8
That code is for the pressure sensor. It means the ECU received a momentary lower then expected voltage signal from the sensor. It's possible it's just a hiccup, and everything's fine, or that the sensor may be on the way out, or something in the wiring is screwy. I'd clear the code, drive the car and see if it comes back. If it does, I'd check the sensor, and the wiring.
If you have a temperature related issue, ie runs fine when cold or hot, but not the other, you may need to replace the coolant temp sensor. You may also have an issue with a spark plug that has a crack in it, and the heat makes it misfire. Same goes for the wires....so those are some things I'd check.
