hi all please help
Legacy777 replied to amjid55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey're both oxygen sensors. The first oxygen sensor sends information to the ECU for a/f ratio control. The second oxygen sensor is a catalytic converter efficiency monitor. The second oxygen sensor is not really necessary to run, but it will throw a check engine light.
STi ATV
please continue discussion in the original thread http://www.ultimatesubaru.org/forum/showthread.php?t=34407
STi-ATV? Check this out!
Legacy777 replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis was posted in OT http://www.ultimatesubaru.org/forum/showthread.php?t=34407 Please continue the discussion there. Thanks
Advice On Anti-Lift Kit.
Legacy777 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe thing about this kit....and the reason I haven't gotten one is that it removes it lift from the suspension geometry. There's actually anti-dive built into the stock suspension setup. With the anti-lift kit, you remove the anti-dive. So the car has the tendancy to dive more under braking and what not. The increase in the amount of dive is said not to be much, and the amount will definitely depend on your suspension setup. I will probably just be replacing that rear link with an upgraded link that is stock in geometry, but has the stiffer bushing.
starting problem w/ 90 legacy
Legacy777 replied to pirata's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup, check codes, and tell us what you find out. Instructions for checking the codes can be found on my site.
92 FWD Legacy Differential Interchange??
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwelcome. yeah I still need the turbo ECU....it didn't pan out
Legacy777 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood deal
Brakes on SVX
Legacy777 replied to PetterFan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRead the article I wrote up. It gives you the jist of why I don't recommend drilled rotors. The summary of it is....a rotor is a heat sink....the more material there is, the more heat it can hold. Drilled rotors remove material from the rotor, and reduce the amount of heat it can absorb. I go into more details in my writeup what the purposes of cross-drilling & slotting are for, but the majority of the reasons they originally used that technology was the brake pads. Brake pads have come a long way, and those original reasons why they used slotting & cross-drilling aren't really an issue any more.
Legacy777 replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't done this, but I've looked into it. I'm pretty sure there's a write up on scoobymods, and some more info on nasioc. May want to try looking there as well.
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny of the FWD differentials should work.
Main Fan not kick on
Legacy777 replied to Zeky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ECU is the MPFI unit.
Brakes on SVX
Legacy777 replied to PetterFan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor a street car.....neither. If you must have something, I'd go slotted. http://www.surrealmirage.com/subaru/brakes.html I'd actually recommend cryo-treating the rotors over anything.
Outback tranny swap
Legacy777 replied to suba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXread my swap writeup www.surrealmirage.com/subaru/swap Granted I added awd, but that was relatively easy. There is a lot of components and things you need to take into consideration. It's not super difficult, but it is time consuming, and the challenge is keeping track of everything, and knowing exactly what to do. You will have more issues with electronics because it is OBD2.
WRX reliability
Legacy777 replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubaru has been using the ej20 motor since at least 1990. It's gone through revisions, but it is a very stable platform. In stock form, I haven't really heard too many issues. If people start upping boost or playing around, I have heard of issues.....
air suspension to gas strut swap
Legacy777 replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemember there is a difference in the rear springs & top mounts between the 90-91 & 92-94 legacies. However that's not really an issue. All the 90-94 AWD rear struts are interchangeable, and will bolt up to your rear knuckle. However, like the KYB guy said, there are some height differences between the model years. The 95-99 rear struts will mount up to the knuckle, I don't care what the KYB guy said. I can't however comment on the perch height/ride height.......so that you'll have to deal with. Bottom line....get rear AWD struts and the springs to go with them, and bolt them up. If it sits sort of weird afterwards, you then know you may need to play around with the different struts to get your ride height correct.
vehicle speed sensor location???
Legacy777 replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, I looked at the fsm. The speed sensors are located on the driver's side of the transmission towards the rear. There are actually three. The rear most one, located on the rear extension housing is the vehicle speed sensor 1. The next one front and near the top of the rear of the main transmission case is the vehicle speed sensor 2. The furthest one forward is the torque converter turbine speed sensor.
95 Legacy Gt-B Spec Diff Lock ?
Legacy777 replied to krypton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne way you could check is jack the car up off of all four wheels, put the fuse in and see if you can stop the rear wheels from spinning....or see if they're not spinning at all. Gently applying the ebrake would be the easiest way to accomplish this. If the motor doesn't bog or speed start to slow down, then you know that's what the fuse is for. Try the test again, but this time with the fuse out. Don't hold the ebrake on very long with the fuse out.....it's bad.
Legacy777 replied to Chef's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRear struts on a FWD car are different then the rear struts on an AWD car, and are not compatible. There's a possibility that the strut top mounts and possibly the springs are different as well. I don't know for sure. I'd really try and find struts, springs, & top hats from an AWD car. The struts you picked up will connect to the knuckle in the front....that's not a problem. If you pick up KYB struts....get the ones for the 92-94 legacy. I would highly recommend getting 4 struts rather then just 2. You can severely alter the handling characteristics of the vehicle. I speak from experience, and it can cause the rear end of the car to spin out a lot easier, etc.
Legacy777 replied to krypton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwith how the MPT designed automatic transmission AWD system is, adding a fuse will not make it 50/50 torque split. The only way to get 50/50 all the time is if the duty c solenoid completely fails.
Legacy GT Diff Lock Fuse
Legacy777 replied to krypton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease do not start more then one thread of the same question. If you have further questions, or didn't get your original question answered, please address it in your original thread http://www.ultimatesubaru.org/forum/showthread.php?t=34447 thanks
anyone have CEL issues? with no codes stored?
Legacy777 replied to Ratty2Austin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to check the codes yourself. I'm pretty sure the 94 impreza was still OBD1. The procedure should be the same as the legacy, and instructions are on my site. As for not leaving codes....yeah I've heard of it happening.....but I'd suggest checking the codes yourself.
How to fix Idle Control System Malfunction (P1507)?
Legacy777 replied to RodA2003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the CEL on all the time, or did it go on once, and you get that code. If it's not on all the time, I'd suggest just driving it, and keeping an eye on things. The idle air control valve may have had a hiccup, or it may be sticking due to carbon build up.
Legacy777 replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know which speed sensor it is? Speed sensor 1 is inside the tranny I believe, and I think speed sensor 2 (which feeds the speedometer) is accessible on the outside. I believe it up near the top of the front diff on the passenger side.
Legacy777 replied to krypton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd say it's probably the same thing as the FWD fuse holder to make the car FWD. Do you have an owner's manual? It should say in there.
Legacy777 replied to Zeky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you unplug the two wire coolant temp sensor, the fans should come on. pic of the ECU http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg
