105
	I've seen at least 2 bleed orders listed, personally, I do farthest to closest. I use a one-man helper gadget - a hose with a valve in it. Document clip to hold to rim of clear plastic container. I set it on top of a small box so the tubing isn't so long. I put a chunk of wood under the pedal so I don't go to the floor - some folks warn against that. DO NOT FORGET to remove the wood chunk before flight!
	indeed something still seems wrong if I understand your temp gauge description. on both my cars, if the gauge were the left side of an analog clock, the hour hand indicates about 8:30 as shown here; never seen my WRX go above 8:30, I HAVE seen the Outback get to ~10 in the desert; uphill grade, 3 people and luggage. 116*F outside. no, I don't want to got to '11' !
	actually, being on low traction surfaces with an odd-sized tire is easy on the AWD system as binding forces won't build up as much. but driving down a straight dry freeway with an odd-size tire - that is murder on AWD. but again, it's temporary.
- 5 replies
- Low Battery
 - Cant remove key
 - (and 3 more)
	in 'the old days' pedal pad wear was about the only other indicator. You want to see wear reflective of the mileage. NEW pedals , OR, extremely worn pedals, would be a red flag that odo cheating has been done. here in the US, we have labs like Blackstone and Polaris that do fluid analysis might be able to tell you if there are excessive metals or fuel or coolant or silicon in the oil. other than that, it's a gamble.
	pull oval plugs and adjust both 'star' wheels UP (both sides. what I do is put car is chock wheels, put car in N, pull p-brake handle to first notch, get rear up on jackstands. Adjust star wheel until I juuuust can't one-arm turn the wheel anymore. Do the other side the same way. that seems to lock the wheels pretty good with half-dozen clicks or so. if it doesn't work well-enough, you can try again....try the adjustment under the console....or maybe somethings wrong?
	maybe I'm wrong but I thought they were the largest volume soob dealer in the US? (I have not ordered from them, but other on-line and ebay dealers have been fine - it would be disappointing though for some DIYers if the wrong part arrived, it's why I sometimes suggest folks try to get a local dealer to match on-line prices. Easier to go just drive back over and exchange a part. A dust boot may not be time sensitive or easily confused with an incorrect partnumber so, probably be OK)
	someone posted this one worked on their 2002 Forester; https://www.amazon.com/45535-22080-Rubber-Shield-1990-2000-Lexus/dp/B00K85CM94/ref=sr_1_16?ie=UTF8&qid=1509568117&sr=8-16&keywords=tie+rod+dust+boot I saw this there; https://www.amazon.com/45535-22080-Rubber-Shield-1990-2000-Lexus/dp/B00K85CM94/ref=sr_1_16?ie=UTF8&qid=1509568117&sr=8-16&keywords=tie+rod+dust+boot try using the above supplied partnumber at ebay, amazon, web search/shopping and see what comes up ?
	I'm not sure on the final drive ratios, but many people have caused synchro clashing problems by switching TO synthetic lube. The OEM fluid or name brand non-synthetic GL-5 plays best. Some folks say the walmart/supertech synthetic BLEND stuff works too - it's cheap to try. Evidently, the syncrho speed is too fast with the synthetics. but, if you've already been down that road, other than just asking car-part.com for a compatible trans, you'd need to research the various final drive ratios. hope someone else responds.
	someone should put together a kickstarter to get a pallet-full of DR trans sent over from Oz, or Japan or S. America - wherever they can be found. people always want them.
- 10 replies
	check into rallitek and king springs with a very high lift, you may need those HERI axles - lots of extension.
- 10 replies
	well, peeling off the top and losing the hatch would SAVE some weight - but it also brings problems like increased body flex so - not great. honestly, I just don't think this vehicle could last long. maybe with a dual range trans, maybe a stronger clutch, a spare engine waiting at home, spare trans.... I dunno - these other guys have more experience with off-road rigs. Trax would be a surprise; /www.youtube.com/watch?v=KgW7DcyROaI
- 10 replies
	did you misspell ' Suburban ' ? lol! I'd be tempted to rig 2 vehicles for redundancy, so , even if it slows the operation down, you have a back-up vehicle.
- 10 replies
	never thought of the plunger getting hung-up - that would explain why he doesn't hear a click. maybe try the 'whack-starter-with-a-piece-of-2x4' trick when it's cold and you feel certain it would fail. If it started immediately when trying that half a dozen times, I'd feel confident a solenoid rebuild would fix it. Even if it doesn't, then, HEY, rebuilt solenoid! (shouldn't be expensive)
