8
They can be rebuilt, however unless you have a place that knows ac stuff and deals with rebuilding compressors on a regular basis, you're better off just getting another compressor. You can try and get a used compressor, and then when the current dies, just put the used one in. Flush the system, replace the receiver/dryer, add oil, pull a vaccum, and recharge the system.
It's "possible" that not having the kit installed may have led to a premature failure. The filter is more of a screen meant to catch larger particles. How many miles are on the car? Was the transmission fluid changed routinely? My AT had about 179k miles on it, and it was pretty much done. It still worked, but shifts were sluggish, and it slipped. To get it back to new, it would've needed a complete rebuild, which I didn't want to do, so I put in an MT.
I'm not trying to shun people from this board, it's just that there are a lot more people who actually own the new GT between the other two boards mentioned, which may give them some more info that they otherwise would not be able to get here. this is pretty much the same reason I recommend people to the legacycentral bbs. There are people that are on both this board and other boards, but why not give someone the information/opportunity to gather more info using another resource.
You can use pads other then OEM and not have squeaking issues. It's true that some aftermarket pads do squeak. So decent pads are axxis metal master and ultimates. There's a few others, but with the rear pads they don't do much braking anyway. As for rotors, most of the brembro rotors you see are just going to be in brembro boxes, and not actually be manufactured by brembro. I personally like OEM rotors....but that's just my opinion.
27mpg is damn good for that car. I'd be lucky to get 25 around town. I can push 30 mpg on the interstate if I'm not hauling arse and stay out of it. As for the whistle. I had a whistle that turned out to be a hole in the muffler. If your muffler is original and looks in bad shape.....it wouldn't surprise me if that's the culprit. Have you had someone sit in the car and you be out side and walk around, trying to find the whistle.
Fuel Pump???
Legacy777 replied to A_DuB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The clicking noise is fine when the green connectors are connected. The pump should definitely see 12v, or whatever the battery is seeing. What's the voltage at the pump? Not sure how to get rid of the clicking noise coming from the abs....you're talking about the ABS computer, relay, or control unit in the engine bay? -
Fuel Pump???
This scan got cut off, but it shows the location of the relay http://www.surrealmirage.com/subaru/files/swap/elect_unit_loc/6-3_electrical_unit_location03.jpg The clicking you're hearing. Are the green or black diagnostic connectors connected? They're under the dash. You can check out my site for info and pics. -
How are you checking the level?To properly check the level, the transmission fluid needs to be at normal operating temp. Driven around for a couple miles. Park the car on a level surface, slowly cycle the gear selector from park to 1st and then back to park. Leave the engine running, and then check fluid level.
Fuel Pump???
There is no fuse, only a relay What model year legacy is it? -
The dipstick for the front differential is on the right (passenger) side of the tranny. The transmission fluid level dipstick is on the left (driver's) side of the tranny. What I'd do is put a fuse in the FWD fuse holder and see if the issues go away. If so, your problem is with the rear extension housing/awd system. I'd suggest replacing the fluid first, and see if that helps the problem. If you do have to replace/repair the clutch packs you don't need to replace the entire transmission.
I'd probably replace the anti-sway bar bushings with polyurethane ones, as well as get new end links. The front bushing on the control arm is pressed in, and you'd need a press for that. I'm not sure of any aftermarket bushings for that one. The rear bushing on the control arm should be able to be removed without taking off the control arm. I'd suggest talking to whiteline and see what they can offer you.
