93 Legacy no power and shakes?!?! HELP
your 2.2 is NOT interference so, that's OK. check here; http://www.northursalia.com/techdocs/pdf/engine/timingbelt.pdf
may have slipped cam/crank timing - inspect. get the knock sensor changed - they are cheap from ebay, wire brush the block under the old one, route the cable the same direction as stock and don't overtorque the new one.
Head lights
GIFSoup
Subaru Impreza Outback shakes when letting off gas
1 Lucky Texan replied to Darr12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, seems this is a different problem than I first thought. do you feel shaking in the steering wheel or 'seat-of-the-pants' ? many things to look at - start by shifting the front tires with the back. Inspect the tires as you do this. alignment could be a little off, worn tie rods/rack bushings could be in the mix. check lugnuts/studs, check for draggng brake caliper, loose axle nut. bad engine/transmission mounts. any work done immediately before this began?
1 Lucky Texan replied to Darr12's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtypical problem with bad/poorly rebuilt half-axles in automatic trans soobs. Vibration when stopped in gear - shift to park or neutral and vibrations stops. seems like the only cure is Subaru axles, new or properly rebuilt. new aftermarket 'sometimes' work OK. The first EMPI I installed did not vibrate, the second one did.
12 Most Embarrassing Vehicles--Baja?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine had a seat in it, but was much easier to drive standing up. The door in the back was segmented on cables - like a garage door.The door on the side would slide back and latch - just a canvas strap across the opening. It would sometimes freak other drivers out at 2 lane stops when I was on the inside lane. They look over and see this geeky teenager STANDING in a yellow van right next to them! Made a little money hauling furniture with it on a few occasions too. The engine was a flathead 4 IIRC. Had a Ford 3 speed auto in it. The accelerator was an 'arm' that stuck out and you operated it with the inside of your foot. Barke pedal was up-down. Very odd. I THINK I have a pic somewhere that might show just a part of it in the background. Probably from about 1972... I'll look for it. that jo-car is in the Subaru museum in NJ I think.
2.2L 99 OBS acceleration lag- common?
TPS ?
- 2005-6 Baja Turbo vs Non-Turbo
2010 Outback dash lights and trouble starting after battery replacement
1 Lucky Texan replied to ncohaw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the car now starts and runs well, it may very well just require a little more driving. AutoZone and other parts stores can read the code stored by the ECU. They might clear the ECU as well. It would be interesting to see what code is stored. all new cars will light 2-3-4 lights if there is a DTC stored in the ECU.
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^ funny! after this Subaru, all the other ones look great!
Rack and pinion diagnosis
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif there are different model tires, or perhaps more than 3/32" difference in wear, you can experience torque bind. I don't htink that's an issue here, but as a test, see if you detect any 'jerking' in the car when doing tight, slow (at idle or just above) circles on dry flat pavement.
- 12 Most Embarrassing Vehicles--Baja?
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've driven so many POSes and weird cars - I just don't care much and, indeed, I find 'odd' cars kind of interesting. I even drove a 1948 Willys Fleetvan in highschool, old RHD postal vehicle. better than walking. never had money for 'nice' cars and never had my ego tied-up with my wheels too much. But other people I'm sure though that van was nuts. kinda like this ;- Rack and pinion diagnosis
1 Lucky Texan replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, not sure what the complaint is. If the tires are the same model and close to each other in wear-level, maybe some rust or other debris is trapped betweein the wheel and the rotor whe they swapped them. what kind of steering problem are you experiencing?- Bad pinion bearings
I have this image of Ivan making a video to set backlash on a diff. - but the audio is stream-of -conciousness, monotone and has no pauses .- aftermarket axles...
1 Lucky Texan replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe Dad's are rusted in place? well, while it's definitely a redneck approach, instead of Teflon, what about aluminum foil, or some type of stainless foil if it could be found? perhaps a strip from one side, over the end, and down the other side. basically like a U shape over the end of the stub. maybe an X shape so you'd get a strip in 4 locations around the stub. it need to be a very thin 'shim' material I guess. Even some very thin guage wire - say - copper, might work. and coat everything with never-seize. If there were a way to gently knurl the splines - that would raise some material. Or build-up the internal splines in the cup with some heavy plating? certainly not a correct repair.- Help me Diagnose noise coming from front of car....
^^^blower fan worth checking, good idea. fender liner flopping? while sitting still, can you bounce the car at the corners and create the noise?- 98 impreza obd2 port not working
1 Lucky Texan replied to gsac132's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDOH! 98 Test the scanner on another car to confirm it's working. Has that scanner actually been used on your other Subaru? There were some inexpensive scanners that wouldn't communicate with the ISO protocol.- 98 impreza obd2 port not working
1 Lucky Texan replied to gsac132's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat year soob? OBD II is 96 and up, some 95s may have had it.- Help me Diagnose noise coming from front of car....
so, it isn't random, but it doesn't correlate with engine rpms or tire rotations? I think it's gonna be a bushing, or balljoint.- 97 Subaru Legacy Outback Security Light
1 Lucky Texan replied to kasha6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdunno how it could happen while driving but, maybe it's in valet mode? check your manual or dig around at cars101.com for instructions to switch it back to normal.- aftermarket axles...
1 Lucky Texan replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI learned something AGAIN - I didn't know the MT stubs weren't just held in by circlips.- 2.2 legacy warm start problem
possible engine temp sensor - though symptoms don't fit perfectly. possible fuel delivery issue - maybe a leaky injector. Don't pump the gas pedal next time, just hold it to the floor. If it consistently starts, the engine is being flooded. In FI engines, when the ECU detects full throttle on start, it shuts the injectors off/down. That is the 'clear flood' condition in a fuel injected car. if the above consustently does NOT start the engine, maybe it's fuel starved? fuel filter changed recently? doesn't seem like a high voltage problem but, at night with the engine idling and hood up, you could try spraying some water mist around the wires and coils, any arcing or engine stumbling may mean bad wires or coil. OEM or NGK parts only on the wires.- Busted Rear Shock (Dial-up beware)
1 Lucky Texan replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, the rear spring on my Outback was 'almost' wimpy enough I think one of my buddies could have held it for assembly. not safely though.- aftermarket axles...
1 Lucky Texan replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an EMPI in our H6 outback. I have no qualms about it failing, good value, very nice unit but it started causing vibration 'in gear when stopped' after a year. If her Forester is a 5 spd, she may never have an issue. - 12 Most Embarrassing Vehicles--Baja?
