1997 legacy L 2.2L
clear the codes and see which come immediately back. Possible bad grounds connections or loose harness connector ? after cranking, pull the plugs and see if one is wet. Also, try cranking with the pedal on the floor. That is the 'clear flood' mode for a FI car. When you checked the timing, the arrow/triangle was about 3 o'clock position right?
Some assembly required (struts & springs)
1 Lucky Texan replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnumber 19, for the fronts, has to go the correct way; http://www.subaruoutback.org/forums/attachments/do-yourself-illustrated-guides/58882d1384312695-front-strut-replacement-2000-outback-struts.jpg
1 Lucky Texan replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe open end goes on the bottom so the spring end fits up against that 'pocket'. also, on my outback anyway, there is an orientation to the top hat. There should be an arrow or other marking that is supposed to point 'outside' after assembly. That is, it points toward the curbside of the fender - 90degrees from the fore-aft axis of the car. And the washer on top has an orientation. The domed or bevel side goes against the inner race of the mount's bearing. just pay close attention to how things come apart. and be careful.
Messed Up Heater Switch in 2005 Forester
1 Lucky Texan replied to 802climber's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI admit to being fairly ignorant of Foresters. One thing to consider is if the car has a cabin filter and how dirty it might be. But, honestly, hard to know how that might affect vent selection unless some debris is blocking a 'blend door' or something.
Non-Ethanol vs. Premium in 3.0 H6
1 Lucky Texan replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhether it has ethanol in it or not, run the higher octane rating fuel in the H6. Lower octane will lead to a little knock, that will cause the ECU to retard the timing. Some say, the car also gets more/faster carbon buidlup in the cylinders with regular gas. You could try the mid-grade in winter and run the hi-octane in summer. I run high octane year round.
Drilled and Slotted rotors
1 Lucky Texan replied to abog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they came on the car, don't have uneven pad deposits, aren't cracked from the drilled holes or at the minmum thickness - just run them. But, as said above, a daily driver does not get any benefit from them. In fact, modern pad materials even for racing do not outgas as badly as in the past so, even some track cars wouldn't need them. Of course, if you're gonna track the car regularly, you would need to use w'ever combo rotor and pad works best for you. If you plan to refresh all 4 corners, get Centric premium rotors and try Centric PosiQuiet Ceramic pads - good value. If you track occasionally - or zoom around in a spirited manner all the time, upgrade the pads to Stoptech Street Performance. On a car that old, you should consider all new rubber lines too. maybe 4 in the back (?) and 2 up front? not sure. That old rubber probably balloons a lot and fresh lines won't - more solid brake pedal feel. Fluid flush might be a good idea too.
Evil noises
1 Lucky Texan replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^^ good post. I wouldn't discounta dragging brake caliper or even a pebble stuck between the rotor and dust shield
95 Impreza CEL flashing rapidly
1 Lucky Texan replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah, I only considered the green connectors and rejected that as he didn't have relays and fans activating... bet that's what it is. probably masking an evap code!
1 Lucky Texan replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have never read of this. waiting for the gurus to explain it......
'02 Outback, 4EAT, delayed power to rear wheels?
1 Lucky Texan replied to xbeerd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust to be certain, are all the tires the same? same model and same wear-level?
Dashboard engine temp gauge
1 Lucky Texan replied to Xadamx1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd be concerned that I got a bad new part or there was a wiring problem. maybe temporariliy put the old one back in?
Rollover, and now transmission won't engage
csprings - you should not have added fluid if the stick indicated full. Also, make certain you are not using the front diff dipstick on the passenger side. (don't scoff, it's happened before) any part s store can read the CEL - post the code here. For <$20 , you can get an elm327 device to use with a smartphone and a free app like Torque and read your codes yourself.
Looking at buying a WRX, advice please!
The main problem with used, inexpensive 'sporty' cars is - they have often been reamed-out by kids. The advice above about being OVERLY cautious on researching the car before purchase is CRITICAL. (I love my 06 WRX wagon)
- just food for thought
with the engine idling, have you checked the level with the dipstick? usually, you have to pull the stick, wipe it, and wait 3-4 minutes before taking a reading, and do the same after adding fluid (add 1/2 pint ata a time near the full marks - unlike the engine dipstick, the low-hi marks are only about a pint apart on the tranny stick.)
2001 Legacy
1 Lucky Texan replied to Vmech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfrozen u-joint or possibly carrier bearing problem. fuel smell and evap 'could' be related. Sometimes the fuel filler neck has corroded holes behind the plastic.
2007 Legacy loss of power on hills
1 Lucky Texan replied to MarcM7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould you have slipped cam timing? One or 2 teeth might just drop power a little. at 211K miles, you're due for the second TB change unless it was just done.
Another A/T Binding Issue
1 Lucky Texan replied to Navet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf this car is new to you, perhaps a previous owner swapped in a transmission or rear diff with improper final drive ratio? But, definitely followthrough on the fluid change - perhaps try an additive to the trans fluid as well.
- 6 replies
- transmission
- transaxle
- wb
- wheel bind
Tagged with:
2000 OBW died while driving, won't start
1 Lucky Texan replied to mphotodoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany signs of rodent damage? they will chew wires.
engine swap from ej20 to fa20
1 Lucky Texan replied to Victor8021's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you want a project, maybe check into a frankenmotor.
1 Lucky Texan replied to Victor8021's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you looked for a WRX or STi engine?
1 Lucky Texan replied to mphotodoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI also think a bad cam sensor will prevent the ECU from sending fuel but, not sure. maybe scan for stored codes?
1 Lucky Texan replied to mphotodoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen you cycle the key to on, can you hear the pump run for a few seconds?
01 Outback jambed glove box door
there just might be some useful images in the cabin air filter replacement section at cars101.com .
5 speed fluid fill hole?
1 Lucky Texan replied to Aluxes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used one of these; pour slowly. I used one of these for the rear diff.
