30
Everything posted by Turbone
I'm looking at a EA81 FSM and they show 2 diag. The marks go up, the top ring has beveled edges, the 2nd ring has sharp edges and the oil ring either has a second ridge under the top rail or even rails, so that doesnt make a difference. Do you know the positions and gaps for the rings? I can scan the FSM and post it?
Need a Garage in Pheonix are for 5 hrs..?
Turbone replied to mudrat79's topic in Meet n' Greet. Your USMB Welcome Center
Thats what I had for WCSS6, it was a 16x16 with zippered openings on all 4 sides. I ended up taking it back to WalMart and getting a refund. All the zippers broke -
Whatever you do, dont use dishsoap on the exterior paint. It leaches out the oils in the paint and dulls the finish.
Legacy LSD in Leone. Is it possible?
Turbone replied to EA82Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Definatly check the tag on the diff, I think it might be 4.11. -
Is this fixable? (after wreck)
Turbone replied to Sister7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you might have "dodged the bullet" (but not the car) so to speak. I think thats perfectly fixable. I happen to be going to Tech School just for this, and have already straightened out a 98 Dodge Intrepid on a frame rack. The only spot that looks bad is the passenger side, need to get the fender off to see if theres any frame rail damage. I have a few parts (headlights, lenses, etc) we can use, but you will have to find a front bumper, hood and right fender. Let me know if you want my help, I'm alot cheaper than a shop. And I need the expereince -
RX approaching 'ultimate' status....
Turbone replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In order to reach full "Ultimate" status, you need to transplant a EJ20G into it (like Corky's original Ultimate) -
Hmmm, that sure looks like Qmans RallyX Brat Heres a little artic of my old Hatch up at Kanaskat a couple years ago.
You can try and adjust the bottom latch, loosen it and drop it down some.
transmission options for my new XT Turbo
Turbone replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought all XT6's were AWD? AT or MT. But you can select between 2wd and 4wd on the 4EAT, just pull the fuse Or if you want, rig a switch up. Plus the duty solenoid c trick too. -
Front Windshield.... (COMPLETED) reply
Turbone replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
According to Sika's web site, the main function of the WS is to keep passengers in the car. If people are belted up, this means its a secondary safety device (IMO). Being a Volunteer Firefighter/EMT for several years I have seen both sides of the WS, so to speak. I have seen what happens to people that are not belted in when a accident occurs, and its not pretty. The reason I'm saying this, is that its the seatbelts that save your life, not neccesarily the WS. Theres a chance of ejection from any window or door during a collision if you are unbelted. Indrid, your link to their site isnt correct, this is the link to thier safety page. Safety -
Need Oil Pump Help Badly!!!
Turbone replied to Bobby_boucher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As far as I know, theres is no aftermarket pump for the EA81/82 cars. Bobby, what and where did you find that pump so cheap? -
Just bought an '87. Need some info.
Turbone replied to xjosh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Theres a strap for a latch of the bottom seat, its in the center and might be down in the crack. May have to stick your hand down there and fish around for it. The oil leakage is common for a Soob, yours could be the PS lines, try tightening them. I would also consider changing the timing belts, they need changed every 60K. Done worry about the engine if one breaks, its a non interference engine. It will just leave you stranded -
Try not to be so ungrateful when you ask a obvious question. Try and get some more sleep
What a way to start a day
Turbone replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Vultures? I think they have bigger problems What about the driver and any passengers in the car -
My 82 GLF is on its way to its New Home
Turbone replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, at least we know he went to a good home and will be taken care of. Maybe when times get better for you Connie, you can buy him back. -
How do you read codes on an EA82 carbed
Turbone replied to oldblue2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did a simple search (reading codes) and I came up with this. Check engine light demystified -
2 Radiators in 6 months? What's up
Turbone replied to erikvr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It might be a good idea to get a new rad cap. -
Explain "going through". Like, whats happening to them? -
I know a couple of years ago somebody here was talking about someone they knew ran a EA82 in a Score race. I tried to find it in the results, but I have a feeling it was DNF.
The green connectors together for test mode. Then find the black connectors, this is the dealer check mode. Once you check these, connect both together, I think this will clear the codes. If it doesnt, just disconnect the battery overnight.
Don't laugh, I KNOW this has happened to you too...!
Turbone replied to markjs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Move away from the salt water Need to know exactly what broke - The seat, rail or capture/mount? -
Crank Seal Replacement 93 Loyale 4x4
Turbone replied to SparkSVT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He's talking about the crankshaft. If theres any irregularities on the shaft, the seal cannot do its job. If the oil was never changed in the car it would certainly put grooves on the pump shaft. Is this a crate motor? -
The plugs are under the steering column next to the ECU. Need to connect the green plugs to read them. ECU Codes
