FWD and AWD GC tranny mounts the same?
Legacy777 replied to Virrdog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXD'oh....the AT & MT FWD mounts are different. That's too bad....I'd like to sell this mount to someone who can use it.
Sidemarker lights
Legacy777 replied to Lukas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can go to subaru's website and see for yourself. here's some Link to the impreza line where you can see more pics http://www.subaru.com/shop/overview.jsp?model=IMPREZA&trim=25I_SPORT_WAGON
Some discoveries about OBDI EJ wiring
Aaron, You really need to find some way to get a signal to the VSS pin on the ECU. The ECU looks for a square wave signal from the VSS. Without it, the ECU will sort of freak out, and go into a limp mode. It changes timing, a/f ratios, and turns the cooling fans on. I had all these weird issues with the car when my speedo went out. So it's something you will need to find a solution for, or the engine is not going to run correctly. The neutral switch basically just tells the ECU when the car is in neutral or not. It is mainly used with automatics to adjust timing/idle control since going from gear to neutral alters the engine load. On manual trans cars it may still be used, but it's affects are almost not noticed. As long as the AT/MT identifier pin is correctly identifying the transmission type (again assuming your using a MT), you'll probably be ok leaving it off if your transmission does not have a neutral switch. Some people have wired the neutral switch up to the clutch switch, so the ECU will be told the car is in neutral when the clutch is depressed. I've done both tranny & engine swaps on the first gen legacies, and have thoroughly researched the wiring issues, so let me know if you have any specific questions. Josh
I think I can add some things. The 90-91 non-turbo engines have 3 square connectors behind the battery. The 92-94 non-turbo engines have 2 square connectors behind the battery. The 91-94 turbo engines have 2 square connectors and 1 round connector behind the battery. The engine harness is pretty much the same between the turbo & non-turbo first gen legacies. The only difference is the location of where the coolant temp sensor is. On the n/a engines, the coolant temp sensor is on the passenger side. On the turbo engines it's on the driver's side. For my ej22t swap, I reused my 90 n/a engine harness, but just peeled back the tape and wire loom, and relocated the wiring connectors to the driver's side. Other then that, the engine harness remained the same. As you mentioned, the turbo specific sensors come through the chassis harness from the firewall. I added the leads for those specific sensors, and that was pretty much all the wiring I had to do. At the ECU, I had to swap the positive pins of the cam & crank sensors because they are reversed for the turbo engines. In addition I had to unplug the mt/at identifier pin because the 92-94 n/a ECU's are wired backwards for some unknown reason.
external hd. gasket leak, 2nd time
Legacy777 replied to kleinkid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry to hear about the problems with the head gaskets. Hopefully they've figured things out. I've started hearing less head gasket issues now compared to a few years ago.
Things missing\needed: used 1995 2.2 into 1996 2.5 OBW
Legacy777 replied to jmickelct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe biggest question I'd have is if you're going to swap the intake manifold. That may not match up with the 2.2 heads. If that's the case, you'll have to pull the wiring harness from your current 2.5 and swap it over so you can use the 2.2 intake manifold, but keep the 2.5 wiring harness (The reasoning for this is that the harness connectors will likely be different between the 2.2 & 2.5) I don't know how the 2.5 ECU will handle the 2.2 either. There could be some ECU pins that are different. I can see this project has a potential to be quite a pain in the rear depending on how things unfold, and how much documentation you have on each motors, etc.
Legacy777 replied to Virrdog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know for sure there is a difference between AWD & FWD tranny mounts. I don't recall if the AT & MT FWD mounts are the same. I'll check when I get home. If they are, I have brand new FWD AT tranny mount I bought to use in my Legacy, but never put it in before I swapped to AWD.
Yokohama Guardex 600
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope.....I wouldn't mind selling them, but shipping makes it not worthwhile.
Can you believe this again!
Legacy777 replied to chadwick35/04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTell them to replace the entire trunk/spoiler with a new one.
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't recall if I have the 600's, but I have a set of yoko guardex I ran on my car when I was in PA. I was very happy with them. They had really good traction/stopping/etc in the snow & ice.
Retrieving Codes causes the car to go whacky!
Legacy777 replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat works for the reason Noah mentioned, but you really should have another black connector somewhere.
