5MT sounds
1 Lucky Texan replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany work or damage done before this?
Intermittent Horn and ABS light
1 Lucky Texan replied to unibrook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, locate the abs pump (maybe front/right, sorta under the power steering tank - not sure on a Forrie), have someone start the car, and feel the pump. It may be buzzing/vibrating. Or just try to listen and pinpoint the sound.
Rounded Axle nut removal
hmmm....I'm sure GD can tell you if you can't find a procedure. On a car I had in the past, there was a torque value, but then you backed the nut off and torqued to a lower value and put a cotter pin in. I think it was a preload procedure for tapered roller bearings IIRC.
Looking to change front and rear diff fluid on my 1996 impreza brighton
1 Lucky Texan replied to kickascii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany work done before this started? Check for a stuck brake caliper while you're under the car. Make certain the axles are seated in the diffs.
you sure it wasn't the Pleiades ?
abs brakes issue 93 legacy
1 Lucky Texan replied to ktmsxguru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhill holder?
1 Lucky Texan replied to unibrook's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvery weird. Certainly could be a wiring or grounding problem. Perhaps have the alternator and battery (plus battery CABLES) checked. I've had odd behavior with a battery with a dead cell before(ABS and CEL/misfire codes). With the horn involved, could be the security system is freaking out with some kinda voltage spikes/dips? odd
H6 3.0 repair manual
dunno what year you have, but you could back-up from here and dig around; http://opposedforces.com/parts/legacy/us_b12/type_27/climate/air_conditioner_system/
1 Lucky Texan replied to kickascii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru gear oil is fine. I don't want to start any 'oil arguments' but the manual specs GL-5 for the diff and people all have their favs when it comes to that stuff. Dunno if you have a stick or auto - but the stick shares fluid with it's diff and you definitely want to be careful with that fluid - might be only 3-4 appropriate fluids for that - again, lots of 'discussion' there too. Subar Extra-S would be great. Front diff on the auto get the same fluid as the rear diff. I used my floor jack on t the end of my 1/2" breaker bar to bust the rear fill and drain plugs loose - cheater bar should work if you have room to swing it. I bought an inexpensive pump from Amazon to fill the rear diffs. I also bought a funnel with a tube on it to help with the front diffs. As said, take your time when filling, try not to overfill the front diff. The rear you fill until the fluid starts to dribble out the top hole. Can't recall the torque values for putting the plugs back in.
Want to add LSD to 1996 Legacy 5MT
could be better than a worn-out viscous unit. I guess I'd want to know more but, the price seems OK.
supercharger on an ea81
nvrmd
maybe adapt one from a Mini Cooper S ???? could be an 'interesting' project.
pipe wrenches are awesome!
you might find an english socket that is intermediate between the next smaller metric size. (1-7/16" ???, I dunno)
bad axle nuts
I think the spec for my wife's 03 H6 OBW was 159 ft/lbs. But my wrench maxes out at 150 so I used that. - hope it's close enough.
bad axle nuts
I could see a larger 'washer'/shoulder area affecting actual clamping force I suppose. Make certain you are not torqueing with the cars weight on the wheel. I put a very large screwdriver in the rotor vent and let the caliper 'buck up' the assembly while torqueing the axle nut. (I'm sure Ivan knows what he's doing, but others reading here might need that info.)
The Awesome Vehicle Picture Thread
Anybody got any Taunus pics? An old guy that ran a service station near where I lived as a teen had 2 wagons and a sedan - I think he said he brought them over himself.
Gear oil - mixed synth/non AND viscosity.Change now?
1 Lucky Texan replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA couple folks at ebay seem to repackage it. It isn't cheap with shipping, but not outrageous either. Maybe showing a listing to a local dealer might convince them to sell some smaller fraction? EDIT: a couple on-line sources for Extr-S in qts.; http://www.mysubie.com/question/Where-to-buy-Subaru-Extra-S-Gear-Oil/735 http://www.fredbeansparts.com/index.php/subaru-75w90-extra-s-gear-and-transmission-quart-bottle.html
The whole time I owned it, it had this weird cut-out at full throttle. I could back off slightly and it would pull harder. I found out years later, the trhottle cable travel is set by adjusting a bolt/jamnut under the pedal! probably was loose or misadjusted - DOH! Used to buy stuff from Rally Roadster service when they were just a dead tree newsletter sent to my house ( http://www.datsunroadster.com/ ) One of the cars the owner/instructor of the HPDE school I've run with twice owns is a Datsun 2000. Wish I'd kept mine, but - well, you know, life......
I had a '69 SRL-311 . I MAY have a pic somewhere. Was impractical with kids on the way - sold it to a guy I worked with. It burned up 2 weeks later. One of the reasons I bought my WRX sportwagon is because my 2 most favorite cars were that Roadster and an 81 Civic wagon.
my wife's 03 does (confirmed with test outlined above) - it 'may' have only been in the 'all weather package' and/or LL Bean models - not sure on that. Her's does have the AWP but is not LLBean. And i dunno if any 4 cylinders got it. Is there a way to move the gears over or swap the VLSD unit to get the correct final drive? Anyway - it would be a moderate amount of work to get a 'weak' lsd. Will any Miata rear lsd guts swap in? Or just buy a quaife,torsen or Tochigi Fugu w'ever. but major $$$$$$$ on those.
