Finally Bought My Subie & P.Brake Handle Price?
Legacy777 replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have a part # for the parking brake stuff? If you do, you can check prices yourself https://www.subarugenuineparts.com/oe_parts_cat.html actually, you may be able to find it by browsing through the catalog
AC charge
Legacy777 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys need to let the refrigerent cans sit there for a little while. Set them in the engine bay where it's hot. It helps get most of the refrigerent out. I just redid my truck on saturday. Pulled a vacuum for about 30-45 min, Let the one can put as much as it could in without the engine running. When it stablized, I turned on the engine, and let it draw the refrigerent out of the can. Like I said, be patient.
Input on new Soob purchase
Legacy777 replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCarl, I believe there is a sport shift on the autos. However I can't really say how they are. I'd recommend just goin and test drive the different models. You're in the Dallas area right? Give Subaru of Dallas a try. Talk to Kevin Heist. He's one of the guys on the texas subaru boards on nasioc. Tell him I told you to see him. He "should" be able to work with you to get a pretty good price.
Alternator amps?
Legacy777 replied to Sweden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, 75 amps sounds ok. You could email one of the online subaru parts dealers here and ask them what the part # is. I'd suggest dropping Jamie an email www.subarugenuineparts.com or www.libertysubaru.com
Engine pull - Will need A/C Conversion?
Legacy777 replied to subiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to move the compressor off to the side as well. As for converting it. Read this http://www.ultimatesubaru.org/forum/showthread.php?t=2442&page=1&pp=10&highlight=134a+conversion
2005 Outback Headlight bulb question...
Legacy777 replied to absorka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, keep the bulbs you have. The silverstars have a tint on the bulb that filters the light. So with the same wattage bulb, the ones with filters will output less because some of the light is being stopped by the filters.
93 legacy sunroof
Legacy777 replied to BRUCEC's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBruce, You already have a post asking this question. No need to start a new thread.
95 legacy AWD tranny
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat adjustment bolts are you talking about?
GT struts questions
Legacy777 replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey should work fine. I can't confirm the strut top mount difference. I don't think there should be any though.
hood latch cable
Legacy777 replied to rbregn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think there's an adjustment. It's either at the handle side, or the latch side.
G0NE at 75 mph... do i need that?
Legacy777 replied to Starkapopolis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can find one, it'd probably be worth replacing.
2001 outback clutch
Legacy777 replied to chuckj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's pretty straight forward. I believe the clutch fork design is the same. So if you've done clutches in the older guys, you should be good.
So apparently detonation doesnt kill engines...*dyno charts!*
Legacy777 replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny codes stored in the ECU? Have you checked your knock sensor? I wonder if it's not working. You might want to test it. Replace it, and then reset the ECU.
Atf????
Legacy777 replied to mtbshark's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRedline D4 ATF is good stuff.
Timing belt help needed for Subaru Legacy
Legacy777 replied to donkijote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou don't need to align anything for TDC. You align the marks on the cams and crank to the marks on the cover and oil pump. Are you sure you're using the correct mark on the crank gear. Don't use the arrrow on the front of the gear. Use the mark on the back of the one tab. Here's pics of my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt/ Factory manual scans for the timing belt job http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt3.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt4.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt5.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt6.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt7.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
ej22t computer question
Legacy777 replied to Jerry DeMoss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs of right now, the only way to do that is with a piggy back computer or stand alone. The perfect power piggyback ECU looks to be pretty good. It's sold by www.rallitek.com some guys over on www.bbs.legacycentral.org are working on hacking the stock ecu.
MAP Sensor Testing
Legacy777 replied to mwd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did not notice a difference in reduction of hesitation with the washers. This was before it came loose. So I just removed them. The "hesitation" I was experiencing was related to the automatic transmission. Once I did my swap, I didn't have any hesitation issues.
atf fluid change
Legacy777 replied to louie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXATF fluid is not a lifetime fluid. Frequent changes will definitely prolong the life of the tranny.
Legacy'90 and code 35
Legacy777 replied to Roman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe canister purge solenoid can intermittantly mess up, and cause the CEL to be illuminated. I drove across country, my CEL would pop on and off for a state or two. I'd recommend just replacing it. If the solenoid sticks open, it can cause poor idle issues, but other then that, it shouldn't be a big deal You can buy the solenoid online from https://www.subarugenuineparts.com/oe_parts_cat.html part # is 14774AA351
MAP Sensor Testing
Legacy777 replied to mwd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe teflon washer thing really doesn't work. I tried it, it made no difference, and the bolt actually came loose, creating more issues. 115k on the orig O2 sensor.....it's probably time to be replaced. Check out https://www.subarugenuineparts.com/oe_parts_cat.html
tranny slip '99 Forester automatic 4 cyl
Legacy777 replied to catboat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt might be a sticking valve or solenoid. There isn't a filter, just an internal screen. The newer ones got a spin on external filter, however I don't know how effective it is. It's probably just a screen type filter as well. Other then putting some synthetic trans fluid in, not sure what else to suggest.
Need testing specs!!
Legacy777 replied to Midwst's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's for a 92, but should be the same http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/
Impreza strut bar on Legacy?
Legacy777 replied to mattyg41383's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I have impreza RS strut bars on my legacy. The front fit without modification. The rear required a little bending of the plate to angle it correctly
Locked Differential!HELP!
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't quite understand what you're asking. Can you provide some clarification.
replace knock sensor
Legacy777 replied to Sabres19's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXknock sensor is the thing with the white connector http://www.main.experiencetherave.com:8080/subaru/images/injectors/DCP_2481.JPG
