. However if you go too new, then you run into wiring differences. I'd say if you can't a 4.111 trans, but you can find a 3.90 one, just swap the rear diff. I don't think labor costs would sky rocket.
92 Legacy Problems
Legacy777 replied to mkap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not saying it's not a headgasket issue, however I would recommend bleeding the system using the bleed screw if you haven't already done that.
Just Got Her home..
Legacy777 replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice! Did you pick it up from another board member?
92 Legacy Problems
Legacy777 replied to mkap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you getting heat from the vents? There is an air bleed screw on the passenger side of the radiator that needs to be unscrewed to allow air to be bled of the system.
Speed-O-Meter
Legacy777 replied to jrbuckingham's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you get a check engine light or anything when the speedometer doesn't work?
ej22t teardown and rebuild pics
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt'd be less work if I wasn't completely rebuilding the motor, but for me, I might as well. You could always buy a built motor... Still, I think the motor swap will be much less work then the AWD & 5spd swap http://www.surrealmirage.com/subaru/swap
timing belt help
Legacy777 replied to 68ragtop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year legacy? Here's factory scans for the SOHC 2.2 http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg Also, here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt
AC control question
Legacy777 replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour ISP probably blocks port 8080, that or you're using a proxy server on that port.
gear ratios??
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not that the tranny changed.....they just changed the final drive ratio and some of the gearing. I believe 1st & 2nd is different. 3rd & 4th are the same.
need key made for 91 awd legacy
Legacy777 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe key itself should have the key code on it as well. I didn't have luck with the door lock.
Brake problem
Legacy777 replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can put some disc quieter stuff on the back of the brake pads. I'd say the noise you are hearing is pretty common. What happens is the pad vibrates with light pedal pressure, mostly due to them not fitting real tight. With the goop on the back of the pad, it helps absorb the noise from pads.
I probably posted various pics before, but I made a page that I'll be updating as I go along. http://www.main.experiencetherave.com:8080/subaru/images/ej22t/ I split the block today, and cleaned the crank up. The rod bearings definitely need to be replaced. The crank bearings are ok, but I'm going to replace them anyway. I need to get the cylinders honed, and I'll be set to put her back together
1990 legacy need tips on pulling motor & saving airconditioning R-12
Legacy777 replied to hearnmike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't need to pull the motor to do the head gasket. It does make it a hell of a lot easier though.
Can i Re-Charge the AC myself?
Legacy777 replied to Andyjo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe r134a systems, you should be able to add refrigerant yourself. Unless you can get a hold of R12, you'll have to take it somewhere, or convert it to 134a. I've got a write up on here. I wouldn't recommend mixing refrigerents. Never heard of 414b.
Front crossmember
Legacy777 replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the bolt positioning where the crossmember bolts to the chassis the same on both sides? If not, then the chassis is probably tweaked, and there's probably not much you can do. A frame pulling machine might make it a little better, but I doubt it'd be perfect.
96 GTB Legacy Wagon, problem that no one seems to know how to fix...
Legacy777 replied to mackryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe older cars had the two temp sensors. The large one went to the ECU. The smaller just went to the gauge, and has no effect in how the car runs.
AWD to FWD conversion?
Legacy777 replied to chriskatana's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you do go with an AWD trans replacement from a different year/car. Make sure you check that the front diff has the same gear ratio as your rear.
2.5 rebuild
I would think the pans are similar Don't know the costs for the 2.5 specifically, but the ej22t motor, rings cost around $118. Pistons run about $55 a piece. If you decide to split the block, which you probably don't need to, you should replace the bearings. You said the engine had only a slight tick? Any idea what was causing the tick? It might be a good idea to check the bearings if oil starvation might have been an issue.
AC control question
Legacy777 replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it work now? If you're still having issues, try this https://www.mail.experiencetherave.com/subaru/techinfo/ac_control_wiring.doc
Opinions please..
Legacy777 replied to badjer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd probably put the 2k in for the tranny. Just my 2 cents.