1 Lucky Texan replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know how to create the 'quote boxes'. so I use the ******* I would just add that, that entire thread has some good info in it, but it is quite long and many folks there are kinda cranky if you ask questions without doing extensive searching/reading first. One reason why I don't participate there as much as a couple other sites. Plus, I don't have the experience many other folks do. In that thread, you can find folks recommending/trying dozens of 'cocktails' to get improved shifting - while hoping longevity isn't suffering. Even Uncle Scotty uses a different mix that his original. Andrewtech now has a 'mix' they like as well. Also, many people there may already be suffering from a damaged part and are hoping a fluid change will, 'fix' their tranny - so, reports of success, failure, etc. should ALL be taken with a huge grain of salt. Throw into the mix people from Arizona as well as Alberta trying to find a fluid that is buttery smooth all the time - with folks who race, folks with 'dog-boxes', folks with modern 6spds, and folks who daily-drive, etc. it's mind boggling. The op could quite likely have used ANY decent fluid and experienced an improvement if the old fluid was thoroughly 'cooked' from age. (Even my experience could be explained by my just swapping out 35K miles old original fluid.) I might try the Motul next time, but it's more $$$$
Noob torque bind question...
1 Lucky Texan replied to Ricearu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's about the same price as I ran across doing some searches. Dunno where the $55 ones are unless that's a junkyard price? edit; prices and selection look pretty good at partsgeek - I might give them a shot. last time I bought major stuff, it was from Rockauto and everything was fine.
1 Lucky Texan replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFair enough - I really just brought up the 'cocktail' (which DOES seem to have fallen out of favor for a different 'cocktail' in that same thread) to point out that mixing MAY not create a 'panic' situation. maybe just change it at 15-20K or if it feels like it is 'degrading' or causing a problem. Soob trannies are odd - trying to get a fluid that plays well with the diff and the synchros.... can Extra S be bought in quarts now? used to be a 20 liter bucket from the dealer.
1 Lucky Texan replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are hundreds of happy folks at NASIOC running the 'cocktail' and or Redline LW Shockproof. It may not be the best in very cold climates, but even some transmission repair techs have posted with no issues after 60K miles. EDIT: here is one post from some tranny rebuilders/soob performance gurus; ******We were first turned onto Lightweight Shockproof when Pfitzner Performance Gearbox recommended that we use it in all of their Subaru 5MT synchro gearboxes. We have been using it ever since without incident. Subaru requires the use of fluid that meets GL-5 requirements due to the design of the front hypoid gearset. GL-4 fluids cannot withstand the pressure created by ring and pinion, providing insufficient film thickness between the gear teeth. This causes the gears to directly contact each other and deteriorate very quickly. We have actually seen GL-4 fluids in Subaru transmissions return with less than 500 miles and a completely destroyed ring and pinion. The metal of the ring and pinion will suspend in the fluid and act like liquid sandpaper that can potentially damage the other gears. Redline's Lightweight Shockproof is not API rated, however it is recommended for rear differential use. The front differential in a Subaru 5MT is designed and subject to the same stresses as a rear differential, as they are both hypoid gearsets. The capability of shockproof to withstand such high pressures as experienced in a differential is likely the reason that the Cocktail doesn't immediately chew up front differentials. If you have grind issues, it is not a pure indication of a bad synchronizer. It CAN be indicative of incorrect fluid choice. There are no bandages over bullet wounds here. From personal experience, Redline's 75W90NS is the "by the book" replacement fluid Subaru's SHOULD use. I've used it on that basis. From the get-go, the shifting the transmission sounded like I was shaking a bucket full of sea-shells. It was awful, and a perfect case of the "right" fluid simply not allowing the transmission to properly do its job. The balancing point is finding a fluid that provides adequate front differential protection and synchro operation while still providing lubrication for the bearings. We deal with an enormous amount of Subaru transmissions. With the exception of one, every grinding transmission we see and put shockproof in, the grinds go away. The one exception had a shattered 3rd gear synchro. It’s a fluid that, time and time again, has made Subaru transmissions shift more smoothly than with any other fluid. We have never seen a fluid influenced failure from Shockproof, and will continue to use and recommend using it until we find something better. In our opinion it is the best fluid to use in a Subaru 5-speed transmission. The Andrewtech Team Andrewtech Automotive ****** anyway, I won't argue with your experience, but folks could read some in the thread there if they want; http://forums.nasioc.com/forums/showthread.php?p=23068677&highlight=failure#post23068677 I thought the idea was it wouldn't sling off the gears. (and, from wht I've read, the 'yogurt/gel issue with the Redline was fixed 9-10 years ago, but maybe it's temp dependent also?- Uncle Scotty is in Houston) Anyway, I don't think Extra S is bad, or Motul, or almost any quality gear oil. I was just looking for something a little better. Since I do my own maintenance, I try to upgrade fluids. YMMV
