Everything posted by Bobby_boucher
I have a trans from a '85 gl-10 A/T all wheel drive and was wondering if it would work in an '87 gl-10 wagon?
Probably adds alot of charactor to the paint too
Now What?!!!!!!!!!
Bobby_boucher replied to wintersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Shouldnt it be around 8 off TDC? -
Stupid Question
Bobby_boucher replied to subarunewbie2005's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Best way to tell if it works is to put power to it...but only for a very short time, the connector is diffrent so that would deffinatly have to be changed, but other than that you need to find out what car it came off of to check the pressure of it. -
yeah the one right next to telluride.
Ever Done the Black Bear Trail??? im very interested in the trail and wonder if a subies has done it?
Turbocharger Help Needed
Bobby_boucher replied to Havnfun2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll try a wrecking yard just a couple of mile down the road from here....i knwo they have a couple of subes but im not sure if any are turbo. -
4 quarts, welcome to the board:)
Yet another newbie..!!
Bobby_boucher replied to SubbieDoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My guess would be the master switch...check for power going in and power comming out!!! Welcome to the board:) -
ok guys whats wrong with my brat???
Bobby_boucher replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah if the a/c clutch is seized and stops the belt the water pump wont turn...but you would probably hear a belt squeel from hell. -
Car suddenly got EXTREMELY loud!
Bobby_boucher replied to EYE_WHY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does it usually struggle that bad up hills??? i bet that sucker blow out because your cats plugged..... but i would just get a good rust breaker and spray the bolts and then let it soak in and try to get them off if you, at any point, feel like somthing is going to break take it to a mechanic and have them break the bolts so there liable if they break off right next to the head. -
Sheet metal noise on front suspension???
Bobby_boucher replied to BoostedBalls's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this is a stupid question and im sure you've checked but...are your brake pads low???? could it be the squeeker plates on the rotor? -
We had a car come into the shop with a very similar problem and it would overheat just a little... we went through everything and finally put a block tester on it and found that the head gasket was slowly and i mean slowly leaking. you can pick up the tester and instruction on how to use it at your local napa.
Unless the rotors are vissably tweaked( you can see a bend in them an i have never heard of that happening) they wouldnt do that. and if it were the rotor it would get worse when you applied the breaks i agree to check ball joints but also check out all your other front and parts like tie rods and steering components.
Calling John Bloom (again)
Bobby_boucher replied to NoahDL88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
is it there yet???? -
Who knows? Days and Counting (Edit First post)
Bobby_boucher replied to NoahDL88's topic in Subaru Retrofitting
I thought that was a sazuki tranfer case?!?
for some reason i had a 18 lbs cap on and i have no idea why?!?!?! i'm going to have to switch over and hope nothings wrong:-\
VOLTS??? Help if you can.
Bobby_boucher replied to DeLiSh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would check the voltage at the battery with a multimeter before trusting your gauge. hook up the multimeter and it should charge around 14 with the rmps up.
