5-lug...brake balance?
Just want to comment on the brake balance thing since I went through a lot of stuff on my car. The newer gen subies use a diagonal circuit brake system, and I would venture to say the older gen may use a similar setup to help maintain some amount of braking in the event of a failure. The problem with this is, fitting an aftermarket adj. proportioning valve is pretty much futal unless you replumb all the lines, and/or sacrafice the safety of the dual circuit design. I will caution about upgrading only the front brakes without doing something in the rear. The car will dive severely under hard/panic braking. I had this very problem along with some others when I upgraded to WRX front brakes. I got in a panic situation, the fronts locked up much sooner then I was used to compared to the old brakes and I hit the guy in front of me. There's so much you can learn about braking and tweaking this stuff, but from what I've found, the best balance is about a 10% shift rearward in brake torque compared to the original factory setup. This is mainly because the factory adds a little bit of front bias because your normal driver reacts better to plowing forward in a turn vs. the rear end coming around. Here is a spreadsheet I have created with various newer gen brake caliper & rotor information. It can be used to calculate the changes in brake torque when swapping calipers & rotors. There is a brake torque calculator with drop down menus on one of the tabs. The formulas are pretty straight forward so you could create your own sheet if you have information on the older gen brakes. The main things you need for the calculation are: Outer disc diameter Effective disc diameter Caliper piston diameter Here's the spreadsheet http://www.main.experiencetherave.com:8080/subaru/techinfo/brakemath.xls Josh
automatic transmission
Legacy777 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm pretty sure the 95 AT is still the phase 1 4EAT. There's some additional TCU inputs on the 95 compared to the 90-94's, but the plug/connector is the same. Either way...yeah you're right...switching between MY generations isn't too fun.
93 Turbo Legacy Sedan Turn Signal Help
Legacy777 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/
Legacy777 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do know for a fact the B15 trans connector plug changes style with the phase 2 trans, so while that's not a huge hurdle, it's not plug & play.
Legacy777 replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if they're the same. I have my doubts. I believe 96 or 97 was when the electronics changed slightly. However the big question would be the final drive ratio. The outbacks tended to have a lower final drive ratio.
93-94 Legacy Wagon, crash rating?
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure they rated them back then.....if they did, I'd see if you could find some figures on the national highway safety website.
OBW Lower Body Cladding Removal
Legacy777 replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's the metal piece I'm thinking of....it has to be cut off, and a new piece welded in.
what do you think?
Legacy777 replied to chadwick2004's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should work. How high it's going to raise is a question. If it's less then an inch or so, I probably wouldn't bother.
Lights Out on 05 OBi Ltd.
Legacy777 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you get this fixed or is it still not working?
Engine Light ON- Multible error codes, where to start??
Legacy777 replied to feathersjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad it was an easy fix. The car will probably run a lot better now too.
Cheesy dirt pics of my new tires
Legacy777 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNah....probably wouldn't happen
94 legacy touring wagon
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's the chassis code. The first gen legacy sedans have a chassis code of BC. The normal wagons are BJ, and the raised roof wagons are BF.
New Suby owner with some questions
Legacy777 replied to outbackattack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are various things to upgrade. However there may not be much specifically listed for your model.....most of the pre 02 impreza stuff will fit. I'd recommend KYB struts. There's a tranny cocktail one of the guys on http://forums.nasioc.com/forums has come up with. Check out the trans forum and search for uncle scotty's cocktail. I've been really happy with the shifting results. You should be able to put a short shifter in your car, if not, you can swap over to the new style linkage and then be able to run a short shifter. I'd personally recommend just replacing the front and rear linkage bushings with poly bushings. You can get them from www.kartboy.com Others should chime in as well. Welcome to the subie clan Josh
EJ25 Rod Bearings: Where to get?
Legacy777 replied to RallyKeith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrod bearings are a pain to find. Have you tried Jamie?
Legacy777 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's a true touring wagon it has to be AT unless it's been swapped over to a MT. For $150 though I don't think you can go wrong.
Adjust TCU?
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe thing though is that this is an automatic. At full throttle you get torque multiplication through the torque converter , so the car still is going to pull all the way to redline. I know that's the one thing I miss about my automatic when compared to the MT.
Legacy777 replied to feathersjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto to do this.
Legacy777 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool pics. Where in Houston were you at?
Legacy 1.8L
Legacy777 replied to soloracer34's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like someone swapped in a 1.8 to replace the 2.2. The US didn't come with a 1.8 in the legacy.
New Gen Subaru FAQ Sticky Compilation
Legacy777 replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat sealant to use
What sealant?
Legacy777 replied to samm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse the Ultra Grey. Personally, I'd pull the trans. The motor has a lot more stuff to reconnect. Also, for future sealant reference. http://www.main.experiencetherave.com:8080/subaru/techinfo/subaru_sealants.gif
Help with my list, I'm taking my car into the shop
Legacy777 replied to JaySmurff's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat you have on there looks about right. Only thing you may want to do some time in the future is replace the struts. They start to head south around 80k or so.
mechanic/shop in RDU area
Legacy777 replied to mcopeland's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to also post in the meet & greet forum as well
Adjust TCU?
Legacy777 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it always shift at 6500 rpm? If so, something was wrong. If you hold the pedal to the floor it should shift at 6500 rpm. I'm not sure what the tranny shop did, but I would say it's not normal.
1990 & 1993 Legacy Wiring Diagrams
Legacy777 replied to allantico's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it's pretty much the same to my knowledge.
