Ecu and Fuel Pump
Legacy777 replied to A_DuB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, the ECU triggers the fuel pump relay to turn on. The rollover valve is mechanical, and not electronic, so it's probably not that. Have you put a tester on the fuel line to see if there is any pressure at any time?
I am getting a code 9?
Legacy777 replied to SuperRallyRoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's the abs computer http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/absdiag.jpg
Electrical Demons - Need an Excorsist
Legacy777 replied to 91subaru-Bruce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmmm.....something definitely sounds screwy. I don't really see how just plugging the alternator in could cause all that. Did you try and put a voltmeter on the plug for the alternator? The two smaller leads are sense & light, and shouldn't have anything coming from them. The fatter wire is the ignition lead telling the alternator it's ok to "turn on" and make power now. You should have 12v on that when the key is turned to the ignition, and no other times. Check that plug and see what you find out. You've definitely got some sort of wiring issue. I'd look around at all your wires in the engine bay and up under the dash and make sure no animals have chewed through them.
Class Action Lawsuit Re: Blown Head Gaskets/ Cracked Heads/ Overheating
Legacy777 replied to oldblackbeard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, please do not post in all caps.
94 Legacy Vehicle Speed Sensors
Legacy777 replied to emurray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah it sounds like the plastic speedo gear is busted. It's not too common for the gears to break, or at least that I've heard of. Far more common for the base piece to break. It's possible it broke on its own, but who's to say, and I'm not sure what the mechanic would've/could've done to break it. On the automatics since the gear goes to the diff, you don't have to take apart the tranny, but it still needs to be removed, the torque converter taken out, and the diff & tranny unbolted from each other. Regardless, not exactly a simple job.
Now that ISRperformance.com has became...
Legacy777 replied to lepetitprince's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXisr & renick are one in the same.
Legacy777 replied to emurray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe speedo cable is pretty easy to spot. Just follow it where it goes into the tranny. When you pull the base piece off, it should be pretty obvious if it's busted or not. Make sure you get the rubber piece and metal washer out of there as well. What I did was jack up the front of the car and turned the wheel to see if the gear in the tranny was still working. Once I knew that was fine, I just put everything back together. BTW, you can see the base piece in this pic http://www.surrealmirage.com/subaru/images/swap/09/DCP_3217.JPG It's just in front of the filler tube on the right side of the tranny/diff.
Cruise control doesn't work. Due to speedo dying???
your cruise won't work without the speedo working. There's actually quite a bit of stuff that will behave weirdly without the speedo working.
Legacy wants to stall after start-up then smooths out
Sounds like the idle air control valve sticking. Do you have any other symptoms, or just that? You may want to pull the tube off the intake tube that goes to the idle air control valve and shoot some brake cleaner down there. It'll help get rid of any carbon build ups that may be causing the valve to stick.
Driver's door lock
Legacy777 replied to Spazz698's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo it just started doing this?
Legacy777 replied to emurray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe speed sensor 2, which controls your speedometer is in the dash. The other is in the tail housing of the tranny. More then likely it's the speedo base piece. Here's 2 threads you can look over for more info. Fix the base piece, and then see how things are working. http://www.ultimatesubaru.org/forum/showthread.php?t=27614&highlight=speed+cable+base http://www.ultimatesubaru.org/forum/showthread.php?t=23812&highlight=speed+cable+base
Auto bucking sensation when torque converter is engaged
Legacy777 replied to Inday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't really think a different fluid will do much else, synthetic might be better since it'll probably clean the insides a little more. Unfortunately, I don't know of anything else you can do. Seafoam makes stuff called transtune. I haven't used it, but have used their engine product. If you can find the transtune stuff, it might help www.seafoamsales.com
Driver's door lock
Legacy777 replied to Spazz698's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo know you have to hold up the handle when closing the driver & passenger front doors for them to stay locked? Try holding the handle up as you shut the door, and it'll probably stay locked.
Legacy777 replied to Inday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine used to do that. Have you changed the fluid recently? I'd suggest that as a first step to try and help. Maybe put some synthetic fluid in.
Seat Belt Retractor issue
Legacy777 replied to nowbiteme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you look in the center console there is an allen wrench type thing. At the base of the pillar between the front and rear doors there is a little round clip/flap. Take that out, and insert the allen wrench into the hex head bolt. You can turn that, and the motor will move, and the seat belt should move. You should be able to manually crank the seat belt in a position so you have a working seatbelt.
Which AWD system, MT or Auto?
Legacy777 replied to the_eleven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo be quite honest, you really can't compare AT's to MT's. It's like comparing apples to oranges. Final drive ratio is different, AT's have torque multiplication, etc, etc.
Legacy777 replied to the_eleven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe old 4eat's are not the same as the new ones. In terms of AWD, the new VTD 4eat's have a better AWD sysetm then the 5mt's which has been the same for a while now.
90 Auto Legacy with stuck key
Legacy777 replied to Jeffk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRead these pages from the owner's manual http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/065.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/066.jpg It shows where the button is.
Legacy777 replied to Jeffk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a button under the steering column you can push to get the key out.
Brake Booster?
Here's what I'd suggest doing to determine whether it's the booster or vacuum line. Take the line off the booster, plug it with something. Start the car, and then wiggle around the vacuum line and see if the engine stalls/bogs down. Unfortunately, I'd probably say that it's the booster. You could probably swap boosters from a similar model and model year near yours.
Synthetic in tranny voids warranty?
Legacy777 replied to SubaruAl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt never ceases to amaze me what they come up with....that bra one takes the cake as the top one.
Legacy777 replied to SubaruAl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally I think the dealer is full of it. Unless it specifically states not to use synthetic in the transmission I don't see why you couldn't be able to. I'd try email subaru of america directly and ask them what their official stance is. Dealers are notorious for making up stupid things like this.
new here and starting immediate with questioning...
Legacy777 replied to Victor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome, The factory manuals are the best. Your local subaru dealership may be able to get them, but may not. Ebay sometimes has people selling cd's with manuals on them. I think Haynes or Chiltons also has a book out as well. You can d/l factory manual info from subaru http://techinfo.subaru.com It's going to be mainly for the US cars, but the info should be similar if not the same for yours. Yeah that's about normal mileage for struts to need to be replaced. I'd strongly recommend replacing all four. The reasoning for this is that the new struts will more then likely provide better response/stiffer and can throw off the handling characteristics of the car. I had this happen with my legacy when I had mix-matched struts on. I'd suggest a set of KYB GR2's. They are priced well, and provide excellent performance for their cost. The locking mechanism. I don't know personally, there may be some impreza people that might know. If you can get a hold of wiring diagrams or manuals, that should tell you for sure.
90 legacy 2.2 uneven acceleration
Legacy777 replied to Brayburks's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably a bad coolant temp sensor. They're pretty cheap. I'd just replace it. Clogged cats typically get worse as the car warms up.
Fuel Needle playing up
Legacy777 replied to Luis_H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust to clarify. There are two fuel sending units only if you have AWD. As to the gauge problem. The contacts on the senders can get corroded. What you can do is take them out of the tank. (access panels are in the trunk if you have a sedan, or behind the seat if you have a wagon.) Then take some emery cloth or fine sand paper and buff the contacts so the metal is clean and the contacts make good connection with the electrode.
