E Brake dummy light
Legacy777 replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your brake fluid level. The ebrake light is tied into the low fluid warning system.
2.5 DOHC Timing Belt
Legacy777 replied to jfm2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow much out of whack is it?
Check Engine Light
Legacy777 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst of all Do NOT post in all caps! It's like you're yelling. Second, you've provided zero information on the specific car, model, engine, etc. Personally, I'd reset the ECU and see if the CEL goes away. Pull the battery cable for 30-45 min.
Front brake rotors : a question about quality
Legacy777 replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's really cheap for rotors. They'd "probably" be ok....but couldn't tell you how long they'll last.
Subaru mechanic suggestions?
Legacy777 replied to tjay460's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHopefully someone on the board is from your area. You may also want to try http://forums.nasioc.com/forums to see who's in your area. As for the shops. For headgaskets. I'd probably take it to the dealer, or a subaru specific shop.
New 2005 Legacy - Add an AUX input (mini-phone jack)?
Legacy777 replied to dmplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe the guys on www.legacygt.com have gone over this. They may have a solution.
EJ22 Turbo swap to EJ20 Turbo
Legacy777 replied to 93LegSportTurb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSearch on www.bbs.legacycentral.org There are some guys that have done this swap, and ran into the same issue.
90 legacy with door lock that sticks
Legacy777 replied to jelly man's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere's the problem, and the fix http://www.geocities.com/hobiegary/locks.html
'95 Legacy A/C ???
Legacy777 replied to Handtool's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSimple answer is you can't take the clutch off, you need to replace the whole compressor. Yes you need discharge the system to replace the compressor. I'd really recommend taking it to a shop. AC work is one of those things that even for someone with all the equipment is a little tricky. Spend 30 bucks or something for a diagnostic. A shop should at least be able to give you an idea of what might be wrong, and costs. If you take it to a shop, report back on what they say. Some shops like to just replace everything for lots of money.....which isn't necessary.
CEL w/ code 400 Evap -keeps reappearing-HELP!
Legacy777 replied to vintagejoe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat car is this on? also, I haven't really heard of code 400. Is it just a generic evaporative emissions code?
93 ac compressor
Legacy777 replied to jimscat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have the haynes hvac book there is a table that has the info. In 93, the calsonic system used 8 oz of oil. The zexel system used 5.10. In 95, the system used 5.30. So depending on what system you have, you'll have to split it or something.
Erratic running Outback, surging, code P0172
Legacy777 replied to TheCorkans's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXautomatic or manual tranny? I'd do the fuel filter. It sounds more electrical then mechanical, and the pump and regulator usually don't fail
Intake Manifold Gasket Question
Legacy777 replied to A_DuB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they should be the same.
Help! Losing power up-hill only in 4th or 5th gear!
Legacy777 replied to misstat2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou're talking about an auto transmission correct? The manual tranny has two electrical inputs. Neutral switch & reverse lights. Neither of them will cause those issues.
Legacy Spindle ?
Legacy777 replied to jmlaser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah the spindles should be the same.
91 Legacy, retreived codes...help
Legacy777 replied to 1phtram's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat I'd recommend doing is resetting the ECU, drive the car around, and see what codes come back.
Legacy Engine in Forester ???
Legacy777 replied to motor275's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLegacy engine? You sure it's just not a 2.5 engine meant to be in there. If it hasn't been swapped, it's supposed to be in there, and I don't think napa knows what they're talking about. Just my thoughts.
Legacy777 replied to misstat2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just can't see how a MT can affect the engine/ecu. The tranny is pretty much all mechanical..... If you go up the hill in 3rd, does it still happen?
plastic slinger plate?
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnever heard of one. There is a plastic oil separator plate that is between the block and the vent for the PCV valve. No need to replace it. It's just a plastic plate.
AC cycling rapidly
Legacy777 replied to Simon Bennett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe radiator fans will cylce depending on engine temp, as well as whether the AC compressor is engaged. Either way, you gotta watch the fans/compressor.
More part numbers
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey'll work
AC cycling rapidly
Legacy777 replied to Simon Bennett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're kidding? That's BS! I would've asked to talk to a manager right then and there. Yes if the car has been sitting in the hot sun, it will take a little bit to cool down, however the air coming from the vents should be cold. As for where to look. If you open the hood, the ac compressor is the furthest right thing that has a belt going to it. With the ac off, you'll see the front part of the compressor (clutch) not moving. With the AC on, you should see that clutch moving. Watch that clutch and see how often it engages/disengages.
AC cycling rapidly
Legacy777 replied to Simon Bennett's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about the HVAC blower fan? Do you have auto climate control? Its speed should stay constant on which ever setting you have it on.
AC signal of 2 wire VSS
Legacy777 replied to itzik93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy bad! Spaced, and was thinking about the older VSS.
impreza oil pressure low light inop
Legacy777 replied to birdfalk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere's the oil pressure sender. It's below the alternator http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2480.JPG