Legacy777 replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to connect the black connectors. Green connectors are for an "active diagnostic" http://www.ultimatesubaru.org/forum/showthread.php?p=428662#post428662
No power when cold
Legacy777 replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe links are good, try these https://www.mail.experiencetherave.com/subaru_manual_scans/FSM_Scans/TPS_testing1.jpg https://www.mail.experiencetherave.com/subaru_manual_scans/FSM_Scans/TPS_testing2.jpg https://www.mail.experiencetherave.com/subaru_manual_scans/FSM_Scans/TPS_testing3.jpg https://www.mail.experiencetherave.com/subaru/images/injectors/DCP_2477.JPG
CEL and Code 24
Legacy777 replied to syncrosubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, the IAC valve will still have a duty % amount when coasting. You can check it while idling, however it'd provide you the most information if you checked the voltage when the problem/CEL was occuring. Josh
Sunroof drains 2000 OB
Legacy777 replied to voodstoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are more drains, however I'm not really sure where they are. As for the water under the door. The plastic wheel well protector allows gunk to build up from the drain at the windshield. You may want to take off the wheel well protector to clean all the junk out.
Beginner Question
Legacy777 replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, Look in the fuse box, find the one for the cig lighter, and swap out the old fuse for the new one.
CEL and Code 24
Legacy777 replied to syncrosubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe injectors don't shut down. They may go to a minimal duty cycle, but they don't shut off. You need to listen to your ECU. It's throwing a specific engine code for a reason. The OBD1 computers aren't super smart like the OBD2 stuff, so the only reason it'd throw a code is if it's getting a resistance outside its normal range, or the IAC isn't responding like it's supposed to be. I'd suggest checking all the wiring from the IAC valve to the ECU to confirm it's good. I'd also hook up a volt meter to the power source of the IAC valve to make sure power is not fluctuating. From there's I'd get a meter that can measure duty cycle, and watch what the duty % is on each of the open & close leads coming from the ECU. Or try and get the BC-BF scan tool to work. Can you post the part # for your ECU? I'll check it out and see what year it's from. Maybe your ECU is on the fritz... Josh
A/C Fan Switch - 04 Outback
Legacy777 replied to Bo13mwz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're low on refrigerent, the expansion valve works extra hard, which is more then likely what you're hearing the hissing from. I'd start with adding refrigerent, and see if that fixes the problem.
LED Turn Signals Require New Harness?
Legacy777 replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to check out www.legacygt.com/forums as they may be able to tell you. I would venture to say, you'd probably need to swap harnesses, or add two wires yourself.
Where is the Transmission Control Module inline fuse?
Legacy777 replied to manwhoyells's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe No. 4 fuse is the the Number 4 fuse in the fuse box in the driver's footwell. It should be labeled EGI/TCU or something like that. If you have your owner's manual, it should also give you a blow schematic of the fuse box, which numbers the fuses are, and what they do. If all else fails, pull the negative battery lead for 30 minutes.
fuel pump control module for the ej20tt
You may want to see about using a USDM WRX fuel control module. I don't know if they're the same, but I do know the US WRX's from 2002 onward have them. Other option is to see if you can get an importer to get you one.
Subaru crash and FWD/AWD conversion
Legacy777 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes 5spd to 5spd is easier, but my write-up still cover's the majority of what needs to be done. You need the trans, driveline (wagon & sedan are the same), rear subframe, rear diff, AWD fuel tank, rear crossmember, hubs, struts, and other suspension components. You also need the fuel separator. The wagon & sedans have different separators, and you will need to get the appropriate one. If you have any questions, let me know, but my write-up covers things pretty well. Josh
Warning to you kids out there -this isn't pretty
Legacy777 replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt least the belt didn't shred. I fixed a 91 turbo legacy that the idler gear busted. It destroyed the belt. http://www.main.experiencetherave.com:8080/subaru/images/shreddedtbelt/
Impreza steering rack bushings
Legacy777 replied to destey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes they should. I'd recommend the whiteline steering rack bushings. You need the ones with the following part # KSR202. They are for the 30mm wide passenger bracket. The KSR200 bushings are for the cars that have a 25mm wide passenger bracket.
Heater Controls Illumination Problem
Legacy777 replied to BitBasher's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat sort of temperatures are you dealing with when you say "cold"?
