Turbone
Administrator
    30
Everything posted by Turbone
  1. Go to any garden store or major dept stores garden section and look for the 3in rubber or PVC seperation stripping. Its used for dividing the lawn from flowerbeds. Comes in rolls.
  2. Eh? Did I miss something, or is CRS getting me again? (probably both)
  3. Heck, he's got a full size Blazer. Woosing out on us Corky? You know I'll be there. My Hatch hasnt seen snow yet
  4. You will also need the complete exhaust also. Either the EA81T or EA82T, cross-over pipe (Header) and the down pipe. But if you go this route, you will need to make a piece of pipe that will replace the turbo. And the cross member from a turbo car is needed also. The whole thing might be easier if you used a EA81T and replaced the turbo pistons with FI pistons.
  5. I heard it was white out conditions up in the passes today. Let us know what kind of fun you had
  6. A couple of guys in a EA82 wagon got on the news last night, they were at Mt. Baker/Stevens pass. Showed em pushing a little snow around, it was about 10in deep. Btw, Crystal Mt opens this weekend
  7. It could look something like this? It only has a EA81 in it tho
  8. If I can remember I will take some pics between the rain squalls tomorrow. Mine is a little different than Adams, and it has the lifted engine.
  9. Sorry Nipper, my bad. Gots to read with my glasses on But if the engine has good oil pressure, why change it? Just throw a new reseal on it and call it good. If the other stuff isnt leaking, dont mess with it. I've found that sometimes when replacing seals that dont leak, end up leaking after replacement.
  10. Your right, it is a PITA to change. What you need is a pair of real long needle nose pliers, maybe with a bend on the end. This will allow you to get the new hose onto the fitting thats under the intake. Otherwise, your alternative is to lift the intake and replace the hose :-\ Dont forget the spring clip on the end of the hose.
  11. The small hole is part of the casting of the block, but should have a dab of sealant to make sure the oil pump is sealed good. As for replacing the oil pump everytime you do the timing belts? Totally un-necessary, oil pumps should last at least 100K. Just my opinion.
  12. No, not all look like that. There are some of us that have a sub frame built above the x-member that the engine mounts to. It brings it back up to the original position, and out of the water and muck.
  13. Theres only 2 Brats with a ER27. Adam NDJ and Archemtis. Contact them if you want the skinny on the swap.
  14. Hey, wheres the engine? All it looks like there, is a intake and alternator sitting on the x-member Oh, I forgot, some of you with lifts have the engine still on the x-member :-p Sub-frame baby Glad you got the tranny in, now when you coming out?
  15. Wow, from the sound of it, its a wonder some of you ever got a window out in one peice I have got a few out by using a utility knife or a fillet knife. Its skinny enough to get in between the glass and metal. I have even used a propane torch to heat the knife. Once I get most of the glue cut, especially the corners, I use a hood release cable (junkyard tools are great) to finish the cut. If you want to do this alot I recommend buying a very expencive tool that cuts the glue like butter. It takes about 10min to get a window out using one. A used one might cost a couple bills
  16. Thanks Tom! I cringed when I read EV's post Like I said before, if your still having probs I can scan the FSM. If it will help.
  17. The only thing lacking there is the Fulltime 4wd tranny (with Diff Lock)
  18. All I can say is..........you better tint those windows mate
  19. Or possibly a even worse case scenario. The front diff could be going :-\
  20. White is constant Lavender/yellow is switched The antenna could be green/white or gray/white If you still need more info, I can scan the page for you.
  21. Theres alot of things you can do in the back of a wagon when theres no seats in it. Nice touch with the carpet too Some mood lighting and your set :cool:
  22. No, I had a Sony deck in it. But it was in the car when I bought it. It doesnt have a wiring adapter either, the sub wiring is straight back from the deck with 12g RCA. The door speakers are actually wired to the stock harness. I think the 89's might be wired differently because I didnt have any problem once I figured out which were the correct wires. Each one had its own ground wire. I wasnt looking forward to running new wire into the doors :-\
  23. Mykeys Toy gave me some links to some places and products. I did some (alot) of research on different makes and I came up with the Kenwood. The subs are off brand, I got them from Mykeys and the amp is a cheapo I got off Ebay, used. The Sony 3ways were in the car when I got it. But I think I have the right combo (for now) and its sounding pretty good. I've been burning about 5-6 CD's a night, I have to record them to my HD first from the cassette player. I went and bought a nice Onkyo system off of Craigslist (Amp, Cassette, 5 CD changer) for just $65. I've been making some good scores lately from Craigslist
  24. Calebz has this setup. You might PM him for more details, or he might respond to this thread
