Late Model Outback Won't Start
1 Lucky Texan replied to Matt_J's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the car is dieing in traffic - definitely report that to NHTSA.
2013 impreza slow of the line
1 Lucky Texan replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin theory - overfilling up near/past the 'windage tray' or w'ever, 'could' lead to oil being beat into a foam by the crank shaft - foam is not pumped as well by the oil pump. but with a HUGE amount of overfilling....and, for such a short amount of operation....I kinda doubt there's anything to worry about. You might consider asking for new oil filter and PCV valve - maybe even a throttle body cleaning....???? I doubt anyone could quantify any reduced utility from the car though. does the engine 'only' last 275,000 miles instead of 300,000 ? impossible to know.
Noise when turning
1 Lucky Texan replied to Lynne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXstrut bearing? If you can duplicate the noise at low speed, maybe have a helper maneuver the car while you pace it and listen. there are enough possibilities that you likely need a pro to help diagnose this.
1 Lucky Texan replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat dealer?
Incorrect rear diff burnt up center diff?
1 Lucky Texan replied to GRombal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ if the front and rear final drives are the same, either age/bad luck took out the enter diff - or the car has been run with a mixed size of tires lonf enough to damage the CD.
Blower fan freezes up on 2008 Subaru Outback
1 Lucky Texan replied to jstricker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould this be a cabin air filter issue?
Clicking noise
1 Lucky Texan replied to Subruman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you crank the engine around with a wrench? maybe check for slipped cam/crank timing.
High RPM faint misfire, unsolved mystery
1 Lucky Texan replied to 09_misfire's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXkinda want to ask about the plugs - are they the correct part number? did you check or adjust the gap? re-check for oil in the plug tubes? looks like you are very close to needing a timing belt system service - kinda wonder if cam timing could drift enough to cause problems if the tensioner is weak?
still chasing vibration
try this, put the trans in Park or N, then, foot on brake, shift to D if you feel vibration when in D, 99% it's the axles. not uncommon for rebuilt or some new aftermarket axles to cause some vibration. usually reported at stopped at idle but, i gotta believe it 'could' also happen while driving...?
ECU from automatic to manual
1 Lucky Texan replied to sfortin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXread these;http://forums.nasioc.com/forums/showthread.php?t=735058 http://forums.nasioc.com/forums/showthread.php?t=1944699 http://www.clubwrx.net/forums/maintenance-service-repair/134297799-cel-p1596.html
Junk yard motors
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ yes, gauge readings are subject to 3-4 moderating factors. cam overlap and timing, altitude/local atmospheric pressure, temp, etc.
Junk yard motors
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmutiply the cr and atmospheric pressure ? if cr = 9.7 and atmo = ~ 14.7, that's a little over 140psi. i've read you want cylinders within 7psi of each other too. dunno how low you draw the acceptable threshold...
ECU blown or fuel pump circuit issue?
1 Lucky Texan replied to sfortin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXare you able to scan the ecu for DTCs ?
p0748 after engine install
1 Lucky Texan replied to phyregold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis could easily happen if the transmission pan was dented - or maybe just 'deflected'. damaging a solenoid. 2 or 3 other possibilities i guess. Try a search, kinda common code after engine/trans work actually.
RockAuto.com Discount Code for Parts & More - Expires December 16, 2016
that's bad news - I'd expect it would be easy for RA to get the supplier to reimburse them for the return shipping. Certainly YOU shouldn't be on the hook for it.
Catalytic Converter
1 Lucky Texan replied to Sangerboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvacuum leaks, bad wiring,etc. , all that needs to be considered as possible P0420 causes. If it comes down to the cat, you might consider a low miles unit from a junkyard - California cars may not have killer rust and swapping-in an OEM cat should be doable. You may find one with 1/3 the miles of yours at an affordable price. car-part.com and LKQ are possible sources. I think there are ways to use an infrared thermometer and perhaps determine if the cat is lighting-off - check youtube for that.
1 Lucky Texan replied to sfortin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you think the engine is now flooded, try starting with the gas pedal held to the floor - that causes the ECU to go into 'clear flood' mode. could the security system is preventing start(?) try lock/unlock with the key fob.
Catalytic Converter
1 Lucky Texan replied to Sangerboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthings as simple as an exhaust leak or cleaning a MAF sensor have cured that code for folks - we often tell people that the cat is rarely the problem but, at 340K, yours may very well be 'done'. Same for the rear sensor. worth looking around for other issues first as even aftermarket cats are pricey. Some folks also have use - spark plug 'extenders' and resistor networks to turn off that code. The rear sensor that triggers it is ONLY used for cat monitoring and has ZERO effect of the car's running parameters.
98 gt woes
1 Lucky Texan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, good luck ducking in to remind you - weak tb tensioners can sound like rod knock or piston slap sometimes.
99 Leggie Outback, massive oil leak
1 Lucky Texan replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoil sender is on top, kinda under the alternator - worth a look if you think oil is coming downt he front.
Towing my automatic Subaru Lancaster (Outback) 1998
1 Lucky Texan replied to imo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI assume you have an automatic? What year? anyway - you're likely to overheat transmission fluid and some vital parts if you tow it. The FWD fuse only 'works' when the engine is running. the 5 spd can be towed - best if done slowly for limited distances I think.
What are the signs of a bad center diff?
all 4 tires really must be the same brand/model/size and close to each other in wear. You use the FWD fuse when you install the donut spare. There ARE ways the system can fail even when you do all that correctly - Duty Solenoid C can be bad, wiring can be bad, the wet clutch pack can hang-up and not function correctly, etc. you may have 2 or more problems, but it seems one of them is definitely torque bind. If it continues, the transmission can be severely damaged. If the FWD fuse is NOT in place, put a fuse in there. If you do that and STILL experience torque bind, might be best to have a Subaru experienced mechanic determine what the problem is and if the best approach might be a used transmission swapped-in.
jerking/bucking in tight maneuvering on dry pavement. (the car should be able to turn tight circles smoothly at idle, or just above idle speed) as a test, there should be an empty slot in the fuse box under the hood. Placing a fuse in there will place the car in FWD mode. Check you manual - usually under spare tire use section. Often, that will make a change in the way the car behaves and point to certain problems in the transmission or drivetrain.
Rear axle question
^^^ yeah, with pinion and spiders and old tripod/DOJ joints - 1/2" doesn't seem bad.
headlight updating
1 Lucky Texan replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall the kits work to a fairly good degree. The 'secret' seems to be a thorough cleaning after, followed by a good UV blocking clear-coat. what types of bulbs are in your car? there may be an option but, most brighter bulbs will have a shorter lifespan. Don't do HIDs without proper projector installation. check State regulations before adding additional 'offroad only' driving lights.
