Everything posted by Turbone
Finally hit 1000!
Hey Glenn, this is me whooping you
Finally hit 1000!
Pre 1/01. I just made it. And I'm real close to turning over another 1K.
Need help analyzing my stool sample
Looks to me like the eviction was successful
Northwest Washington Meet
This should be called the "Mid West Washington Meet". North West Washington will put you up in Bellingham.
Help needed quickly! front crank seal
Thats what he has in it now.
Why do I think the EA81 has more power than the EA82?
I swear we have a echo here
I can see! Again. (Headlight conversion)
Ok, where'd you get them and how much? Glad to know they fit in the XT's
EJ22
It certainly could be the difference. There is quite a diff in weight between the 2. Your freinds 4wd could also be suffering from tuning issues also.
Brake upgrades for 89 gl-10?
Have the rotors cleaned(turned) and mic'd, they might be salvagable. You can get good quality pads to go around, they usually run up to $40 for a set (front or rear).
Betcha never seen a EA81 coupe like THIS before.
Another blasphemy Just doesnt do me at all :-\
Make sure you have the right seal. The part # is 8067 38070.
You have removed the timing belt covers, etc?
Key Stuck in the Ignition - and it's not the right key!
You may have to remove the cylinder to get the key out. Its a PITA, sorry. What you could do in the meantime is remove the plastic cowling from around the steering colume and on the right side of the ign you will see the relay. Theres 2 small screws that hold it on, remove these and it will come off. You can then turn the cars ign on and off this way and yes, start it also. I've been driving my 86 wagon like this for a while cause the cylinder crapped out on me. And I've been to lazy to fix it Replace all the plastic and tuck the relay under it but with easy access so you can turn it.
What engine is this Ea81 or EA82? I dont recall any metal rim inside either one but I also dont think the main bearing can slip forward like that either. How far out is the seal sticking? The ones that I have replaced on EA82's go flush.
88 xt starting problem
Might start by replacing the fuel filter. Drivers side firewall, make sure you crimp the hose or remove the fuse, its high pressure.
** FIXED!** No brake lights
Test the circuit just before where the old trailer harness was and after it. This will tell you if the wire is bad at that point.
twin core radiator tweak
The correct mod here is what WJM suggested. Replace the clutch fan with electric. It mounts right to the rad, and its alot easier to remove.
Rare Subaru Spotted...
Tim, check the date on his post. He's still around, I see him on MSN occasionally.
comin to the coast NEXT WEEKEND
Date and time? And I assume you mean the left coast?
I can't believe this-- beware 56k carnage enclosed
I would inquire more about thier "registry", maybe have a look at it. A Brat GL will not work as they have thier own market. Which is considerably higher that a Wagon's.
Bad Dizzy?
Get a JY coil and see if it still has the problem. Not common to have 2 disty's go bad in a row.
Sube only NW junkyards
Aarons Auto Wrecking in White Center. He's in the phone book.
Did you see the link in my post?
Attention: Transfer case weak link found
Dont forget petting. They like to be fondled
