8
Front Seals?
Legacy777 replied to rbregn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
that's from my 90 legacy ej22. The newer DOHC engines are not the same. I'm not sure if the SOHC 2.5's are the same or not. -
You'll have to remove the rear extension housing on the transmisson. It can be done with it still in the car. The plates and everything associated with the rear power transfer should be checked or replaced. Here's some blow up diagrams that should give you an idea of things. http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/AWD_transfer_system3.jpg
If you haven't overfilled it, you shouldn't have caused a leak by doing what you did. Just an FYI. To properly check the fluid level, the trans needs to be brought up to normal operating temp. Park the car on a level surface, slowly move the gear selector from Park to 1, and then back to Park. Leave the car running, and then check the fluid level of the transmission.
Front Seals?
Just for your viewing pleasure. Here's pics from my timing belt job http://www.main.experiencetherave.com:8080/subaru/images/timingbelt Also....as for a manual...this will probably be helpful http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ -
Instructions to pull the trans codes are on my site under the notes & tips section, trans related. TCU can be seen in this pic http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg Did they tow the car with all four wheels off the ground? If not, the transmission probably got toasted. The AT inhibitor is in the transmission itself.
Added pics from taking the heads off. I'm not sure what I'm going to do yet. It's filthy and needs to be cleaned. I'm not sure if putting it in the parts washer is a good thing to do or not. I'd like to replace the piston rings...even if I don't tear the block halves apart. I need to figure out what I'm going to do.....make some calls, check costs and such. I wash my hands and take a bunch of pictures
Sport Wagon Heater/Fan
Legacy777 replied to Scooby-Doo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
goin to move this to the old gen side. You should get more response over there. -
No they are tied together. It get's a little complicated to explain, but I'll do my best. The big thing most people don't see is that the drive pinion shaft runs through the center of the driven shaft. They both are splined and input into the center diff. Rather then me try to explain this in a million words. Check out these scans Drive pinion & driven shaft. You can see that one goes inside the other http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_AWD_drive_pinion_assy.jpg Description of the center diff & awd system http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/MT_centerdiff3.jpg
